Question about Cameras
Camera will not take pictures. Button at top of camera that you push will not activate the camera to take a picture. Is there a setting on the menu that might be able to fix this problem?
    Guru:
  • 1,705 Answers
If there's no sign of life at all, either the batteries are dead or the camera is dead.
Posted on May 20, 2011
Where is the self timer on the c-3000 digital camera
try to check this path: Press the Menu button, then press the top/bottom arrows on the Jog dial to select DRIVE. Press the right arrow and press the top/bottom arrows to select. Press the left arrow on the Jog dial to confirm the setting. If you take a
picture without pressing the OK button, the setting will be valid until the Menu is canceled. To take a picture using the selftimer, when the shutter is released, the Selftimer/Remote control signal lights for
approx. 10 seconds then blinks for approx. 2 seconds before the picture is taken. To stop the activated selftimer, press the Menu button.
Sep 06, 2010 | Olympus C-3000 Zoom Digital Camera
How do I use the timer on my camera?
Select the timer mode (left arrow on the 4-curser-button). There are 3 settings in the order of 10sec timer; 2sec timer and timer off. Select either the 10 second timer (if you want to be in the picture) or the 2 second timer (more appropriate for long exposures when camera is on a tripod or similar to avoid camera shake when pressing the shutter button), then press the shutter button fully. The subject will then be automatically focused just before the picture is taken. There's a little light on the front of the camera (top right hand corner when you look at the camera) which should blink when self timer is activated. Pressing the menu button while timer is activated will cancel self timer mode.
In low light conditions this light may turn on brightly to double up as an AF assist light.
Hope that helps
Jul 24, 2010 | Panasonic Lumix DMC-FX9 Digital Camera
Camera timer factor; wish to clear settings
Make sure you have the dial set on 'P' not green suare, then when you go to Clear settings, go up to the clear all cameras ettings, and that will res\et camera for you. Failing that, just turn the delay timmer off with the circular button 2nd from top, LHS of the LCD.
Jun 08, 2010 | Canon Rebel XT / EOS 350D Digital Camera
How to set date stamp for canon ixus 860is
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
dsc_include_date01_tcm13-520510.jpgTo set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
dsc_include_date02_tcm13-520511.jpgBe aware that if you take pictures with this option enabled, the Date and Time cannot be removed from the pictures at a further time. It will permanently appear on the picture.
Please rate my help++++Thanks for using FIXYA
Feb 28, 2010 | Canon IXUS 860 IS Digital Camera
How to set picture resolution.
Turn the camera on and set the slide on the right hand side to the red camera icon, as if you are taking photos. Turn the dial on top of the camera to the red camera icon. Press the middle circle button (menu/set), you will see that the 'picture size' menu is highlighted. Press the right arrow key to view the different resolutions available, select with the up, down and menu/set button. Press the menu/set button again to leave menu. To change resolution in intelligent auto mode, do the same thing but turn the dial to the red camera with the 'iA' in it.
Sep 20, 2009 | Panasonic Lumix DMC-TZ50 Digital Camera
Canon sd 750 how to put the date in the picture?
here is the solution:
dsc_include_date02_tcm14-520511.jpgyour date and time are set now
congratulations!
Rate this answer if it is working with you
thank you
with all my best regards
huetrichard@gmail.com
Feb 25, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
I dont no how to turn my camera on and dont no if it needs batteries or has to be charged and cannot find charger.
Push the button on top of the camera to the left of the dial, once your camera comes on, push the menu button, and hold down the larger button on the top right to take a picture.You might want to set the dial on top to the A (auto mode) as this works best. to turn the camera of, hold down the button on the top left. Hope this helps
Nov 26, 2008 | Mercury Electronics CyberPix S-550V...
Camera Frozen
I tried Option No.1 successfully when my Panasonic DMC-FZ7K froze once:
Option No1:
1. Try turning the camera on with the battery inserted.
2. Now remove the battery while the camera is on.
3. Flip the switch on the camera to off, then insert a fully charged battery. (Make sure that the battery's orientation is correct. Also make sure that the battery being used is not damaged).
4. Now flip the camera's switch to ON again.
Option No. 2:
If you can open the Setup menu then the camera can be reset which might help:
Turn on the camera.
1. Press MENU SET.
2. Press the left arrow button.
3. Press the down arrow button.
4. Press the right arrow button.
5. Now, press the up arrow button several times until the menu item named RESET is highlighted. Push the right arrow button and then select and set YES when the camera asks to be reset.
Oct 18, 2007 | Panasonic DMC-FX07 Digital Camera
Shutter button problem
This may be the same problem that requires you to press the LOCK button to actually take a picture. I found a solution and have posted to the questions mentioning the LOCK problem. Anyways, here goes, if that is not the problem please disregard what follows:
Same problem that would not allow me to take a picture without pressing the LOCK button on my Nikon 8700. Here is how I believe I fixed the problem:
Turn the camera ON.
Press MENU button on your camera to bring up the menu.
Scroll down to SET-UP, open the SET-UP menu by scrolling right.
In the SET-UP menu, scroll all the way down to FUNC (Controls) on page 2/3 , open the FUNC (Controls) menu by scrolling right.
You are now presented with 2 options:FUNC and AE-L, AF-L)
Select the FUNC option by right scrolling.
Choose the 2nd option: i.e the mountain, flower and timer icon (distance, macro and self-timer icon) by right scrolling.
Press the MENU button to get out of the menu.
Attempt to take a picture without pressing LOCK.
Should work! Anyways, it worked for me.
Cheers.
Sep 15, 2007 | Nikon Coolpix 8700 Digital Camera
Time/Date function for C-770
I dont know if this is any help because I am not sure if you actually want the date and time stamped over the top of the picture or if you just want it to have a record of the date and time with the picture. If the second option is OK then when ever you take a picture with all digital cameras I have owned and the c-770 is my newest it puts a tag in the file so that when you right click on the picture and go into the properties you can select the summary tab at the top and click on the advanced button and it will tell you every setting that the camera was set on to take that picture including the date and time it was taken.
Sep 12, 2005 | Olympus Camedia C-770 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
