Press and hold the power button for 5-10 seconds and this should shut down the computer. If not, you may want to switch the power supply on the back of the computer to off to shut the computer down.
Regards,
G33k
my problem hasnt been solved, I cant log in because the pointer has ceased.
Turn the computer off, remove the mouse and replug it back in. Turn on the computer and see if the mouse works. If not, try using a different mouse or use the mouse on a different computer. If the mouse does not work on another computer then we know the mouse is bad. If it does then we narrowed the problem down to the computer.
Well it sounds like the computer is just freezing up..What did you do before the problem started? Did you install any software? If so, you can boot into safe mode and do a system restore to a point before the problem started. To do this, as the computer is booting keep pressing the F8 key and you should get a menu. In this menu, choose Safe mode with Network. Go to Start > Programs > Accessories > System Tools and choose System Restore. Depending on your version of windows system restore could be under Administrative tools and not accessories.
my pleasure and if you can rate my solution!
I plugged the mouse into the desktop and its working fine. Its definitely the computer, the touchpad and the keyboard are not responding either.
Thankyou, thankyou, THANK YOU!!! I HAVE NOW RETURNED TO THE WORLD OF TECHNOLOGY! CUDOS 2 U!!
