Question about LG Refrigerators
My LG Refrigerator/Freezer is running water on the floor about every other day. The freezer builds up water/ice in the bottom and then it seems to defrost and run on the floor. Is it the defrost timer and how do I change and purchase the timer?
  • 4 more comments
  • s_dennis81 May 20, 2011
    My LG doesn't have a water and ice dispenser so what would you suggest for fixing my problem of building up ice in the freezer and then running water on the floor?
    Thanks
    This problem just started to occur so I'm not sure it's the setting of the thermostate.
    I was hoping that I wouldn't have to call the repair man by paying for advice from this site.....
    I have an LG Model LRFC25750ST refrigerator/freezer that is leaking water on the floor every other day. When you open the bottom freezer door the bottom of the freezer will be full of ice and it seems that it then goes into defrost mode and the water runs on the floor through the freezer seal. It doesn't however remove the ice from the freezer floor and seems to just melt some of the ice which runs on the floor. I was wondering if it was the defrost switch or something on that order and if so where do you purchase the parts?
    Thanks
    The refrigerator does have an ice maker but it's not hooked up. I pulled the refrigerator out from the wall the other day and inspected the water tray which is on the back side and you can't remove it from the front. I will inspect the door seal again but didn't find anything when I inspected it the other day.
    Do you have the manual for this model of refrigerator? I can't find mine but it should show you the drain pan on the back side of the refrigerator.
    Thanks
    I inspected the seals again and then cleaned out the ice from the bottom of the freezer. I don't see how anything from the freezer drains into the pan, there isn't a hole anywhere. Does it drain into the pan?
    I also adjusted the feet so that the doors would close on thier own.
  • salwood1 Dec 16, 2014
    often the circulation channel is blocked with ice, just turn it off forr 24 hours & it melts the ice build up, if that is the problem
  • 794 Answers
His_dennis81,
If water running down to your floor from your freezer ice may be blocking the circulation channel inside the fridge. It's easy to address this problem. Just kindly follow the steps below to stop the issue:
1. First thing to do is to empty your freezer compartment. Once emptied, open it up so you can access evaporator and defrost coils.
2. To melt any ice around the coils and in hole to bottom of the machine you may use a hair blower.
3. Then, blow through hole to make sure that it is free of debris and ice.
4. Finally, using a copper or aluminum wire place onde end of the wire into the hole and wrap enough amount around the defrost coil.
Small amount of heat will be transferred by the wire down the hole to make sure that it remains ice free. This will solve your drainage problems with your freezer defrosting and water running out of the refrigerator.
There are diagrams available on this link that you can view. You might find it helpful. Also, remember your safety during the process.
Hope it helps.
Thank you for using FixYa.
Posted on May 20, 2011
    President:
  • 1,216 Answers
No, defrost timer is not a cause while there are several other causes which you eill inspect step by step.
Analyzing the likely source
Move the refrigerator out from the wall and look for the location of the leak.
Check the side panels and the seals around the door for beads of "sweat." This could indicate a condensation problem.
Check the floor. A puddle there could indicate a missing or cracked drip pan, or a leak in the water line that feeds your ice maker.
Check for water seeping from the front of the freezer or the refrigerator. This could indicate your defrost drain is plugged or your ice maker is leaking.
Fixing a condensation problem
5
Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely.
6
Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets (see How to Fix a Refrigerator That Cools Poorly).
7
If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls.
Fixing a drip-pan problem
8
Pull off the grill that runs along the bottom of your refrigerator.
9
Locate the drip pan, using a flashlight if necessary. The pan should be sitting on top of a set of black condenser coils and directly below a drain tube that carries water from your freezer when it is in defrost mode.
10
Place the drip pan in your sink and fill it with water to test for leaks. If it leaks, order a replacement from your appliance dealer.
11
If the drip pan doesn't leak, clean it with warm, soapy water, then reinstall the pan and the refrigerator grill.
Fixing a clogged defrost drain
12
Locate the defrost drain. It should be a round hole or a channel running under the vegetable and fruit bins in the refrigerator or along the floor of the freezer compartment.
13
Inspect the drain for clogs and remove any debris. If necessary, use a small screwdriver to break up debris that's trapped in the drain hole.
14
Fill a meat baster with hot water and force it through the drain to make sure the clog is gone. If the drain is operating properly, the hot water will fill the drip pan.
Fixing a leaky ice maker
15
Pull the refrigerator away from the wall and locate the copper water-supply line. It runs from the house water line to the refrigerator water-supply valve. (To get to the supply valve, you may have to use a screwdriver or a nut driver and socket to remove your refrigerator's back access panel.)
16
Inspect the copper supply line, the supply valve, and the plastic supply tube that runs from the other side of the supply valve to the back of the ice maker.
17
If a connection is leaking, tighten it with an adjustable wrench. If either the copper supply line or the plastic supply tube is leaking, you need to replace it.
18
Turn off the water supply. The valve may be under the kitchen sink or connected to a cold-water pipe in your basement.
19
Remove the faulty line and take it to a hardware store to get an exact replacement.
20
Install the new line, tighten the connections with the adjustable wrench and turn the water back on.
    President:
  • 739 Answers
Hi..
Many LG refrigerators include an ice and water dispenser on the front of the refrigerator. The ice and water dispenser also has a control panel that, in addition to controlling the dispenser settings, allows you to adjust the internal temperature of the refrigerator. By default the internal temperature is set to Fahrenheit, however it is designed to be easily changed to Celsius. If at any time you would like to switch the temperature read-out back to Fahrenheit, you can do so with the touch of a button.
Instructions
1>Locate the "Freezer" and "Refrigerator" buttons on the ice and water dispenser control panel.
2>Press and hold the "Freezer" and "Refrigerator" buttons simultaneously.
3>Release the "Freezer" and "Refrigerator" buttons when the temperature display changes from Fahrenheit to Celsius, which takes approximately five seconds.
To get more support with your LG product CLICK HERE
CLICK HERE to download manual guide for your reference
Regards
  • HTS Sri Aman
    HTS Sri Aman May 20, 2011
    to build the ice you just have to adjust the temperature of the water level temostart to freeze, if your freezer fails to do so, this means that there are other problems in your fridge and it requires you to make a detailed inspection of your refrigerator, as is often done by specialists providing a refrigerator repair service.
Leaking water on floor
Remove contents from bottom of freezer. Turn ref/freezer off. Use the handle end of a screwdriver and carefully break up the ice build up from the bottom of the freezer. Find the condensate drain and remove ice build up. Find the condensate drain and remove ice or any kind of restriction from the drain line.
Or you can turn the refrigerator off for a day , mop up the water and blow out the condensate drain
Jan 18, 2016 | Maytag Refrigerators
I have a french door stainless LG refridgerator with the freezer on the bottom. I have ice building up in the bottom of the freezer. When I pull out the drawer there is a layer of ice on the bottom. ...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 19, 2011 | LG LFC23760ST Side by Side Bottom Freezer...
My Lg bottom freezer refrigerator, model # LFC21770ST leaks constantly down in the bottom of the freezer and comes out onto the floor. Ice dams build up under the freezer drawer. I take out the ice, but it...
The drain for the auto defrost water is plugged up somewhere.You will need to look at the very back and bottom inside the freezer to see if you can locate it and clean it out.Also you may have to pull the refrig out from the wall and try to get to it from the back.Hope this aleast gets you looking in the right direction.
Jun 29, 2011 | LG Bottom Freezer Refrigerator w/...
Ice build-up in bottom of freezer section.
your defrost drain on the freezer side is stopped up causing the drain to freeze over then eventually running out on the floor during the defrost cycle. Locate the drain at the back of the freezer and thaw it out using hot water. Using a screw driver or other object gently push down into the defrost hole and dislodge whatever is stuck there.
An air hose with good air pressure may also work well. When the drain line is clear you should be able to pour water through it freely.
Jun 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Once or twice per day, water on floor below freezer door
check for plugged drain at back bottom of freezer if plugged/frozen over defrost and clear with hot water and remove all ice.
Nov 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
Leaking water from the bottom on the freezer side. It's a side by side refrigerator and is set up for water/ice on the front left(freezer) side but this has been disconnected and is not in use. Water...
check this website repairclinic.com they are talking about a clogged drain plug for the defrost cycle. seems we have exactly the same situation. see if this helps
Sep 24, 2009 | Kenmore Refrigerators
Lg frost free fridge freezer gr-399sq
on the back wall inside the freezer unscrew the white panel and then remove the panel behind this . you should now see a tray that runs the width of the freezer with a driphole on the left-hand side which will probably be frozen with ice , chip away whatever is possible and then put boiling water on the driphole and once this is clear you should find the problem sorted , 1 other option is to turn the fridge/freezer off for several days and this will allow the ice build-up to thaw thus resolving the problem
Jan 05, 2009 | LG LFD22860 Stainless Steel Bottom Freezer...
Water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Feb 23, 2008 | Kenmore 71279 Bottom Freezer Refrigerator
Ice build up on the bottom floor of the freezer
Sounds llik a defrost heater is open if you
have a VOM you can test it for continuity
Its probably behind a panel in the rear bottom
of the refrilgerator Should have a pan under
there to
Nov 21, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
1,872 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
