Question about Avalanche Gt 30 Mountain Mtb Mtn Bike Red Xs 06
NEED TO REPLACE FRONT BRAKE PAD.... - Avalanche Gt 30 Mountain Mtb Mtn Bike Red Xs 06
    Brigadier General:
  • 8,546 Answers
Replace brake pad light on, how do you reset it?
you need to replace the pad wear sensor when the pad wears down it wears the sensor and the sensor needs to be replace if you look at the sensor you can see the wire on the sensor wears threw
May 19, 2012 | 2009 Audi Q7
How to replace front disc pads
Jack up the front end remove tire onthe brake pad assembly there will be two Hex head bolts these will be probably a 3/8 u can use a big Alan wrench u will also need a small pipe to use a breaker bar and some WD 40 as these bolts are probably rusted just a bit,once u have the bolts out u should be able to remove the brake pad assembly,u might need a rubber malet to help with this,OK u got this off take the new brake pads out of the boxs,pay speial attention to the back of them,now take a big screw driver a pry just one of the brake pad off if u do the side with the caliber on it,(this is the round thing that pushes the brake pad on to the disk to stop the car)There is a clip take this clip off look that the back of the brake pad find the new brake pad that has the same notches in it put the clip on it the same way it came off put it back on the caliber,ok take the other one off,nothice the clip might be made in to the brake pad assembly on this side if not put clip in to same notches,Ok now u have replace the brake pads u will notice that the brake assembly will not go back on, not to fear take a Clean rag place it on the pad on the caliber side get a pair of channel locks now compress the caliber abit now it should side right on replace bolts and u are good to go do other side the same way.
Apr 03, 2011 | Honda Civic Cars & Trucks
Step by step instructions on how to replace front break pads on a 2003 VW Passat
For front brake pads replacement you need only usually wrench set, inclusive 7 mm allen key also.
But for rear brake pads replacement you need obligatory a special caliper piston pressing tool, in order to press back rear caliper piston with parking brake automatic adjustment!!!
For front brake pads. First you must verify yours front brake disc diameter: 280 mm or 288 mm. After that you can buy the brake pads (with wear sensor). For change front brake pads you must raise vehicle, remove wheels, extract the retaining spring of the caliper, and remove the caliper as follow:
1. Do not disconnect the brake hose from the caliper, and do not allow the caliper to hang by the brake hose!
2. Remove top and bottom caps (on back side of the caliper) for access to guide pins, then unbolt and remove them from the brake carrier. Remove the caliper.
3. Now you must thoroughly clean the brake calipers (free of grease).
4. Remove outer brake pad from brake carrier.
5. Pull inner brake pad out of brake caliper piston.
6. Check up the brake fluid level on the reservor, and emptying if neccessary!
7. Push piston back into brake caliper housing.
8. Install inner brake pad (with expanding spring) in brake caliper piston. (Arrow marked on pad - if exist, must point in direction of brake disc rotation when vehicle is moving forward).
9. Install outer brake pad into brake carrier.
10. Bolt brake caliper housing to brake carrier using two guide pins. Tightening torque is 25 Nm.
11. Install both caps.
12. Insert retaining spring into brake caliper housing. Important: Depress the brake pedal firmly several times while the car is stationary so that the brake pads adjust to their normal operating positions!!! Check brake fluid level and top up if neccessary!!!
Mar 10, 2011 | Volkswagen Passat Cars & Trucks
Change brake pads
For front brake pads replacement you need only usually wrench set, inclusive 7 mm allen key also. But for rear brake pads replacement you need obligatory a special caliper piston pressing tool, in order to press back rear caliper piston with parking brake automatic adjustment!!! For front brake pads. First you must verify yours front brake disc diameter: 280 mm or 288 mm. (On my car y have 288 mm). After that you can buy the brake pads (with wear sensor). For change front brake pads you must raise vehicle, remove wheels, extract the retaining spring of the caliper, and remove the caliper as follow: 1. Do not disconnect the brake hose from the caliper, and do not allow the caliper to hang by the brake hose! 2. Remove top and bottom caps (on back side of the caliper) for access to guide pins, then unbolt and remove them from the brake carrier. Remove the caliper. 3. Now you must thoroughly clean the brake calipers (free of grease). 4. Remove outer brake pad from brake carrier. 5. Pull inner brake pad out of brake caliper piston. 6. Check up the brake fluid level on the reservor, and emptying if neccessary! 7. Push piston back into brake caliper housing. 8. Install inner brake pad (with expanding spring) in brake caliper piston. (Arrow marked on pad - if exist, must point in direction of brake disc rotation when vehicle is moving forward). 9. Install outer brake pad into brake carrier. 10. Bolt brake caliper housing to brake carrier using two guide pins. Tightening torque is 25 Nm. 11. Install both caps. 12. Insert retaining spring into brake caliper housing. Important: Depress the brake pedal firmly several times while the car is stationary so that the brake pads adjust to their normal operating positions!!! Check brake fluid level and top up if neccessary!!!
Sep 30, 2010 | Audi A6 Cars & Trucks
What tools needed to replace front brake pads & rotors
Brake Pads
Removal & Installation
Front
3.4L front disc brake assembly
4.0L and 4.7L front disc brake assembly
To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of
    this section.
  2. Remove or disconnect the following:
    • Front wheel
    • Clip, 2 caliper pins, the anti-rattle spring then remove the 2 brake pads
      and the 4 anti-squeal shims
To Install:
CAUTION
Only replace brake pads on 1 side of the
vehicle at a time. Failure to use this procedure could cause the caliper pistons
on the opposite side of the vehicle to pop out requiring the reconditioning or
replacement of the brake caliper.
  1. Remove a small amount of brake fluid from the master cylinder.
  2. Install a used brake pad into the caliper and compress the caliper pistons.
  3. Apply disc brake grease to both sides of the inner anti-squeal shims.
  4. Install or connect the following:
    • Anti-squeal shims to the new brake pads
      NOTE: When replacing worn pads, the anti-squeal shims must be replaced
      together with the pads.
    • 2 brake pads
    • Anti-rattle spring and the 2 caliper pins
    • Clip
    • Front wheel
  5. Depress the brake pedal several times to seat the brake pads.
  6. Check the brake fluid level and top off as needed.
Rear
To Remove:
    this section.
    • Rear wheel
    • 2 cylinder slide pins from rear caliper assembly
    • Caliper assembly from rear caliper mounting
    • 2 brake pads with anti-squeal shims from rear caliper mounting
    • 2 anti-squeal shims from each disc brake pads
    • Pad wear indicator plate from the inner side disc brake pad
    • 4 pad support plates from the rear caliper mounting
To Install:
  1. Install or connect the following:
    • 4 pad support plates on the rear caliper mounting
    • Pad wear indicator plate on the inside brake pad
      Note: Install the pad wear indicator facing downward.
    • Anti-squeal shims on each brake pad
    • 2 disc brake pads with anti-squeal shims to the caliper assembly
  2. Apply lithium soap base glycol grease to the sliding part of 2 caliper slide
    pins.
  3. Install or connect the following:
    • Disc brake caliper assembly with 2 caliper slide pins
    • Torque to 65 ft-lbs (88 Nm)
    • Rear wheel
  4. Depress the brake pedal several times to seat the brake pads.
  5. Check the brake fluid level and top off as needed.
--- Removal & Installation
Front
To Remove:
    this section.
    • Front wheel
    • Front brake caliper assembly
  3. Make matchmarks on the disc and the axle hub.
  4. Remove the front disc.
To Install:
  1. Align matchmarks and disc onto axle hub.
  2. Install or connect the following:
    • Front brake caliper assembly with the 2 bolts
      1. Torque to 90 ft-lbs (123 Nm)
    • Front wheel
Sep 23, 2010 | 2003 Toyota 4Runner
WHAT TOOLS ARE NEEDE TO REPLACE AUDI A3 SPORTSBACK FRONT BRAKE PADS
For front brake pads replacement you need only usually wrench set, inclusive 7 mm allen key also. But for rear brake pads replacement you need obligatory a special caliper piston pressing tool, in order to press back rear caliper piston with parking brake automatic adjustment!!! For front brake pads. You must buy the brake pads with wear sensor. For change front brake pads you must raise vehicle, remove wheels, extract the retaining spring of the caliper, and remove the caliper as follow:
8. Install inner brake pad (with expanding spring) in brake caliper piston. (Arrow marked on pad - if exists, must point in direction of brake disc rotation when vehicle is moving forward).
Feb 14, 2010 | 2006 Audi A3
Wat tool do i need to remove front and back brake calipers so i can replace brake pads on a audi a4 2002 2.0 se
For front brake pads replacement you need only usually wrench set, inclusive 7 mm allen key also. But for rear brake pads replacement you need obligatory a special caliper piston pressing tool, in order to press back rear caliper piston with parking brake automatic adjustment!!! For front brake pads. First you must verify yours front brake disc diameter: 280 mm or 288 mm. (On my car y have 288 mm). After that you can buy the brake pads (with wear sensor). For change front brake pads you must raise vehicle, remove wheels, extract the retaining spring of the caliper, and remove the caliper as follow: 1. Do not disconnect the brake hose from the caliper, and do not allow the caliper to hang by the brake hose! 2. Remove top and bottom caps (on back side of the caliper) for access to guide pins, then unbolt and remove them from the brake carrier. Remove the caliper. 3. Now you must thoroughly clean the brake calipers (free of grease). 4. Remove outer brake pad from brake carrier. 5. Pull inner brake pad out of brake caliper piston. 6. Check up the brake fluid level on the reservor, and emptying if neccessary! 7. Push piston back into brake caliper housing. 8. Install inner brake pad (with expanding spring) in brake caliper piston. (Arrow marked on pad - if exist, must point in direction of brake disc rotation when vehicle is moving forward). 9. Install outer brake pad into brake carrier. 10. Bolt brake caliper housing to brake carrier using two guide pins. Tightening torque is 25 Nm. 11. Install both caps. 12. Insert retaining spring into brake caliper housing. Important: Depress the brake pedal firmly several times while the car is stationary so that the brake pads adjust to their normal operating positions!!! Check brake fluid level and top up if neccessary!!! Please Rate my Response! Thanks!
Aug 01, 2009 | 2002 Audi A4
Front brake service for a 1995 subaru legacy. Repair calipers and new pads how to do it?
Calipers need repairing only if they leak. Remove tire then calipers. Remove brake pad from calipers. Compress pistons in brake caliper and install new brake pad. Replace calipers and tire.
Jul 29, 2009 | 1995 Subaru Legacy
Need to replace front brakes. is it hard to do
ya gotta be careful if she has antilock or air sensors stuff will break easy an iz EXPENSIVE call auto part store may have instruct. online for ya
Jul 28, 2009 | 2001 Audi A4
2001 brake pad replacement 2001 nissan quest
The hard part is pressing the caliper piston abck into the caliper so you can get the new, thicker pads over the rotor. A large C Clamp works best.
SECTION 206-03: Front Disc Brake 2001 Villager Workshop Manual
REMOVAL AND INSTALLATION Pads —Front Disc Brake Removal
  1. Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .
  1. Remove the front disc brake caliper bolts. torx bit. T20?
  1. Support the front disc brake caliper from the front strut and spring assembly using mechanics wire.
  1. Remove the front disc brake pads.
    1. Remove the outboard front disc brake pad.
    1. Remove the inboard front disc brake pad.
Installation
  1. s1v~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Make sure the master cylinder reservoir does not overfill and spill brake fluid while retracting the front disc brake caliper piston.
    NOTE: It is necessary to fully retract the front disc brake caliper piston in the bore before installing the front disc brake pads.
    Install the front disc brake pads.
    1. Install the inboard front disc brake pad.
    1. Install the outboard front disc brake pad.
Caution. The outer pads are left and right. put left on driver side.
  1. Position the front disc brake caliper on the front-wheel knuckle and install the brake caliper pin bolts.
  1. s1v~us~en~file=ani_caut.gif~gen~ref.gif WARNING: It is necessary to depress the brake pedal several times to position the front disc brake caliper piston before driving the vehicle.
Apr 23, 2009 | 2001 Nissan Quest
Avalanche Gt  30 Mountain Mtb Mtn Bike Red Xs 06 Logo
Top Avalanche Cycling Experts
John Egan
John Egan
Are you an Avalanche Cycling Expert? Answer questions, earn points and help others
