Hi!
Seems like your MAC goes into sleep mode, when this happens, the computer does not supply power to the USB ports to save power. When the computer does this, there is a big change that will drain out the battery of the Reader. You can try this:
1. Connect the reader to the computer
2. Hit the reset button while is connected for 3 seconds (Reset is located at the bottom of the unit)
3. Leave the reader charging for about 40 minutes then disconnect the reader and check the battery meter
4. If you can see that the reader took some charge then leave it connected for 2 hours or until the redlight goes off
Good Luck!
eBookBoy
http://digialreader.freeforums.org
