Question about Keurig B60 Coffee Maker
The coffee pot will not turn on it must have something to do with the timer i can't find the manual
  • Keurig Master
  • 43,501 Answers
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Posted on Sep 05, 2011
Set the timer to start brewing, i have always done this with no problem till now
Could be the brewing mechanism or the timer. However, if you get the action you describe on BREW NOW, I am inclined to think the brewer has failed.
Nov 10, 2013 | Mr. Coffee 072179228578 12 Cup Coffee...
WE HAVE A BUNN VLPF SERIES COFFEE MAKER. WHEN YOU PUSH THE BUTTON TO MAKE A POT OF COFFEE, THE WATER DOESNT STOP AT ONE POT IT MAKES 6-7 BEFORE IT STOPS. IF YOU TURN OFF THE MACHINE WHEN THE DECANTER IS...
Sounds like your timer part #32400.0002.This is the new type timer which replaces the dial timer.Another thing is does this happen when you turn on the on/off switch? I would also check your liquid level probe in top of tank.Always a possibility bad liquid level board.If it only does this when you push the brew button the timer is bad.
Feb 07, 2011 | Bunn VLPF Coffee Maker
I BOUGHT A USED BUNN COFFEE MACHINE STF-15. IT CAME WITH THREE POTS THAT HAVE THE NAME ELLIS COFFEE ON THEM. PART #2097 0202. WHEN I RUNS IT THE POT OVER FILLS. DO I HAVE THE WRONG POT OR IS THERE AN...
This is usually the result of an incorrectly set timer (see p. 22 & p. 24 of manual) or stuck solenoid valve (p. 18). A link to the owner's manual is provided below. You should read the manual thoroughly before attempting adjustments & repairs.
http://www.bunn.com/pdfs/commercial/manuals/29251.0000.pdf
I hope this helps!
Oct 20, 2009 | Coffee Makers & Espresso Machines
After brewering the level in the pot is a little low .
We could have 2 things going, the easiest is to remove the spray head, and using the deliming spring clean out the brew tube.
The hard way is to check the water level, brew 2 pots to check level, if you get the exact amount in both pots, then wee will program the brewer. Depending the model you might have a timer knob behind panel or a circuit board.
If timer knob then turn to a longer time settings.
If a circuit board the settings and instruction are pasted on the front label.
Jun 01, 2009 | Bunn Automatic Coffee Brewer CWTF15 1
Need help on using Timer feature on Melitta Mill & Brew
My second one just died, and I am very sad, but I can help you with your question.
First you have to set the time. Do that by pressing the hour or minute buttons until the time blinks. Then you can press the buttons to set the time. AM/PM are differiented by a red dot coming on in the time display. You can set that as preferred.
To set the timer feature, press the time button until the time blinks. Then use the hr and min button to set your timer setting. Pay careful attention to match the am/pm button with what you want.- if you don't you will be 12 hour off. To use the delay, set up the coffee pot, then push time. The red time indicator will light. If you are using ground coffee press the mill button. If it is lit, the mill will not turn on. This goes for either timed brewing or present tense brewing.
THe coffee pot has a timer - it will shut itself off after 1 hour. If you want to restart it, just push the mill button and press the on/off button.
Mar 15, 2009 | Salton Melitta Coffee Maker 10 Cup - white...
Cooffe brews on its own
Hello. Here is what could be happening. Your brew timer may be having a problem where it is re actuating on it's own, in which case it would need to be replaced, and re calibrated. The other possibility is that the start switch is making contact internally, and telling the brew timer to start again. Your unit does not show it having a level probe, so most likely it is not overflowing due to a flooding condition. After you brew, turn off the lower heat switch, this will remove power to the brew circuit, if the problem stops, then you know it is one of those 2 things, and I would try the start switch first, as it is a cheaper item to replace than the timer.
Here is a link to your brewer manual with part #'s etc..
http://www.bunnomatic.com/pdfs/commercial/manuals/10613.0000.pdf
Hope this helped, and thank you.
Mar 12, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Water over filling pot
There is a brew timer on the left side of your machine near the heater switch. you need to remove an access panel to access it. turn this down a little, let the water heat up, then try another brew. Adjust as needed, brewing another pot between each setting.
Jan 07, 2009 | Bunn-O-Matic Coffee Brewer GRW8
MyCurtis,Alpha-111S coffee machine isover filling the coffee pots
that model may have a digital timer that is acssed using the panal swithes get the number for wilbur curtis from thier web site they will talk you through it {simple} the other style timer is a potentiometer type To adjust first unplug brewer, look behind either the front panel or top cover for a dial with numbers around it. turn the dial down slightly brew a pot of water see where the water level comes keep turning down till desired level is reached
Jan 04, 2009 | Wilbur Curtis Alpha G3 Concourse...
Keurig B60 Coffee Maker Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
