Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Error code c0202 - Konica Minolta bizhub 350 All-In-One Laser Printer
    Sergeant:
    Champion:
  • Konica Minolta Expert
  • 355 Answers
C0202 means that the top paper tray is not rising to bring the paper in contact with the feed rollers. Remove all of the paper from the tray and try turning the machine off and on with the paper tray not pushed in to the machine. Good luck.
Posted on May 20, 2011
4 Suggested Answers
  • 55 Answers
SOURCE: Error code c0202. What is
Most likely there is paper stuck in the very back behind one of the trays. Take both trays out and see if there is any paper jammed (could be a small piece). Put trays back in but leave them open, turn off the printer, unplug it, wait 5 minutes, plug it back in, turn it back on and push in the trays.
Posted on Dec 23, 2010
  • 158 Answers
SOURCE: error code C0202
this is a tray 1 lift up failure code pull the paper tray out and check to see if some torn paper is blocking the lift sensor look around where the paper is fed into the feed plates if not it could be a failed lift motor or sensor and they will need to be replaced
Posted on Dec 02, 2009
SOURCE: Bizhub 200 Error Code C0202
I fix the error thanks to Patrillica on my BIZHUB 350!
The paper stock in tray 1 or to be exact above the tray 1, when you open it, you can hardly see it. After you remove the paper you should unplug your machine and then lug it back.
Thanks again to Patrillica.
Posted on Jun 05, 2008
My minolta bizhub c6501 has a trouble code of c0203. How do I fix it?
Description
Intermittent C-0201 (C0201), C-0202 (C0202) and C-0203 (C0203)paper lift error codes.
Solution
PROBABLE CAUSES:
1.The trail edge paper guide (p/n A03U R756 00) may not be pressed against the paper. This will allow the paper to fall backwards and induce the error code.
Instruct the end user to check the position of the trail edge paper guide whenever paper is loaded into the paper tray.
2. Coupling for the tray lift for Tray 1, Tray 2 or Tray 3 is obstructed or out of alignment causing the tray to not lift.
Inspect the coupler in the back of the machine for paper preventing the pin from seating in the coupler. Check alignment when tray is inserted. If out of
alignment try to adjust the drive to properly align.
Oct 04, 2017 | Minolta Office Equipment & Supplies
MY BIZHUB 283 SHOWING THE ERROR CODE C-0202
Code
C0202
Description
Tray 1 feeder up/down abnormality
The tray 1 upper limit sensor (PS22) is not blocked even after the lapse of a given period of time after the lifting motion has been started.
Remedy
1 Check the connector between M12-PRCB CN25 for proper connection and correct as necessary. 2 Check the connector of M12 for proper drive coupling and correct as necessary. 3 Check the connector between PS25-relay CN30- PRCB CN26 for proper connection and correct as necessary. 4 PS25 I/O check, sensor check PRCB CN26-3 (ON). 5 M12 operation check PRCB CN25-5 (REM). 6 Replace M12. 7 PRCB ICP5 conduction check. 8 Replace PRCB.
Konica Minolta bizhub C224e Error Codes
Nov 08, 2016 | Office Equipment & Supplies
How do I correct error code C0202?
Did you take the paper out of the left side of draw that area is not a storage area!!!!! DO NOT STORE extra paper on the left side of any draw, that space is use for 11x17 paper. Might have a bad lift motor, might also check the roller assy for the draw, since there are sensors that determine if the paper lifted
Jun 11, 2015 | Konica Minolta bizhub Office Equipment &...
C0202 bizhub c353
open the draw check for any paper behind it, THEN REMOVE ALL OF THE PAPER SITTING ON THE LEFT SiDE OF THE DRAW
NOT A STORAGE AREA. for 11 x 17 paper
Feb 05, 2014 | Konica Minolta Bizhub C353 Copier
Konica printer error code c0202
try to reinstall the printer driver
Nov 20, 2013 | Office Equipment & Supplies
Call service person code c0202
Maybe calling a service person and reporting a displayed C0202 code will help solve this problem
May 11, 2013 | Office Equipment & Supplies
Clarified error code for bh283: C-0202
Solution ID
TAUS1103824EN* Solution Usage 1
Description
C0202 (Tray 1) error code.Traymight not rise and indicates "out of paper" soon after it has been pushed in.
Solution
CAUSE: Actuator (Lever) for the upper limit sensor is hit very hard by the paper tray when opening/closing the drawer, and the Lever breaks.Upper limit
sensor (PS12/PS22) is either not activatedby the actuator(generating the error codes) oris always actuated(generating the out of paper message).
<Parts Guide Manual: Page 13, 16>
SOLUTION: Replace the current Lever (p/n A1UD 5611 00) with the modified one (p/n A1UD 5611 01).
APPLIED PRODUCT
Nov 22, 2012 | Konica Minolta Bizhub 283 Copier
Error code c0202. What is it mean? Konica-minolta bizhub c250
Dec 23, 2010 | Konica Minolta bizhub C250 All-In-One...
A paper jam was not cleared in a timely manner, now the machine will only display "Error Code C0202, Call Technician" It is Saturday and I can not get a hold of anyone at our support center. How can I...
C0202= tray 1 elevator failure.
Open tray 1, check and make sure paper is loaded correctly.
With tray open, open and close front door. This will reset error code. With tray 1 open look to see if paper is stuck behind tray in back of machine, if so remove it ( this will block the lift motor for the tray).
Close tray 1, if you hear a popping noise the lift motor is damaged and will have to be replaced. Until it is replaced operate machine with tray 1 out to prevent error code.
Sep 18, 2010 | Konica Minolta Bizhub 362 Copier
Error code C0202
Nov 29, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
6,243 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
