Question about Dishwashers
Model cw492 starts then panel light flashes seven times
  • helen_hendry May 21, 2011
    when power is switched on the seems to drain and the light flashes 7 times. if the power button is pressed again the machine partially fills and then drains then light flashes 7 times
  • 4,323 Answers
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine.
Hope this helps... Please post back if you need more information.
Daniel
Posted on May 21, 2011
  • Dishwashers Master
  • 3,247 Answers
I am assuming it is a CDA cw492 dishwasher.
Panel light flashing 7 times would mean some sort of inlet water failure. Either the water tap is turned off or the inlet water pressure is low or the water inlet solenoid is faulty.
You will have to isolate one by one.
Posted on May 20, 2011
Panasonic 50 inch plasma th 50px80ua tv won't turn on and red light flashes seven times
Hi Steve, The link below is a YouTube video showing a panasonic television with 7 red flashes, Also there's videos down the right side of the link that may help as well... I hope this helps............CHEERS..
Panasonic TC P50S30 review seven led flash
May 01, 2016 | Panasonic Televison & Video
Why is my 2007 Kia Rio Check Engine light flash seven times?
Does it studder (or act as if misfiring?) while accelerating?
Aug 23, 2014 | 2007 Kia Rio5
The red light flases 7 times and thats it
The seven flash thing would be helpful if you gave the make/model of the set
Aug 28, 2011 | Televison & Video
Tv shuts off on start up and light flashes six times
more loose inside your tv that is a reason for your tv shut off you need to resolder the printed board
Jun 24, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
My Whirlpool DU1145XTP won't turn on. Clean light
Check the themistor in the control panel. Radio Shack sells these for about $1.30 each. I replaced the one in my dishwasher three years ago and have had no issues since.
May 16, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Green light flashes 7 times - why?
Ok, the reason for the shutdown is because of a serious control fault within the control panel. it could be because of a simple lose wire or, it could be as serious as a damaged control circuit board.
The best way to find out is to use a multimeter and test all pins on the back of the control panel for their respective operational values. Make sure the wires are not worn and damaged as well. check the entire wiring harness for lose fit on all correlating parts in the unit.
If you are not an experienced electrician, i would recommend calling in a tech for a look. Your tech will run a smilier inspection to make sure its the control and not a motor malfunction.
In most cases, this will most defiantly be a control board failure and replacing the board will usually fix this type of issue.
PLease rate and god bless:)
May 09, 2009 | Dishwashers
Canon i320 amber light flashing will not print
I believe that 7 amber flashes refer to a cartridge error. Check that the cartridge is seated correctly.
Nov 05, 2008 | Canon i80 InkJet Printer
Cda dishwasher
green light on right flashing and beeping noise..Problem solved by thowing a few pints of water in the bottom of the dishwasher...must have 'primed' the pump..which must have been the problem; working fine now. David- Crosby
Apr 19, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Dishwashers Logo
113 people viewed this question
Top Dishwashers Experts
