I connected extrernal keyboard for aicr labtop whin I dissconnect it the built in keyboard for the laptop does not work proberly some keies changed like m changed to z and so thanks alot for helping
    Sergeant:
  • 228 Answers
Here are some steps which you might want to try.
- Access BIOS and reload the default settings.
- Boot to Safe Mode with command prompt and test if all keys work properly.
- If the keyboard works properly in Safe Mode with command prompt, the registry inputs of your operating system are messed up. You can do registry editing (recommended for advanced users) or just back up your files and reinstall the operating system.
Hope this helps. Just leave a comment or question if you need further assistance. Thanks.
Posted on May 20, 2011
My keyboard is not working right keys E,D,C,3,F4 &F5 are not responding when I use it, thats why i'm using on-screen keyboard often times.
It could be a bad connection. The keyboard is usally pretty easy to remove. On most labtops it can be removed with a small screwdriver along the edge of the keybord. It is connected to the motherboard with a brezel connector, check that it is not loose. If you cant find the fault you can normally find a replacement keyboard on ebay for as low as 20 bucks.
Take a look at this guide
Mar 23, 2011 | Toshiba Computers & Internet
Keyboard does not work...I have to use on-screen keyboard--which sucks!!! Please help !
Hi... If you spilled liquid on the keyboard it stops working and it has to be replaced, otherwise the keyboard unlike anything else in the laptop it does not just stop working for no reason unless the interface on the mainboard is the problem but then again if that is the case it will not be just the keyboard... You may also want to check if it is connected proberly, there should be few screws in the bottom of the laptop (not all screws) that you can remove and with a thin flat screw driver try to pull the keyboard off, be careful not to damage it or the pc and not to pull it very far, it should be somewhat attached with a wide flat cable... check the connection of that cable and maybe remove and reconnect to be sure, turn the machine on and check if anything happend... hope that helps, if not then maybe you can replace or use an external keyboard... Best of luck
Jan 29, 2011 | Dell Latitude E5400 Laptop
My keyboard does not work can't get any keys to work onmy labtop i have to use the on screen keyboard
1) Go to your device manager disable then enable the keyboard.
2) Check the HP website for up to date driver for your keyboard. Download and install.
3) Most laptops have a PS/2 connection, try a PC keyboard, does that work?
4) It's a case of taking the laptop apart and checking the ribbon connector on the laptop is fully home.
Apr 18, 2010 | HP Pavilion dv6000z Notebook
Labtop with no vga but turns on
yes. the shell is only to hold the components together and to protect the device. you still might need to connect some peripherals to it so that you can use keyboard and mouse. as for the vga you might need to setup a usb or some other connection to have video.
Jul 08, 2009 | Computers & Internet
Keyboard not working; want to replace a new keyboard myself; how to do it?
Look underneath the labtop there should be two screws that hold the keyboard in place..
Apr 22, 2009 | HP Pavilion dv4000 Notebook
I have hp labtop pavilion dv4 with AMD Turion X2 ultra - the labtop screen become black and all icon disapper but i can move the mouse pointer. the system remain on and i could not shutdowen it untill i...
firstly , i just want to let you know that it is a laptop not a labtop. But anyway In windows you cannot make a restart from the keyboard. When this happenes, just hold down the power button untill it shuts off (about 10-15 seconds)
Apr 10, 2009 | HP Pavilion G60-120US NoteBook
How do i work the webcam on my labtop
you can download the application software for your built camera in hp support web site
Mar 15, 2009 | HP Computers & Internet
HDMI HP Labtop to Mitsubishi HDMI not working
Easy...first connect the hdmi cable between laptop and tv. Press and hold the 'fn' key on the laptop keyboard - bottom left corner. while holding the fn key, press and release the F4 key. This will toggle the laptop between its multiple display capabilities.
Press and holfn - press and release F4 until you get an image on the big screen.
Enjoy :)
Dec 22, 2008 | HP Pavilion dv7-1130us laptop
Maxdata keyboard suddenly does not work after two years.  Only the touch pad works
sounds like your keyboard connector has come loose, these eyboard units are actually a seperate keyboard and mouse pad built into one unit, so the mouse's electronics are seperate,
you may also want to check the connector to see if there are any broken/bent pins in the connector (sometimes happens, when accidently unplugged)
hope this helps :)
Oct 06, 2008 | Maxdata iStarUSA TC-A100B 1U IPC Keyboard...
My Toshiba labtop's touchpad and keyboard won't work
oooh..frozen...eagle338 must have been in the cooler, eh?
only way to connect with him/her is to add them as a buddy, then do an 'ask buddy' request..
Mar 07, 2008 | Toshiba Satellite A205-S4607 Notebook PC
Computers & Internet Logo
David Payne
David Payne
