Question about Panasonic KX-T7630 Corded Phone
I have two issues with my voicemail First the message button on the phone seems to be linked to the wrong extension all of a sudden and does not access my vm. So I now hit intercom 165 then my password which takes me into a vm and tells me i have no new voicemails, however my light is on identifying that i have a message all the time. please help! thank you
  • Panasonic Master
  • 2,460 Answers
Actually you have only one issue, the second is that you've posted this under a 7630 phone. If you really have a 76xx phone, press MESSAGE and look at the display. (don't pick up the handset).
Not only will it tell you where the message came from, it will let you CLEAR or ERASE the message by pressing the 3rd soft key. When all messages are cleared, the red light will go out.
Carl
Posted on May 20, 2011
Voicemail button redirected to phone line
If, perhaps you mean "it rings another one of our..." Phone Extensions, then just press the illuminated red message button, go to the ringing phone (the extension number will appear on your phone if you have a display phone) and answer the call by lifting the phone off-hook, then hang it up. Now the message button on your phone will work normally. What happened was that the user of the phone that was ringing when you pressed the button had inadvertently left you a "message waiting" after they called your phone on the intercom. By pressing the message button on your phone, you returned their call, and by answering the return call, you cleared the message waiting indication on your phone. There can be more than one message waiting, so if the light is still on after you clear the first call, using the procedure above, do it again and again until each call is returned, answered and cleared.
Mar 04, 2015 | Panasonic KXDT343 Phone
As the receptionist I take calls and then transfer them to the person the caller disires to speak with. For example, if I am on a call and the person I am speaking with would like to speak with my boss, I...
A couple of things, but first. When you TRANSFER a call to your boss using the transfer button, he key to getting rid of the call is to hang up. But that's not your problem. When we install voice mail systems, we reserve 3 buttons; one for VM TRANSFER, one for 2 WAY TRANSFER, and one for VM RECORD. It's easier to link you to the OM of a TDA system than explain it, so here's the link http://www.public.carl.airpost.net/Pana/TDA/200_TDA_OM_06-121.pdf
Pdf page 170 will give you the table for setting up your 94,91 and 90 codes for the above features.
Basically, you press PROGRAM, the button, and dial, for example, 94 500 SAVE to store the VMT . You use it by pressing that button while you on the call (no hold) and either dial your boss' extension or press his DSS button. If you use the 2-way transfer, you can actually put his number under one button and carry on a 2-way conversation with the outside party. Kind of like you would do with the old 'pink slip' messages.
Carl
Mar 16, 2011 | Panasonic KX-T7630 Corded Phone
My message light is flashing even though I've cleared all messages
There might be another voicemail box associated with your extension. Hang-up the receiver and press the voicemail button. It should tell you where the voicemail is sitting. If you do not know the passcode for that voicemail, have your system admin take a look at it.
Sep 13, 2010 | Mitel 5330 IP Phone
Cannot retrieve voicemail
When you press the message button, look at the display. Is it really going to the VM extension or is it going to another phone? Othre people could have left you a message by calling you and pressing the MESSAGE buttone either on purpose, or by accident.
You can clear ALL message lights from your phone by dialing *700 plus your extension and #. Of course you can access VM by dialing the VM extension, usually 165 or 500 from the intercom.
Apr 06, 2010 | Panasonic KX-T7630 Corded Phone
My message button automatically calls another extension How do I get it back to answer my voicemail
the reason the message button is calling another extension is because that extension turned your message light on. to turn off the message light either press the msg button and have the extension answer the call or press intercom #409. You'll have to that for each message recieved til the light goes out.
Oct 13, 2009 | Toshiba DKT-2020-SD telephone
When call goes to voicemail, it says call being transfered
I understand that you would like to bypass Auto Attendant for your lines.
On extension 10 or 11
Feature 00
Left Intercom, Left Intercome
#208
Line 01
Enter your extension number
#208
Line 02
Do the same for all of the lines.
Go to your extension to program a voicemail cover button. Without it being on voicemail wont pick up
Press Feature 00
Select a button and call it Call Cover press it
Enter Feature 15
Feature 00
Press that button so the green light lights up.
Test.
Jun 18, 2009 | Lucent PARTNER18 Corded Phone
Toshiba dk 280 voicemail issue
This is usually caused by a non booting system and would require at least a reset. Most are caused by being overfilled or hard drive failure. We fix these and others but some better guides can be found here.
http://guides.idacomusa.com/
May 01, 2009 | Toshiba DKT3010SD Corded Phone
My M7310 keeps calling another internal extension, and it wont' stop.
I think an autodial button for that co-worker may be stuck, try jiggling the autodial buttons to unstick it.
Jan 20, 2018 | NorStar M7310 Corded Phone
Missing message waiting indication.
I have a jwin jt-p590 and I have no idea how to use the voicemail/answer machine it's equipped with. Is there some sort of button scheme I'm supposed to press. I threw away the manual to it. Sorry I don't have an answer for your problem, but you seem pretty witty from the answers I saw you give to other ppl. I'd really appreciate it if you could help me out.
Jul 21, 2008 | Lands Phones
T7316E Voicemail issue
Reset the voicemail password.
Do so by first presing
Function 985 (to view the mailbox number the phone is using)
Function 983
Log: 1020000 (or 120000, 10020000 1st is for 2 digit extensions 2nd is for 4 digit extensions)
Left Button (MBOX)
Right Button (CHG)
Enter Extension
Left Button (RESET)
This should reset the passwod to 0000, the steps maybe a little bit off depending on the software version installed on the phone system, but something like that will fix the problem.
Jul 04, 2008 | NorStar T7316E Corded Phone
Panasonic KX-T7630 Corded Phone Logo
181 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
