Question about Dometic Rooftop RV Air Conditioner
RV AC/HP Rooftop 15,000 btu Penguin
The a/c is cooling. It does not hum or cause lights to dim. It simply won't stay on long enough at one time to get to the set temp on the CCC. It will only stay on 10 minutes at a time, shutdown and restart 3 minutes later. The unit is clean and free of obstructions both outside and inside. Fins are not bent and the coils are not freezing. The unit does finally get the r.v. cooled to the set temp (which by the way is only set about 10 degrees below the outside highest temp of the day) late into the evening. I feel it is cooling well enough but just not staying on long enough at one time to get to the desired temp.
Does this answer your questions to my problem?
  • kamper2 Aug 16, 2008
    I think the solution that motor158 fits my situation and I will try this first. In the meantime, I will contact Dometic if that does not solve it. Thank you.
  • Dometic Master
  • 6,674 Answers
Is there by any chance a cool air duct or register, or maybe return air duct near the thermostat, or perhaps on opposite wall,(behind it) that may be throwing it off? Have you tried just draping a small towel or facecloth over it to see if that changes anything? I've had one that acted similar in a 12 wide, and it turned out to be that the return air was directly behind it, and caused cool air to rush in around hole for wiring of thermostat, causing it to kick in & out about every 5 minutes. Heard a whistle when I was checking thermostat, and a light went on in my head. Plugged the hole up good & all was well. have you tried this number & link to contact tech assitance at dometic for some advice on it? Phone 1-800-544-4881 and ask for technical assistance. CustomerSupportCenter@DometicUSA.com <CustomerSupportCenter@DometicUSA.com>
Posted on Aug 15, 2008
I have a parc model..36 foots, my ac is not cooling enought.i wont to kow i much btu is my ac..mod:59516-531. tank you
15,000 btu. Has it been cleaned well recently? Quite often that is all that is required. Has it never cooled sufficiently?
Aug 30, 2011 | Dometic Rooftop RV Air Conditioner
My air conditioner keeps icing up and the flow is then reduced and cooling is diminished. I was recently in a very hot area and the AC was working very hard. I'm in a more reosonable temperature now but...
Check the filters and make sure the coils are clean first. Then make sure both fans are running, the evaporator fan and condenser fan. If all of that is ok then you need to get the refrigerant charge checked.
Jul 23, 2010 | Dometic Rooftop RV Air Conditioner
Is this model number a 13,000 or 15,000? and whats the difference
Hi, I don't see a model number? I can tell you that for each ton of cooling, you will have 12,000 btu's. So, at 13,000 and 15,000 btu's of cooling, they both are just a little over 1 ton of cooling. Tons are a measurement of btus in a/c and heating applications. Give me the exact model number itself, and I can tell you the tonnage.
Thanks,
Shastalaker7
Jun 05, 2010 | Dometic Rooftop RV Air Conditioner
Rooftop RV Air Conditioner: my duotherm rv ac rooftop 15,000 btu the free...
If it's the pencil type, it just pokes into the fins (carefully)
If you look real close with flashlight you should be able to see where it poked in before, usually a couple of inches up from bottom. If it's the little round disc, it snaps in down in bottom corner, there should be a small hole for it in the frame.
May 17, 2010 | Dometic Rooftop RV Air Conditioner
I have a 13500 btu ac dometic penguin model on pan that is old and would like to replace with 15000 btu ac of any other manufacturer or another dometic what are my options ..I do not have ducts and do not...
Your choices are another Dometic or a Coleman
I prefer the Coleman But the amount of extra cooling you will get by stepping up to a 15K unit will probability not be worth the added cost
Mar 11, 2010 | Dometic Rooftop RV Air Conditioner
A/C starts, goes immediately to heat
Unfortunately, your rear unit is calling for heat. If you put the rear unit on heat pump mode, does it then cool?
moz-screenshot-2.jpgmoz-screenshot-3.jpgThe reversing valve is energized in the cool mode of these AC's. So there is no real way to bypass it. I would check the thermostat and the control board in the unit to make sure that the switches are set correctly.
In the service manual section of the dometic/Rooftop RV Air Conditioner section. I have posted service manuals for the Heat Pump and the Comfort Control.
Hope this helps,
Jeff
Rate me please.
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
I need a penguin 15,000 AC mod#620426.321
if it isn't destroyed you could have it brazed and charged,if it is bad try ebay,i have good luck there with hard to find parts
Jan 08, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
222 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
