Question about Microwave Ovens
Induction AEG hob (98030KF-SN / HK953400FB) error E8
2 Suggested Answers
  • 72 Answers
SOURCE: Got an error E8, on
Follow the below mentioned steps :
1.
Remove the outside case of your printer.
2.
The Printer Body on the Base
Once the case is off, you're looking at the guts of the printer sitting in the tray-like base. To get at the blotters and waste ink, you'll need to get under the printer body, which is held to the base by three or four screws. The older your printer is, the easier it will be to find the screws that hold the body to the base, and the more working room you'll have. If you have a good magnetic screwdriver, that will be very helpful. It may also be helpful to take notes and/or pictures of where the screws are located to make re-assembly easier.
3.
One of the Rear Corner Screws
Use your flashlight or lamp to illuminate the rear corners of the printer base. You should see a small screw on each side with an access for your screwdriver to it - remove each of these screws, and the body of the printer should be freed-up from the rear of the case. Now look for one, or usually, two more small screws on each side of the case bottom toward the front. With the removal of these screws, the printer body should be able to be raised at the rear and lifted backward out of the case. Some models have a hidden screw or two, which might even require the removal of the power supply, or the movement of wire assemblies to get at the screw. But there always will be a way.
4.
Put on a pair of latex gloves. With the printer body removed from the case, and set aside on some newspaper (it may/will be very "inky" on the bottom!), you are now looking at the blotters which have received the excess ink - see the top pic. Again, it's a good idea to take notes or pictures to indicate the location of the blotters. There are usually several large and small ones. Remove them to plenty of newspaper and take them to a utility sink, idealy in your garage or the utility room (I use our kitchen stainless steel sink, but my wife is very gracious and I'm VERY careful!).
5.
The cleaning of the blotters will take huge amounts of running water! Hold the blotter under a stream of running water as it flushes the waste ink out. This will take a long time - maybe 10-15 minutes for each one. No, you will never get them white again, but your goal is to remove enough of the waste ink that eventually, the wash water is just slightly inky and the blotters are grey. You may gently squeeze them as you wash them, but this may damage the blotters, so go gently. When you decide they've had enough cleaning, let them swell with warm water until nice and plump, and do not squeeze this water out. Put them outside in the full sun on some thick newspaper to fully dry - occasionally turning them over. If it's raining in your area, you may choose to do the drying in your oven - use only the oven light, which should push the temp to near/over 100 degrees, and lots of newspaper.
6.
While the blotters dry, take the printer tray/base to the sink and give it a good cleaning. Make up a Clorox/water solution to help remove ink stains from the base and the outside of the case too. When the blotters have dried - two days is not unusual - you're ready to begin the re-assembly of the printer. Use your notes/pictures if you've been smart enough to have them. Replace the blotters. The printer body will slip into the bottom of the case from the back toward the front. Replace the screws. Remember to re-route any wiring, and to reconnect plug-ins. It's a good idea to power it up before you put the case back on, just to make sure all is well. Replace the case, and power it up.
7.
If you're lucky, you will no longer see the flashing error code lights (they are different on many models, but usually on the Pixmas, you'll see a sequence of 8 orange flashes followed by one green). If you are still seeing this error code flashing, you'll need to reset the printer's internal setting - to do that, see the last link in the Resources below titled, "How to Fix the Dreaded Waste Tank Filled Error Message for Your Canon Printer". And if you continue to have issues, Please reply back for assistance.
Posted on Apr 17, 2011
Aeg glass induction hob error code ER 21
reset the microwave. Disconnect the power cord, by 1minutes, and try again,the microcontroller is confuse.
If the problem persist you can be problem with the main controller board, repllace, but read your owner manual section troubleshooting for identi the error. download from www.retrevo.com
God bless you
Oct 27, 2013 | Microwave Ovens
Code e on only two of the right hand zones on siemens induction hob
Hello.
These codes mean that the oven's electronic control hasdetected a condition it needs to check which mean error. When you see a code,follow these steps to solve the problem:
  • Press "Stop/Clear" to clear the display and stop the beeping.
  • Reprogram the oven.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes before turning it back on.
Thanks.
Sep 07, 2011 | Microwave Ovens
I have an prestige induction cook top model PIC 3.0 the problem is that it displays an E7 error whenever switched on after appx. 1 minute and the food is not boiled /cooked. please let me know what is the...
Dear Sir i have an prestige induction cook top model PIC 3.0 the problem is that it displays an E7 error whenever switched on after appx. 1 minute and the food is not boiled /cooked. please let me know what is the problem How Can Solved this Problem This prestige induction cook top model PIC 3.0 Only one week so please do need full
thx... Kundan singh Rana Baddi (H.P.) 09857455945 ranansd@gmail.com
Mar 23, 2011 | Microwave Ovens
The induction cooker when put on it shows E6 after about a minute or so and no heating takes place.
There is a error message there, it indicate a problem with your induction cooker. It cause a defective winding wire or circuit controllers your know induction cooker works similar to the principle of electro magnet induction, it give heat to metal cooking pot. I hope I give you a idea regarding what happen to your unit.
Pigeon Induction Error E6 occurs
E6 stands for 'Internal Electronic Temperature is higher than normal for 3 seconds', contact service centre.Source: Prestige Induction Error Codes
Feb 16, 2011 | Microwave Ovens
Error message E8 is shown in the clock display
Error Code: E8 Cause: Control Board Example: Remains in display; oven unusable Corrective Action: Replace control board
Apr 12, 2010 | Bosch HMT8625GB Microwave Oven
My AEG Micromat_Combi microwave has started coming up with an E14 error message, have you any ideas please.
The motor opening some air valve is probably stuck. See "AEG “micromat_combi 635” halts with error E14. What to do?" at http://appliancewiz.com/questions/47/aeg-micromatcombi-635-halts-with-error-e14-what-to-do for some images and instructions.
Oct 31, 2008 | AEG Microwave Ovens
Microwave Ovens Logo
258 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
