Question about Kenmore Washing Machines
I have a Kenmore elite washer HE3t model# 110 49972 600. I keep getting code F42. Do you know what that is?
  • 6 Answers
SOURCE: kenmore elite HE3t
Unplug your machine, remove the top panel, doublecheck all of the wires are securely connected. Sometimes the wires are loosened due to the vibration of the washer. Hope this works for you! It worked for our Kenmore Elite H3 when no cycles would start and flashed the error code "dL/F" (door lock failure).
Posted on Jan 02, 2008
Jimster
  • 240 Answers
SOURCE: What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
Posted on Jun 01, 2008
  • 326 Answers
SOURCE: keep getting f2 signal on
F2 and F02 error are one and the same. My daughter was doing a load of towels in my Kenmore Elite HE3t front loading machine, when I went back to put them in the dryer the washer had a load of water in it and an error reading of F02. Checked the manual Could not find anything wrong with the Drain Hose?
These are the possibilities for that error code at one web site:
Press PAUSE/CANCEL twice to clear the display.* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
F02 is long drain.
Just because it came up doesn't mean there's a problem, it simply means there was a failure during the cycle, if it returns on a regular basis, you have a problem.
F02 error could be caused by the over use of soap, you need to make sure your using 2 tablespoons of HE soap, 1/4 cap at the most.
Over sudsing, could cause the water pump to run longer, the pump is designed for 15 min duty cycle which means, 15 minutes on to 45 minutes off. The computer may sense too much soap, and continue to pump. HE soap will cure that, along with SUD error, possible F09 (overflow condition), you may also notice the timing is wrong, HE soap works well in these machines and F/l washer go hand in hand
if the F02 returns the remove the 3 torx screws from the bottom kick panel, and remove the kick panel, right there in the middle you will see a big round handle, turn it and then slide it out, have some towels ready, there will be some water in there, and check to see if you have any thing in there that will slow water flow, tooth picks and other "floating" items may jam the impeller.
Posted on May 06, 2009
SOURCE: Kenmore Elite Washing machine error codes
I am getting F35 error code. What is the problem?
Posted on Jul 19, 2009
I am getting an F35 code on the washer has anyone had this problem
Posted on Aug 06, 2009
Kenmore elite he3t where is the lint trap?
Raise up your washer slightly or feel for 3 screws right under the front, bottom. Unscrew these and pull down - you will find the lint trap. Be prepared for water, and since the model is 2002 - immense junk too!
Pl say so if helped!!
Apr 01, 2013 | Kenmore Washing Machines
Kenmore Elite HE3T model 110 44932 200 I'm getting an F02 error code during the rinse cycle. I've lost my manual - pls advise thx
Clean Out your Water pump filter if that is not dirty replace the water pump. f02 is Code for LD Long Drain something is clogging your water drain in the washer or your kids rock or pen got stuck and chewed up the blades on the water pump
Jun 06, 2010 | Kenmore 44932 Front Load Washer
Kenmore Elite HE3 (not HE3t) F11/dL error code
The part number for the CCU under the model number you have listed is 8182687. There is also a refurbished version of the CCU you can purchase for less (part #8182237R).
Replacement parts can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need. The CCU will be listed as item 15 (15A for a refurbished version) under the "Control Panel Parts" section.
If you have any questions, please post back and let me know. I hope this helps you.
NOTE: The cheapest site I found the CCU listed (NEW) was pcappliancerepair.com. The cheapest (REFURBISHED) is searspartsdirect.com.
Mar 02, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I am thinking about buying a 2003 kenmore elite washer and dryer for $500. they are a HE3t. are there any problems I should be aware of with this year and model.
No unusual problems. Keep it maintained properly - and you have a great washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 15, 2009 | Kenmore Elite 45986 Front Load Washer
Nov 23, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t Model#11044932200
How long is long? I have to hold the button down for about 5 seconds and I think that is to keep from accidentally turning the machine on . If it is longer than 5 seconds then maybe something IS wrong.
Sep 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t model 42922
After the complete wash cycle is finished, the clothes are still soaking wet sometimes. This is not an every load problem.
Aug 12, 2008 | Kenmore 46462 Front Load Washer
Washing Machines Logo
133 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
