When I turn on my pc all i get are the led lights on my tower...
I have this motherboard: asrock775vm800 and when I push the power button to turn it on all the led lights come on like its booting but other than that i get nothing...help me please...
    Master:
  • 763 Answers
If you have the manual see the led instructions to what or where your going to insert the led wires from the case to the motherboard led slots. maybe you put it on the wrong slot. hope that helps!
CHARCOIS
Posted on Aug 15, 2008
I have an Asus M4A89TD Pro/USB3 Motherboard that I'm using to build a new PC. After I finished assembling the tower I turned it on and began setting my BIOS. I only set the date and time when my whole...
I would re-seat the power connector from the power supply to the motherboard. If you are able to test the power supply output, that would be helpful as well. The problem as you describe it points towards the power supply failing.
Apr 01, 2017 | ASUS Computers & Internet
There is a green blinking LED on my motherboard, and my computer is not turning on. What is wrong? Someone told me to ... Hi, i have a dell Optiplex 780 running windows xp, the computer button is just...
If you are referring to the green light on the system tower and is blinking the problem could be the system is in stand by mode.
Turn off the computer by pressing on the power button on the system tower for 10 seconds.
Disconnect the black power cord at the back of the system tower and then again press the power button on the tower for 10 seconds. There would be no activity on the tower when you do this.
Reconnect the power cord and then power on the computer to see if the issue is resolved.
Thanks for using Fixya
Proton
Aug 30, 2010 | Dell XPS 200 PC Desktop
HP a1050y....Push the button to turn it on, and
You might have a bad power supply, or something might have loosened inside the case. sometimes if the memory or processor get jarred , they might need to be reseated. unplug all the cables from the back of the tower, only leave the power cord in then try to power up. Sounds like it might be power supply or Maybee the motherboard. Have a computer tech check all the inside connections. Good luck..
Mar 31, 2010 | HP Pavilion A1050y (PU131AV) PC Desktop
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
My vostro 200 slim tower wont turn on PLZ READ FULL
There could be a hardware problem on the computer if the power button led light is "Orange/ or amber", if you can open the computer, try removing one memory card at a time and see if the power button will change.
Dec 15, 2009 | Dell Vostro 200 Mini Tower With 20" Flat...
WHEN I PRESS POWER BUTTON NOTHING HAPPENS
Disconnect the Power cable / A/c adapter/Battery from computer.
Disconnect External peripherials.
Hold down the power button on the computer for 10 seconds.
Reconnect the power cable or A/c adapter and battery or the computer
Try to turn on the computer
check for Led's on the computer
If still no display ,shut down the computer,disconnect power cable.
Open the computer tower,remove memory modules,reconnect power cable and turn on the computer.If you get a beeping sound after turning on you should be getting beeping sound suggesting the mother board is not bad.Turn on the computer and disconnect power cable from computer.
Reseat 1 memory at a time if you have 2 memory module or if single memory module reseat in different memory slot,swap memory module.
Reconnect the power cable and turn on the computer if it boots to desktop possible issue with 1 of the memory module.
Disconnect the harddrive ide cable from the harddrive .Turn on the computer.
If still unable to power on .Shutdown the computer and disconnect power cable.Remove video card,sound card ,modem card if any .Connect just the vga cable from monitor to the integrated video port.
Connect power cable and turn on the computer.
If computer turns on possible issue with one of PCI or PCI express card.
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard. GOOD Luck.!!
Aug 27, 2009 | Insignia D400a PC Desktop
There is no toggle/powerbutton on the face of the tower
If this is atx power it should be just push to on button look for something that can be depress. On motherboard connection follow motherboard manual. It should be on a header. Together with the reset, power led light, hd LED and the power itself.
Apr 18, 2009 | Computers & Internet
Computer will not turn on
May sound strange, but is the power supply switch in the correct position?
If the button is pressed, makes your continuity test, and not even the fans come on, check that the switch jumper has not come loose from the motherboard, and finally, if the motherboard is plugged in and no fan comes on when you push the power button, there may be chipset damage from an electrical surge or overheating.
In this case, a new mobo is your only option.
Jan 20, 2009 | Dell Dimension 4600 PC Desktop
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
