I have a RCA VCR mod VR520 made by Thompson. While playing a tape every 10 seconds the picture fades to blue screen then comes back. Sound O.K. all the time. Can you suggest a solution. Thanks. Dale
  • dianne42 May 24, 2011
    Thanks for your prompt reply - much appreciated and will give this a try.
    Dale
    Dale
  • 6,771 Answers
The problem is in the rf amplifier a silver box located behind the video head, you will see a ribbon wire go from the heads to the rf section. Remove the ribbon cable and rf module, "1 or 2 screws" next remove the shielding to expose the board, now if you are handy with a soldering iron retouch the solder joints in hopes this will fix the problem, if this fails! cheaper to replace vcr. It would not be cost effective to get a professional involved.
Posted on May 20, 2011
VCR will play, but won't record
Your VCR has to be on the same channel as the switch on the back of you cable box.
Mar 05, 2009 | RCA VR557 VHS VCR
Movie tapes have snow but not home video tapes can i fix it my self
I assume you have had this player a while and I assume that all the programs that work without snow are ones that you recorded using that VCR to do it. Right?
If so, it is a compatibility issue where the last time you had it fixed, the repair guy did not check for VCR to VCR compatibility. I had a shop for 15 years and this is common.
Do you have a Tracking control? try adjusting that. It is either a physical control or part of the menu, depending on that specific model.
Last...last is to open the unit and you must be very very careful. Put in a tape that is from another player that plays snow and identify the shinny rotating head if you can physically see it. It sits at an angle and the RCA is typically in the back middle, about an inch in a half in diameter. While playing press your finger very very lightly in the middle of the shinny exposed video tape for like 4-10 seconds and maybe the snow will go away.
Your video head may be worn or dirty. Do not attempt to clean the heads the are verrrry delicate.
3. Try finding an old VCR cleaning tape. It does the same thing as your finger.
E
Mar 01, 2009 | RCA VR349 VHS VCR
VCR Issue with Toshiba SD-V295KU
This may be a bit late but I just ran across these posts. All these problems can be caused by bad tapes. Commercially-made tapes will usually play properly. But home recorded tapes, or very worn tapes, may not play back properly in every VCR. If the VCR isn't getting the right information off the tape for proper playback, it's muting the sound and the screen so you don't see any snow. It's also possible that the VCR heads already need a cleaning. It takes just one worn-out or defective tape to clog up the heads and cause the "no picture" problem, although in this case sound isn't usually affected.
Dec 21, 2008 | Toshiba SD-V295
27" Zenith Television
Assuming the picture tube lights up and you have snow when selecting the tuner function, I would first hook up a working VCR with a good tape and play it while the set is on channel 3 (if that is what your VCR is set to). If no sound or picture is displayed while the tape is playing,it could indicate a defective tuner. If you don't even get snow with no antenna connected (unless your set is designed to go to a blue screen with no signal present) then you could have a problem in the video processing circuits which would explain no picture with the RCA connections as well. This would probably make the set beyone economical repair.
Sep 15, 2008 | Zenith C27A24T 27" TV
Philips DVP 3150V
saida horizontal com deficiencia faz com que a fonte aciona circuito de proteção.
Feb 09, 2008 | Philips CCB092AT 9 in. TV/VCR Combo
Sound but no picture
chances are the scart lead has come out slightly at either end, give both ends a wriggle while on play
Oct 05, 2007 | Philips VR550 VHS VCR
Portable Grundig TV/vcr combo - screen goes blue and then set switches off.
Hi mcloud Your problem is your video circuit.the component could be faulty or it has lose solder.have a tech look on your set for repairs.good luck.
Apr 25, 2007 | Grundig GF70-600 TV
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
