Question about LG LS-K1830CL Cool Mini Split Air Conditioner
What type of refrigerant is the LG 9000btu/h 1hp,12000btu/h 1.5hp and 18000btu/h 2hp....
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: the best pressure of gas in a split ac in
Should be around 70 psi on the low suction side if R22 is being used.
Suggest you read up on Superheat and Subcooling.
Posted on Jun 05, 2010
  • 4 Answers
65 psi is the ideal pressure remember its not exceede from this pressure.
and it is valid for all season
Posted on Jun 09, 2013
What happen with a wrong connection on a single phase 2hp sp motor
I'm not sure which motor you have - the heading shows a 1HP type - yet you talk about a 2HP type. Anyway, the label on the motor should have a wiring diagram. You must have a label on the motor to know how to wire. It may have two diagrams - one designated as "high voltage" and the other "low voltage". Check the label for voltage.. it likely says "120/240 volts". The 120 uses the low volts diagram and the 240 uses the high volt diagram. If the motor has terminals L1 and L2, these will most likely be the point of connection for power - regardless if it 120 or 240, unless the label states otherwise. Unless the neutral connection is specified on the label, it does not matter which L1 or L2 you connect it to.
The other terminals will be required to be connected properly. Motors use these connections or jumpers to set options such as voltage, direction of rotation, speed(s), etc. An incorrect setting here can cause unexpected results as far as speed and rotation, or catastrophic results if you supply this motor with 240 volts but set the jumper for 120 volts.
Here's a link to their catalog with telephone numbers for you to review.
Apr 26, 2012 | A O Smith Motors A O Smith 1hp 115/230v Ur...
Will a smith 1hp pump fit in place of a hayward 1hp
as long as the frame size matches i.e. 56J in this case then you should have NO issue with changing the motor mfg.
US Parts Center
Aug 18, 2011 | Hayward 2HP Pool Pump Motor A O Smith...
Hi i need to know what size window air con for a room 30sq meters cooling onjy and what model
Hello there.. :) your room 30 sq. meters needs 2 - 2hp window type aircon as computed. But you can consider the purpose of putting up the aircon and how many occupants will stay.. :0
For the model:
NATIONAL, 2HP, Model CW-1808VPH 2HP LG Window Type Aircon Manual 2HP Koppel Aircon w/ remote model: KWR-18R1
or check the internet for other models that you want.. :)
Feb 03, 2011 | Heating & Cooling
Hello , I have a 5yr old pool complete with Hayward Filter and a 1hp pool filter motor and 2 hp spa air injection motor connected to an air switch the in ground pool is 32K gallons. Problem is with spa air...
ALWAYS FREE.. SO IT SEEMS THAT YOUR NOT GETTING AIR, THESE BLOWERS HAVE FOAM IN THEM AND CAN ,AFTER A FEW YEARS GET CRISPY AND BREAK UP AND PLUG THE AIR PUMPS SUCTION PORT. THE FOAM IS USED AS A AIR FILTER AND A NOISE REDUCER , WHEN THESE BLOWERS GO BAD 90% OF THEM CAN'T BE REPAIRED ! = JUNK.. TO SEE IF YOU HAVE A RESTRICTION IN YOUR LINE OR LINES ,USE A SHOP VAC TO **** AND BLOW THE LINES IN AND OUT.. THESE BLOWERS ARE HELD IN USUALLY WITH ONE SCREW AND ARE EASY TO REPLACE ONE MORE CHECK 4 YA IS, THERE MIGHT BE A CHECK VALVE INLINE ON THE BLOWER , IT MAY BE BAD . BEST WAY TO CHECK IS TURN THE BLOWER ON FIRST , THEN TURN THE WATER PUMP ON.. HEY IF'N I WAS OF HELP GIVE ME A REVIEW OR A THUMB.. JAY YOUR LOCAL POOL PUMP WHISPERER IN FLORIDA
Nov 15, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
The best pressure of gas in a split ac in
Jun 05, 2010 | LG LSC121PMA Split System Air Conditioner
Replaced 1hp semi hermedic condenseing uint with 2hp hermedic uint can only d=get 40 degreese of temp. can you help
did you vacuum the sealed system down correctly and fully? if not you could still have moisture in the system and this will affect cooling
Jan 25, 2010 | Refrigerators
We have AC LG Zet cool 1pk, with size room 5x6x3, the problems is we doesn't have cool on the room, but ac is good condition with standard free on. pleas e help me to solve this problem. thanks. RS. Urip...
Depending on the type of building and insulation. For building with good insulation and not many windows, you could manage with a 18000BTU, but if your insulation not so good, you should need 24 to 26000btu unit.
Mar 16, 2009 | LG Heating & Cooling
Motor will not turn over all the time.
is it new or used, does it have oil??hydraulic lock up??compressor dump valve bad,dirty
Jan 14, 2009 | Hitachi EC12 Portable Electric 2hp Air...
LG LS-K1830CL Cool Mini Split Air Conditioner Logo
157 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
