My computer keeps saying to reboot wireless adapter, it keeps loseing internet connection
  • Anonymous Mar 23, 2014
    I keep losing internet connection I am wireless so is there a problem with the screw on dongle
  • 3,051 Answers
I think you need to get your adapter closer to the signal
Posted on Aug 14, 2008
Im having problems connecting to my wireless network. Its keeps identifying. when I troubleshoot it say my network adapter has a problem
Reboot computer, with out adapter, connected or turn on, after rebooting then connect to PC and it should recognize it then.
Jun 06, 2011 | Sony VAIO PCWA-C150S 802.11b Wireless...
Tip
Tips to Fix Unreliable Wireless Connections
In general, wireless computer connections are reliable. But nothing is perfect and sometimes you lose your connection or experience a weak signal. There are several factors affecting the reliability of your wireless connection.For example, if your wireless adapter is too close to 2.4 GHz cordless phone, you may experience a decrease in the computer's wireless single strength. Why? Because the phone and computer are on the same frequency and can interfere with each other performances.
Handy Repair Checklist for Wireless Interruptions
First check to see if your cable or DSL is absolutely working. Usually amid in your basement, best modems accept four lights. You accept a alive Internet connection if the "data" or "status" ablaze is on. If it's off, or flashing, your cable is out.
If your cable/DSL is working, afresh reboot your computer. Sometimes, if your cable/DSL goes out for alike 10 seconds, your computer and the wireless router may no best be able to allocution to anniversary other. By rebooting your computer, a new IP address is assigned, acceptance them to already new communicate.
If your desktop is wireless and you've confused the wireless adapter,again you may charge to move the adapter until you acquisition a stronger signal.
on Jan 13, 2011 | Computers & Internet
My Cisco Valet M10 loses connection to the internet and my computer also says ip address conflict. Any ideas on how to keep this from happening? I end up having to do a full reboot every hour because I...
try to update the Firmware of the router. You can do this by opening the Cisco Connect Software under all programs. It should ask for an update when it initializes, if not then power cycle your network.
Jan 07, 2011 | Cisco Valet Wireless Hotspot (M10)
Abit wireless adapter unable to locate wireless network
well!! I have an answer for you.your comp is loosing the IP address.connect your computer through cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Abit (WLP-01) Wireless Adapter
Why do i keep losing my wireless internet connection?
try to have a reformat again or change the settings of your router or try to reinstall the wireless adapter that you have
May 20, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Truemobile 1300 w/l usb adapter problem
hi..
if i understand your issue your computer connected to the internet using the wireless adapter but get disconnected after rebooting...right?
did u try updating the software for the wireless card..
here is the link trying updating the drivers for the wireless usb adapter..
here is the link for the download--
http://www.softwaredriverdownload.com/download.php?file=2nxZnRwOi8vZnRwLnVzLmRlbGwuY29tL25ldHdvcmsvUjE0MzM1NS5FWEU%3D..
good luck........
vedhick
Feb 03, 2009 | Dell TrueMobile 1300 802.11g/b Wireless...
Losing wireless connection after logging off
Log off? Not turn off?
Does the wireless work after you reboot?
If you log off but keep the computer powered it may be a power management issue.
Some network adapters have a setting to allow windows to turn them off to save power.
Go to the Device Manager, right click on the wireless adapter and select Properties.
Is there a Power Management tab? If so, click on it and remove the check mark from "Allow the computer to turn off this device to save power".
Sep 27, 2008 | Belkin (F5D5231-4) Router
I installed netgear adapter WG111v3 and I keep losing internet connection
I had the same problem and when checking the properties of the adapter under device Manager.
I found the under the Power Management Tab the option to
"Allow the computer to turn off this device to save power" was turned on.
Remove the check mark from this option and click OK.
Oct 29, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
