Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Need a printhead
I need a partnumber and price for a c2424 printhead, can you help me out?
    President:
  • 2,072 Answers
Off hand I dont know the part number any longer.
Price from Xerox would be $750.
Look up on Google a business called "the parts drop".
Call and ask for Britt see if he has one, he would be a lot cheaper
Posted on Aug 15, 2008
SOURCE:
System error # 07,010.43:27456 on a xerox c2424 copier
The printhead is stuck in the tilt position, need to replace the process motor camshaft kit, part number WCC2424-Z2
http://www.iteminconline.com/wcc2424-z2_wcc2424-z2-xerox-workcentre-c2424-process-motor-camshaft-kit.htm
Jul 07, 2015 | Xerox Office Equipment & Supplies
Xerox c2424 37,002,47:280890
The 37,002 error code is for a defective heater in the printhead 650-4354-00. There is no reset or workaround for this error.
Unfortunately, the part is fairly expensive, but the C2424 is such a workhorse, you may want to repair it.
Whit Item, Inc.
Dec 06, 2010 | Xerox C2424 Copier
C2424: error code 19,993.48:88868
This error is a Printhead error, but in this case is usually more probable to be caused by the Electronics Module.
The Printhead part number is 650-4354-00
The Electronics Module is 119-6427-03
I suspect the actual error code was 19,003.48
Whit
Item, Inc.
Oct 03, 2010 | Xerox C2424 Copier
The wiper blade is stuck to the print head of my xerox c2424 printer. how do you take the ink cartridge tray out to get to the print head. i have it torn down that far...bonnie
The printhead and wiper could be heated to soften the ink.
Enter Diagnostics by holding the back arrow and "i" button while powering up. Go to the Monitor menu and turn on "All Heaters"
After a few minutes, it should be able to be moved away.
This situation may have broken 2 Camshafts and perhaps even motors. If you continue to get an error 07,010 then buy this kit "C2424-Z2" It may require a technician to install.
Whit
Item, Inc.
Oct 01, 2010 | Xerox C2424 Copier
The process motor has stalled while moving the Printhead.
You need to check the wiring to the printhead for proper routing.
Then, remove the printhead and check for ink spills in the tilt and drive gears.
Then, check the gears in the Process gear drive train are correctly aligned, in the coerrect home position, and not damaged.
You might need to replace the Process gearbox.
May 25, 2010 | Xerox C2424 Copier
Getting a printhead error #935 message on lcd panel. Also, feed wheels (2) for 4049 duplexer need replacing. Any ideas?
Printhead error 935 means you have a defective printhead witch needs to be replaced. Partnumber 1381635. It is not a cheep part.
Nov 11, 2009 | Office Equipment & Supplies
Xerox c2424 error code
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
Jun 20, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
MAINT. KIT
Here is what you need. Its is easily replaced through the maintenance drawer on the right side of the printer Part # spacer.gif Description spacer.gif Capacity2 spacer.gif Price spacer.gif spacer.gif spacer.gif 108R00656 spacer.gif Standard-Capacity Maintenance Kit, Work Centre C2424 spacer.gif Up to 10,000 pages spacer.gif $99.99 spacer.gif spacer.gif spacer.gif 108R00657 spacer.gif Extended-Capacity Maintenance Kit, WorkCentre C2424 spacer.gif Up to 30,000 pages spacer.gif $149.99
Oct 30, 2007 | Xerox C2424 Copier
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
62 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
