Question about EA Sports MVP Baseball 2005 for Windows
MVP 2003 I have vista... I downloaded all updates and tried running in all compatability modes and as admin but every time i try to run EA MVP 2003 it says "MVP 2003 requires direct x 8.1 and graphics hardware acceleration" I checked and I have direct x 10 installed and have also installed 9 and 8.1 just in case and also checked and my graphics card driver is updated and capable of 3d hardware acceleration. it is also enabled. I ran a progrma on the MVP disc and it says all checks out except that it thinks I am running Windows NT what do I do?
  • Anonymous Aug 23, 2008
    Tryed the solution and it did not make any difference. I talked to EA Tech support and they said they think it is just not compatible with Vista. Perhaps there is a download out there that could trick the game into thinking i am running XP anyway still same problem with no solutions that work.
  • JonCasey Aug 23, 2008
    Tried all the suggestion and still have the same problem. I talked to EA tech and he said that they think MVP 2003 is simply not compatible with Vista. Maybe there is a program out there that will trick the game into thinking I have XP. Anyway still the same problem as before.
  • 83 Answers
You Need GameXp
For Speed Your Pc & For Speed Your Games
and ATF Cleaner FOr Clean Your Pc
And Here Is Direct X 7.0
--> Download Link (Direct X 7.0) <--
MVP 2003 - 9148c3a.jpg --> Download Link (game xp) <--
--> Download Link (Atf Cleaner) <--
Posted on Aug 22, 2008
I have downloaded the demo of cash register express but when i double click on it it will just say not responding it will not even open i have tried shutting the computer down and putting it back on and it...
U can try opening it in another compatibility mode.
Right click the icon > Compatibility > ""Run this program in compatibility mode for.."
Choose From Windows XP to Windows Vista!
May 30, 2011 | Computers & Internet
When i install scan cm1312 on my PC ruuning win 7 i get an Error saying Extanal Error
Are you installing the driver from the CD?
Try downloadingg the driver from their site.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3558902&prodNameId=3562006&swEnvOID=2100&swLang=8&mode=2&taskId=135&swItem=ma-61238-3
1. Download the file: 1312series_full_solution_v5.0_AM-EMEA.exe (306 MB)
2 Use the full download from the website and it self extracts to your root directory.To run the self extracting file, first set the compatibility mode to Vista sp2 and run as admin.
3) The files remain and you can find them here:
C:\HP_CM1312_series_full_solution_v5.0_AM-EMEA\
4) Set the compatibility mode to Vista sp2 and run as admin on the Setup.exe.
5) Run the full install. Works for both usb or network.
Regards,
Mar 18, 2011 | Computers & Internet
Photo explotion will not launch after the first time i use it. i have to uninstall and reinstall it to use it again :{ it work fine with windows vista but i now have window 7.
Welcome to Fixya. Have you tried running the software in Compatibility Mode? Depending on your version of Windows 7, you may have the ability to run it in Compatibility Mode. Try right-clicking on the Photo Explosion shortcut that is on your Desktop. Then, go to Properties from the pop-up menu. Then, select the Compatibility tab. On that tab, put a check next to "Run the program in compatibility mode for:". Then, select Windows XP SP2. Click on the OK button to save this setting. Finally, try launching the program again.
If you have questions please let me know. Thanks for using Fixya.
Mar 13, 2011 | Nova Development Photo Explosion Deluxe...
I have windows vista. I am trying to install ansys 11 on my laptop but the installation never starts. It stops on the page with install shield wizard. I downloaded a newer install shield version based on...
make sure that the install runs under administratives privileges, when executing an app that requieres admin rights the UAC will prompt to run the app under elevated rights, also you could try the following:
right click over the app installer
click on properties
go to the tab compatibility
check mark the box for ( run this program in compatibility mode for)
select windows XP SP3
also check the box that says ( Run this program as Administrator )
click apply and then ok
try to run the application now.
some apps won't run in vista unless a compatibility mode is set, but if this doesn't work you may want to try looking for a installer compatible with vista.
Mar 01, 2011 | Computers & Internet
Cant install my pinnacl 110i on windows 7. Any one had success with that? It was working perfectly well with Vista. But I'm a ****** for pain! :D
Download updated VISTA drivers from here: http://cdn.pinnaclesys.com/SupportFiles/PCTV%20Drivers/ReadmePCTV.htm
If the driver have an installer try to install from it.
If not success try to run the installer in compatibility mode (right click - properties - compatibility tab - run in compatibility mode with WINDOWS VISTA)
If all of those steps faill try to MANUALLY install the driver:
Go to device manager, select your device, right click on it and select update controller software - try to find it in Windows Update (online)
If not driver available online try again, but select the "find on my computer" option, and select a folder containing the drivers.
An excellent website to find drivers and solutions is: http://www.driverguide.com
Aug 26, 2009 | Televison & Video
Software not compatible with Vista
Try running in compatibility mode for the program. Go to the program thru Start menu, then right-click. There you will see the compatibility mode Tab or choose properties.
Jul 30, 2009 | Computers & Internet
Need vista software
vistas UAC is a pain sometimes.  one thing you may want to try is right click on the cd drive and choose "run as administrator" many times windows block even if your are the admin. another is the compatibility mode. try running it in compat for xp.
May 04, 2009 | Computers & Internet
Sims complete collection won't run on my windows vista
Hello.. The Sims collection does have some compatability issues with vista but EA has worked on it and actually it should run fine.May be any running process is conflicting with the game or you may have to update your Display drivers.
Also try using the compatability mode.Just right click on the game *.exe and select properties.then select the compatability tab and check the box "run in compatability with Win Xp[sp2]".
In adition you can check for any available patches here. http://www.electronicarts.in/search/?search=sims
Oct 30, 2008 | EA - Electronic Arts Sims: Complete...
Quickbooks 2003 Windows Vista Installation
install as normal then run as admin once. should not have to run as admin again. wonder where at intuit lenny 297 works lol
Apr 13, 2008 | Intuit QuickBooks Pro 2003 Single User...
Is quick books 2003 Vista compatabile?
QuickBooks Pro 2003 can run on Windows Vista. Right-click a shortcut to open Quickbooks (or qbw32.exe directly) and click on Properties. Select the Compatibility tab. Under Compatibility Mode, check the box and select Windows XP (Service Pack 2) from the list. Under privilege level, select "Run this program as an administrator." Select OK and everything will work.
Feb 14, 2008 | Intuit QuickBooks Pro 2003 Single User...
EA Sports MVP Baseball 2005 for Windows Logo
354 people viewed this question
Top EA Sports Video Game Consoles & Games Experts
James Wishart
MegaByteMe
MegaByteMe
mhder
Level 1 Expert
Are you an EA Sports Video Game Console and Game Expert? Answer questions, earn points and help others
