Need wiring diagram for AO SMITH motor model F48V61A01
3 Suggested Answers
  • 96 Answers
SOURCE: Need connection diagram, AO Smith motor FDL 1056
Black is high , Blue is med. , red is low
Posted on Feb 19, 2009
meBNme
  • 334 Answers
SOURCE: I have a Trane XE1200
OK, locate the terminals on the capacitor marked "HERM"(Compressor lead), "FAN", and "COM".(common)
HERM and COM remian as they are.
The wire going to "FAN" (usually brown) will be placed on either terminal of the new capacitor. (This is the ((usually brown)) wire comming off of the fan motor.) An additional wire needs to be run from the other terminal of the new capacitor to the "COM" on the old capacior.
What you are doing is bypassing the fan side of the old capacitor but still using the compressor side of the old Cap.
The fan should have a wiring diagram on it to help identify the wires if there is no brown wire. The other two wires will be identified on the wiring diagram as well, but one typically goes to the contactor and the other to the board.
Posted on Sep 07, 2009
Wiring diagram AO Smith ST1102 pump motor
There is almost always the wiring diagram on the outside of every spa motor.
Bath Spa Parts Online
Jul 24, 2016 | AO Smith Pool & Spa
Wiring issue
Without model info, try this link. Most motor brands follow pretty standard wiring setups. Please rate me if this helps.
http://waterheatertimer.org/pdf/AO-Smith-motor-wiring.pdf
Apr 16, 2014 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Wiring diagram for century pool pump motor model b977
check on side of motor should show low and high voltage wiring if not email AO smith
Apr 13, 2013 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Im replacing a 2 speed Hayward motor with a AO smith 1 speed motor. I need to no how to wire the 1 speed
to wire a single speed motor you use only the black, white and green wire. there is usually a wiring diagram on the side of the motor to show how this is done.
no wiring diagram then put the black wire on the L1 or H1 post and the white wire to the common and of course the green to ground
Aug 21, 2011 | AO Smith A O Smith Motors Century 1hp 115v...
Need wiring diagram for BN34 motor 2 speed 1.5 hp 230 volt
Usually the wiring diagram is on the nameplat of the motor. I hope this helps.
Aug 16, 2011 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
I purchased a 60 gallon compressor from Lowes which has a 230 volt single phase motor,3450 rpm,15 amp. The model # of the motor is 7-194160. There is no wiring diagrm in the manual. I was wondering where I...
There may be a wiring diagram either on the body of the motor or inside the wiring terminal cover.
A.O. Smith can be contacted at 800-262-6484. If you do call, have pertinent motor info ready.
Nov 30, 2010 | AO Smith Air Tools & Compressors
Just replaced a rheem oem 1/6 hp motor 3 wires with a 1/3 hp 5 wire. Need help with wiring diagram. A.O. Smith 1/3 hp to capacitor
green wire cut off if motor is held on with metal bracket.white/yellow to contactor,black to other side contactor. brown/wht to fan on capacitor,brown to common on contactor NOT HERM.
Jul 07, 2009 | AO Smith 2 HP 115/230V 56C Replacement...
Heating & Cooling Logo
248 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
