Question about Samsung LN46A650 46 in. LCD HDTV
Power cycling with green screen on our LCD TV - we had a repairman in DEC and he tightened some screws inside and it's been fine for 5 months. What now - we don't want to invest another $250 in repair charge.
  • Jack Herklotz May 20, 2011
    Thank you for your quick response. It seems a bit more than I can deal with. I wouldn't recognize a capacitor from a cap pistol, let alone know how to remove and replace one. I will check out the youtube videos, as you suggest.
    Should I need to junk this set, can you recommend a more reliable brand of TV to purchase?
    Thanks, and God bless.
    Jack
    From some research my wife did this morning, there were many, many complaints as to Samsung customer NO service. Can you suggest brands with a better track record in that respect? Thanks.
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on May 20, 2011
  • Norman Skinner
    Norman Skinner May 20, 2011
    This issue isn't brand specific, but most manufacturers have resolved this issue by using more expensive but more reliable capacitors, so the short answer is that almost any brand should be fine these days.
  • Norman Skinner
    Not being one that calls for service often, as I fix things myself, I can't really say in that respect.
    When you go online, you will always see the complaints as few people post praise for any manufacturer, but almost always post complaints.
    I know HP has great service because I used to work for them, however, I don't think HP makes TV sets.
Why does my Sony Google TV NSX-46GT1 46 in. HDTV LCD TV powers up, displays application screen on bottom, makes a computer chime and shuts off completely, and starts the same process over and over aga
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 25, 2014 | Sony Google TV NSX-46GT1 46 in. HDTV LCD...
My Dell moniter is a 19 inch monitor (Model No: E193FPc) and it's been working fine for 5 years. Now when I plug in the power, the power button goes green, but the monitor shuts off instantly. This...
your LCD monitor has a defective cathode driver inside, it will shut down your monitor when it has short circuit or has defective cathode bulb. you have to open your LCD case to see the circuit .you need screw driver set plus and negative to open the case. if your have knowledge in troubleshooting you can check the circuit if it has a short or defective part at the cathode driver, it has two small transformer that supplying the 2 or 4cathode tube in upper and lower screen of lcd
Aug 18, 2011 | Dell E193FPC 19" TFT LCD Flat Panel...
Can't find screw size to fit back of my 42in Toshiba Regza. I want to mount on wall. Screws that came with the 42in wall mount don't fit it. It's not a 5/16, 6mm, 8mm fine thread or course thread
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
Dec 19, 2010 | Toshiba REGZA 46RV530U LCD TV
TV goes off after turning on
did you change your lamp? if so check thermal fuse.. i have same tv, it was great for about 18 months then went to ****.. light engine will go out soon, cost between 2,000 and 600 bucks.. i have major complaint with sony atm. i know several several ppl with sdame prblem, might get a class suit started against sony, they knew and did nothing. I am pretty upset with them since i have always been a sony fan until this.
May 20, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
When my tv is on for about 15 mins the borders turn green. I have changed the hdmi cable and it hasn't fixed the problem. My tv is a 47" vizio 1080 and it's only 4 or 5 months old. can you help?
something is wrong call vizio i bought the same tv two days later all of the color on the screen that should be black is green called repairman who came tv was working and after he replaced the mother board and daughter board tv was black turned on but no pic he tried again and i heard the arching sound he zapped it i was told by repair we need to order the power board it willl be another 3 to 5 days
i called vizio the minute that he left i was so pissed and that is not like me they are sending a new tv that was thursday i still have to wait 7 to 10 days but they are standing behind there tv i will give them that
Jun 04, 2009 | Vizio SV470XVT 47 in. LCD TV
Proscan 19la25q 19in lcd
Is there a red L-E-D power light beneath the screen? that is the power off light(red). Watch closely to see if that red light momentarily turns green and then immediately red again when you are attempting to turn the tv on, that indicates a bad power supply. There are replacement power supplies on ebay. Be sure that the positive (+) is the center hole of the plug. Most likely all of them are. The output plug is 5.5mm x 2.5mm in size.
http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=12+volt+5+amp+power+supply&_sacat=See-All-Categories
Mar 08, 2009 | Proscan 19LA25Q 19 in. LCD Television
Sony KP-51WS510
you need a green CRT thats whay you have the white kind of concave lines with the green screen. You can try adjusting the green screen control but you need anew CRT ( tube) the speaker cover has two plastic plugs that get removed on the lower edge os the grille which covers the two screws that hold the grille on. If you need more assistancr or where to get a green CRT let me know as I have a link that has some green and red Tubes for your model.
Sep 05, 2008 | Sony KP-51WS510 51" Rear Projection...
Norcent LT-3222 32" LCD HDTV SCREEN TURNS GREEN
I have the same problem and need help. Have this TV over 5 years and don't know what to do this it
Aug 29, 2008 | Norcent Technologies LT-3222 32 in. LCD...
Light green and pink spots on my hd tv!!!
Tiny particles of dust on the light engine lens can cause this (and was a service call for me about a month ago), or possibly the expensive light engine.
May 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Samsung LN46A650 46 in. LCD HDTV Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
