Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
Tv keeps shuyyong off and restarting - Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on May 20, 2011
Tv keeps restarting
take air and blow out the vent holes on the back. it is getting hot and shutting down. if that doesnt help its a relay bad
Mar 18, 2012 | Coby TFTV2625 26 in LCD TV
The hd tv keeps cutting out and saying no signal
It not the tv,u restart the Sky HD box the signal come back right?The Sky HD box is the problems,replaced the box,u will solved this problems.
Apr 22, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Tv keeps self restarting after about 30 - 45
When lamp in TV become weak in result and consume more current then its rating , TV gets that symptom, on for few seconds/ minutes, shuts down and turns on itself.
Please replace lamp in TV as procedure is written in user manual of TV and its easy.
Let me know if you have further question.
Thanks.
Dec 13, 2009 | Sony KDS-R50XBR1 50" HDTV
N99i keeps restarting
What is pin number for make factory settings; MODEL TV-N99I
May 14, 2009 | Dual Electronics N99i Cellular Phone
I have a asus 7200 gs 256mb graphic card my pc keep restarting
Your PC keeps restarting because while playing your video card is highly solicited,and this causes overheating. The solution to your issue is to buy a cooling fan and attach it to the cooling grid.
If this solution worked for you please rate it. If you require further assistance feel free to post a followup comment.
Feb 13, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
V smile learning systems keeps restarting
Unplug the system from the power supply for about 15 seconds and try one more time. If that fails:
Make sure the power cord is plugged in and that the red/white/yellow cables are plugged properly into the TV. Also, as you plug the red/white/yellow cables into the TV, make sure you turn the TV to the right channel - it is different for every TV. For instance, the red/white/yellow on the front of my Sony is labelled Video 2 - yours might be labelled FRONT, AUX, or something else.
Things you can try to get the V.Smile TV Learning System to work:
1) Press the Reset – Press and hold the ON button for about 10 seconds
2) Make sure the game is inserted far enough into the system, and that it is pointing in the right direction. You may occasionally need to clean the contacts.
3) Also, make sure you are using the supplied power cord/adapter, not batteries. Batteries cause more problems than they’re worth.
-Tha Mp3 Doctor
Nov 23, 2008 | Vtech V.Smile TV Learning System
Restarting T.V
Sounds like the flyback transformer or the regulator is bad or could be both. There are no user serviceable parts inside of these sets so servicing should only be done once you understand the safty issues concerning the HI voltage and X ray radiation.. call in a pro to assist you. Good Luck
Jun 18, 2006 | RCA 27V550T 27" TV
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
