Screen on gateway laptop using windows vista appears oblong and quick start icons appear too large.
  • 44 Answers
Change your screen rezolution to 1024 x 768 or 800x 600 this should change youe screen to the proper size
Posted on May 20, 2011
Some of my desktop icons have grown to be very big. I want small icons.
in windows 7 right click on the desktop and select Personalize. Then click display on the left. Choose small, medium or large.
in windows xp;
Shrinking Icons in Windows XP
  • 1 Right-click on the desktopicon1.png. A drop-down menu will appear on which you will click on "Properties."
  • 2 In the "Display Properties" box, click on the "Settings" tab.
  • 3 Slide the scale in the "Screen Resolution" box to the right to shrink the icons (and everything else that appears on the screen).
  • 4 Click on "Apply" and then click on "OK."
  • 5 Click on "Start" and then right-click on an empty space until a box that says "Properties" appears. Click on "Properties."
  • 6 In the "Taskbar and Start Menuicon1.png Properties" menu, click on "Customize."
  • 7 In the box that says "Select an icon size for programs," click on "Small Icons."
  • 8 Click on "Apply" and then click on "OK" to adjust the size.
Shrinking Icons in Windows Vista
  • 9 Right-click on the desktop. When the drop-down menu appears, run the mouse-pointer over "View" and click on "Classic Icons." This will shrink the icons if they are set to either "Large Icons" or "Medium Icons."
  • 10 Right-click on the desktop again and click on "Personalize."
  • 11 On the "Personalize appearance and sounds" screen, click on "Taskbar and Start Menu" on the left side bar.
  • 12 In the "Taskbar and Start Menu Properties" menu, click on the "Start Menu" tab.
  • 13 Click on "Customize."
  • 14 Find the box that says "Use large icons." If it is checked, uncheck it and click on "OK." This will shrink the Start Menu and Taskbar icons.
Read more: http://www.ehow.com/how_4855250_make-windows-icons-smaller.html#ixzz2ifeSGGtj
Sep 08, 2013 | Computers & Internet
Hi I connected an "S" cable from my laptop to my
Thank You Mr. David,
For choosing my services.
I will try my level best to help you,
First start with very basic Troubleshooting steps
1. Switch off both devices.
2. Make connections S-Videos
3. Now switch on Laptop (As you mentioned its dell)
4. Now switch on TV or monitor.
5. Now hold (fn key) and simultaneously press f8 or f7) f8 for dell. (key which contains display icon on it).
6. Fn and f8 key helps in toggling displays in 3 modes-
7. Laptop display
8. Monitor /TV display
9. Both of displays
If you are Using Windows 7 then follow these settings after above troubleshooting steps
  1. Click "Start," access the "Control Panel" and then select "Appearance and Personalization." Find the option that says "Adjust Screen Resolution" and click once. A small window displays with two monitors labeled "1" and "2."
  2. Click on the "Identify" icon and a large "1" appears on one monitor while a large "2" appears on the other.
  3. Select the drop-down menu next to "Multiple Displays." Select the "Extend these displays" and click apply. The desktop is now extended. Adjust the "Resolution" and "Orientation" to complete the customization.
  4. Control Panel\All Control Panel Items\Display (You can choose magnification of your screen. (Medium-100 % recommended) check and set it to medium.
Now Let Me know the status and Exact problem You are facing right know.
Thank You Regards
Sunil Pratap Singh
Feb 05, 2012 | Dell Computers & Internet
The taskbar is upside down and at the top of the screen
On Windows computers, you should have what is known as the taskbar. This is the gray strip that runs across the bottom of your computer and which displays icons for quickly accessing programs you frequently use. The taskbar also shows the "Start" menu, clock and icons for your Internet connections. Sometimes icons do not appear properly in the taskbar. This usually is because the computer is new and hasn't had icons placed in the taskbar manually, or because a default setting is off in the OS properties. Both are simple fixes.
1.Right-click the "Start" icon and select "Properties."
2.Select the "Taskbar" tab in the "Taskbar and Start Menu Properties" dialogue box.
3.Uncheck "Lock the taskbar" and "Auto-hide the taskbar." Check "Show Quick Launch." Since the Quick Launch box isn't available in some systems, you may need to right-click on the taskbar area, choose "Toolbars" and then select "Quick Launch."
4.Navigate to the programs you want to show on the taskbar through the "Start" menu or on your desktop. Right-click the program and drag it to the taskbar. Choose "Create shortcuts here" from the menu that appears. The icon for the program should appear in the taskbar.
Sep 19, 2011 | Dell Latitude 2120 Notebook
I need help to create a new account in microsoft outlook for e-mail?
For Windows 7:
  • If Control Panel is in either Large icons or Small icons view, click Mail. The Mail Setup dialog box appears.
  • If Control Panel is in Category view, under View by, click to select either Large icons or Small icons, and then click Mail. The Mail Setup dialog box appears.
  • Click E-mail accounts
  • Select the E-mail tab, click New...
For Windows Vista or Windows XP:
  • If Control Panel is in Classic View, double-click Mail. The Mail Setup dialog box appears.
  • If Control Panel is in Category View, under Control Panel, click Switch to Classic View for Windows XP, or click Classic View for Windows Vista, and then double-click Mail. The Mail Setup dialog box appears.
Alternatively, in Outlook, select the File group at the top.
Click INFO, then add account.
Jun 23, 2011 | Microsoft Office 2010
How to change icon size on laprop
Try to go to this link, on how you change icon size.
http://www.techtalkz.com/windows-7/516049-how-change-font-size-icon-size-windows-7-a.html
AnEspera
Apr 18, 2011 | Computers & Internet
Hi, I can't open the main modem configuration page. the modem is (thomson tg585 v8. and the page adress is 192.168.1.254 it opens for a minut or so after turning it off then on, then it shows explorer...
Please try one of the following option:
Browse to http://dsldevice.lan or to the IP address of your Thomson Gateway (by default: 192.168.1.254).
If your computer runs Windows Vista or Windows XP, you can also access the Thomson Gateway Web Interface using the Internet Gateway Device icon.
If you computer runs Windows Vista:
1 On the Windows Start menu, click Network.
2 The Network window appears:
3 Right-click your Thomson Gateway (displayed as THOMSON TGXXX) and click View device web page.
4 The Thomson Gateway Web Interface appears.
If you computer runs Windows XP:
1 Go to My Network Places.
2 The My Network Places window appears:
3 Double-click your Thomson Gateway (displayed as THOMSON TGXXX).
Be sure you don't have any popup blocker or firewall interfering.
For more reference here below the manual (Version 7 that is basically the same of V8)
http://www.cytauk.com/cytauk/userfiles/TG585-v7_SetupUserGuide_en_pdf.pdf
regards
Mar 22, 2011 | Computers & Internet
Gateway P-6313 laptop error
registry may be corrupt...
try cleaning registy by using Tuneup Utility...
Dec 20, 2009 | Gateway P-6313 Notebook
Cant find how to put the side bar
We are talking Vista right and not mac. If your talking about the Vista side bar then heres how to do it.
  1. Vista start menu (windows icon on the bottom left corner)
  2. control panel
  3. Appearance and personalization
  4. Windows side bar properties
  5. check "start side bar when windows starts". You can also customize it from here.
Jul 27, 2008 | Gateway Computers & Internet
Gateway Laptop
This is either an operating system failure or hard drive failure. Start by reloading a fresh operating system (Vista) with your recovery or operating system disc. If you have any problems during or after the install, then it's the hard drive and will need to be replaced.
Jun 25, 2008 | Gateway MX6920 Notebook
Large text
The first thing to check is the preferences for display. It sounds from what you say like it is there that the problem lies.
Right click anywhere on the desktop EXCEPT on an icon, and choose the bottom option "Personalize" from the menu that appears. On the left is an option called "Adjust font size (DPI)" start by checking that this is set to 96 and not the larger 120dpi.
You might also like to change the Theme back to Windows Vista and see if that fixes it. These options should change your screen back to the way it was.
May 26, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
