Question about HP Pavilion dv8315NR Notebook
My HP Pavilion dv8315nr runs slow, the audio is choppy and the battery won't charge. I have to take the battery out and only use power cord for laptop to turn on. I was told to get a restore disk and have someone totally wipe out the hard drive. Is there any way to download the restore disk? If not, where can I order one for the least expensive price? Thanks!
    Sergeant:
  • 212 Answers
First I think you have a bad battery...this is usually why the battery wont charge or the machine wont turn on when you have the battery in. So I would look into replacing the battery.
I think for the slowness you can definitely do a restore to factory settings to help clear some of that up. The link here: http://www.pctechbytes.com/hp/hp-recovery-cd-creation Should give you some info on creating restore disks for your HP machine.
NOTE...be careful and BACK UP your data and test it. a restore will wipe out all your programs and data and set your machine back as if it was the day you brought it home. Make sure you have backups.
Good Luck.
Posted on May 20, 2011
My HP pavilion dv6700 won't power on. I have a blue light at the power cord but can't power up.
disconnect the power adapter 2) disconnect the battery too 3) Press the power and hold the switch button power by 60 seconds. Then proceed in reverse and Power again and can be fix it.Of course if the problem remain test the memory from your pressing the key f2 or f9 depending of your modell in the reboot and go to the test memory.
God bless you
Mar 22, 2013 | HP Pavilion dv6000z Notebook
HP Pavilion dv6448se Notebook PC Won't Boot.
it restarts on booting screen or else at start up screen itself?
Jun 08, 2012 | HP Computers & Internet
New battery HP g61 is fully charged but not working \
Maybe the AC Adapter Power Cord is not working. If you can't get on the laptop with the power cord then it is bad and the battery might be drained so you have no power source to power up the laptop.
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 30, 2012 | HEWLETT-PACKARD HP G61A50US 156 AMD Athlon...
T will indicate charging but it won't charge actor
Apr 23, 2012 | HP Compaq nc6400 Notebook
How to test laptop output to the battery
Click Start Control Panel and go into the Power Options to check the Battery Meter. Batteries on last for so long. Maybe it's time you buy a new one.
Apr 20, 2012 | HP Pavilion Dv9910us Notebook PC
Batterie ne charge pas
Apr 02, 2012 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion DV7-1245 runs on battery, but not with the power cord
If there is a light on the charger? check to see if is illuminated when plugged in the mains.
Could be a faulty power supply lead, check for broken lead near the plug that plugs in to the laptop. The socket it'self could be faulty, if it is then the laptop will need to be stripped down to repair it. Usually it's only a matter of resoldering a joint but it's not cheap because of what's involved.
Jan 24, 2012 | HP Pavilion dv7-1245dx Notebook
My HP Pavilion dv8315NR PC Notebook crashes b4 windows even loads but has done this for awhile just shutting off think it could be the battery if theres a way to check?
there is a way to check whether the battery is good or bad , you can go to the hp.com and download the hp battery check software which is the smallest software into you computer and run the test it will show whether the battery is good or bad or whether you need to replace it.
Oct 27, 2009 | HP Pavilion dv8315NR Notebook
Dell laptop wont run with power cord and wont charge battery
could be the A/C connector on the mother board this would have to be replaced by a TECH if your cord is good and you have voltage coming out of the end of the cord that plugs in to the laptop then your A/C connector on the mother bord is bad and its a common problem this happens with use, if the laptop is new then return it if not it could cost $120.00 to fix. GOOD LUCK
Sep 21, 2009 | HP Pavilion zd8000 Notebook
HP zd8000 will not charge battery or run on power cord
check the dc jack probably is loose that cause the batterie dont get charge
Aug 13, 2009 | HP Pavilion zd8000 Notebook
HP Pavilion dv8315NR Notebook Logo
117 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
