Question about Vizio GV42L 42 in. LCD Television
No signol I turn the tv on.....I get a blue screen that says "no signal" and then 5 seconds
  • Anonymous Sep 08, 2008
    37inch model. Turn on no signal display, tv shuts off in in a seconds
  • xoxsanders Sep 30, 2008
    i have the same problem did you find out the problem
Me too. Anybody out there...please help.
Posted on Sep 26, 2008
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
The TV turns on but cannot find a signal (as has been normal when swictching to HDMI inputs). Usually it takes a second and the Cable or FIOS signal shows on screen. As of today, the images never comes...
Tries tv and cables boxes uplug,replug it back like about an hour later for the tv resetting itself back to the factory setting and those pay boxes updated it softwares.Take the HDMI cable plug it in into another tv HDMI hub.Tv should have signal and work again.
Feb 17, 2011 | InFocus ScreenPlay 61" Rear Projection...
I turn on the tv and i get a blue screen for 5 seconds and the tv shuts off. Any ideas?
Hey bbendure, I have a similar/same same problem! My model is a GV42L.
It has a blue screen that says no signal t, then it turns itself off in about 20 seconds.
Is this the same problem you see?
Oct 09, 2010 | Vizio GV42L 42 in. LCD Television
TV says lost signal and turns itself off
Unplug the TV from Wall, wait a bit and plug back in. Should be reset.
Feb 09, 2010 | Vizio L42HDTV 42 in. LCD Television
I turn on the tv and it has a blue screen and no
Just try to reset so picture will back to normal again, some LCD TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the LCD TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the LCD TV power button for five seconds.
4. Plug the LCD TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the LCD TV is responding again.
6. Turn off the LCD TV and reconnect the devices.
7. Turn on the LCD TV.
Hope it may help you;
Regards;
VOTIT
Apr 23, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
The dogs rolled on the remote and the tv went to a blue screen and turned off. Every time you turn the tv on now it is a blue screen and says no signal and turns off after 10 seconds
This sounds as if when the dog rolled on your remote he has pressed the source button so that you are no longer on the TV cahnnel. The TV is looking for a different input eg. AV1/AV2/HDMI etc. This will give you a blue screen & as there is no signal the TV will switch off. Check on the remote for an Input or TV/AV or source button & make sure this is set for the TV signal.
Mar 22, 2009 | Vizio Televison & Video
No signal and blue screen
hello
i think you might have a blue screen of death on your tv
--full str pka
Dec 31, 2008 | Polaroid FLM-3732 Television
No picture, blue screen only
Good Day;
It sounds like you have a lack of signal; 1. reset TV by unplugging TV & signal sources from wall for at least 5 minutes then plug back in, 2. Turn all eguipment on such as cable box, dvd & etc, then change the inputs from your TV's remote, if still no pix,only blue.
Good Luck.
May 01, 2008 | Mitsubishi WD-62725 62" Rear Projection...
42 in lcd vizio "no signal"
Had the same problem. My TV must have been puht onto RGB input. So I plugged my computer in to the RGB on back and turned on the TV. It stayed on. Then switch it back to input of choice
Apr 15, 2008 | Vizio VU37L 37 in. LCD TV
Tv monitor turns blue during forward or reverse vcr search
On some TV's the screen will go blue if there is not a strong, solid video signal present. This is to prevent the showing of very snowy or all snow channels, or garbled, mixed-up external video signals. This is normal. On some VCR's the video signal changes when the FF or REW search feature is used, and this could trigger the TV to go to blue screen. The only way around this if you can enter the TV's menu and turn off the blue screen feature.
Jun 23, 2007 | Panasonic PV-V4020 VHS VCR
Vizio GV42L 42 in. LCD Television Logo
227 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
