When I set up the router It comes back with the internet is not hook up, but when I hook the intern et up to the lap top it goes right through Please help me with this problem
  • 24 Answers
Try restarting the modem while it is connected to the router. the modem probably thinks that it is hooked straight up to a computer not a router. if that doesn't work go to the web gui by going to the routers ip address on a computer connected to the router. the easiest way to find its ip is to go to run (or the bottom search bar if in vista) and type in cmd. once this is up type in ipconfig /all look for the the default gateway. write this number down somewere.
next go get on a web browser (internet exploiter or fire fox) and in the address bar type in that number. this will take you to the web gui. start adjusting the router so that it works with your internet service.
Posted on Aug 15, 2008
Internet shuts off why?
First try doing a complete reset on your Router, and then give the wireless a new name and password. Do Not inter any old/same info. Start fresh
Nov 26, 2017 | Linksys WRT110 Wireless Router
How do i connect it to the internet? Do i need a card or wireless router or both? I tried hooking it up to my refular internet connection and it wont connect. Diana
check that the network its network drivers are fully installed to check it, right click on my computer icon, then hardware, then device manager, any yellow spot or question mark you see from the device manager means that there is a driver missing.
Jan 07, 2011 | Acer Computers & Internet
We have the router hooked up now where do I connect my Lap top to get into the internet?
If it's a standard router, you can plug a Cat 5 (networking) cable into any of the numbered slots on the back, and into the corresponding slot on the side or back of your laptop. If it's a wireless router, you need to check the manual on how to name and set up a password for access to your wireless 'network.' Then you access your network from the laptop, and enter the password when prompted.
Me2_BFD
Dec 13, 2010 | Computers & Internet
I lent my lap to a mate it has come back but i can,t get internet on my normal wireless its a d link M e a bit new to computers but i like my little lap top any help cheers
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
May 10, 2010 | D-Link 802.11g Wireless Router WBR-1310...
What is and how do I get an IP address to hook up a router?
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 10, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
There is a red workd globe lit up on the front of
So that means your computer works when connected directly to the imternet modem .
You will need to check the settings of the router.
or may be you will need to set up the router again.
Click Here for more info
Oct 22, 2009 | D-Link DIR-615 Wireless Router
I lost my setup disc's and I am trying to set up my internet so that I have my xbox hooked direct and my lap top is wireless
get another computer with internet connection and google your router... Example: belkin f5d7231-4 driver
This should brink results with links to the required drivers that your router needs.
Jun 29, 2009 | Belkin (F5D8231-4) Wireless Router...
Can't get internet connection to my lap top.ps i have a desk top.
Is your laptop wireless adapter correctly configured? It may be set to only recieve certain types of signals (802.11b, when you may beed 802.11g etc), so check if the configuration of the laptop matches the configuration of the router.
To test if the laptop can get internet at all, try to get to a wired internet line (your wireless router may have some Ethernet ports on the back; laptops usually have Ethernet connectivity), just incase your laptop is set to block all internet signals coming in.
Hope this helps!
Dec 27, 2008 | Computers & Internet
Question on setting up two computers
Yes, I have pretty much the same setup at home. Wired desktop and wireless laptop. On the back of your wireless router, there should be 4 or 5 wired connections which you can use. You will only have to use the setup disk on one computer. Basically, the setup disk is for the router, not the computers, it simply guides you through the router configuration process. You can also do this manually, the manual for the router will give those instructions as well.
Apr 07, 2008 | NetGear WGR614 Wireless Router
Wireless router
Do you see a little monitor Icon in the lower left bottom. If so go ahead and right click on it and select wireless connections , If not open network connections, now you should see detect wireless networks, Click on that,( IF SO ) Now you should get a window that shows your wireless connections, Select the network you have by clicking on it, and then in the lower left of the window Opened you should see a connect button, select that, you should be able to go online now if not let me know, there are some other things we can try to get you up and running just write back here if it does not work and as soon as I get this I will get back to you. I am sure its nothing we can't solve. Ok thanks bear001
Dec 23, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
