Screen goes on -then after a couple of seconds the tv cuts off
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on May 20, 2011
    Genius:
  • 1,156 Answers
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
I hope this will helpout.....
LG M227WDP turns black a couple of seconds
Do you have the "sleep" mode turned off on the computer?
As well, you can try different screen resolutions and refresh rate settings on the video section of your computer. That might make the connection to the TV more stable.
Nov 27, 2013 | LG M227WD-PZ LCD TV
The inputs on my RCA scenium dlp tv wont work.
It sounds like your talking about the ITC222 chassis series which is having a small signal board problem. Very common in the RCA ITC222 and ITC222A Chassis HDTV's
Jul 12, 2010 | RCA Televison & Video
Screen goes black but still sound
This is inverter or backlighting problem. Can you try switching it on and off quickly for a couple of times and tell me if these '2 seconds' get any longer'. If picture stays longer and longer before shutting down, one lamp needs replaced-if not, please replace inverter board
Jan 15, 2010 | Goodmans GTVL19W17HDF 19 in. LCD TV
Sony KDF-42WE655. Screen goes dark.
Replace your lamp if you had it more the 3 years.
Nov 08, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sharp LCD TV, Screen goes black sound stays on
Capacitors on the power pack are going bad they need to be replaced that should fix the problem.
Apr 07, 2009 | Sharp LC20SH7U Television
Power cuts off at sart up
I have the same problem with my mistubishi projection tv model ws48311 I believe the problem I had before and it was a couple of transistors and a high voltage power supply that fixed it. I believe the problem was caused by faulty power from a power strip or outlet not making a good connection and sparking. I had Overland Tv in OP Ks look at the Television, but heard bad reviews from a coworker and now do not trust them hsnitkoff@yahoo.com
Aug 22, 2008 | Mitsubishi WS-48311 48" Rear Projection...
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
