Question about HP Mini 1000 Netbook
I have a HP netbook and had to re-install windows 7 because it wouldn't reboot and now when it does boots it says administrator lock. There's nowhere to put a password, if I knew what it was and there isn't anything else on the screen. Please help, thank you.
SOURCE: Administrator Password for BIOS lost
HP laptop 9000 need help installing webcam
Posted on Feb 22, 2008
florin_decad
  • 203 Answers
SOURCE: Hp Compaq nx9020 bios password screen
The easy way is to open up the laptop and remove the smal batery from inside for about 15 minute and put it back, the hard way is to dowload KILLCMOS from internet put it on a flopy disk and insert the flopy disk if you have one in your laptop and falow the prompter
Posted on Jan 18, 2009
brannfenix
  • 81 Answers
SOURCE: hp compaq nx8220 - Administrator password cannot be reset
If this issue started with a motherboard error that appeared to be a faulty CMOS battery and then it started incorrectly detecting your memory and now is asking for a password it could be a faulty motherboard. If you are 110% you or anyone else has set a password on that laptop then I would say your motherboard needs to be replaced. It is a difficult process to reset admin passwords on most laptops due to a security chip that will prevent the trick of removing the battery from working. In all honestly if no one has set a password and the motherboard THINKS someone has then even if you reset the password you will still have issues. There is a small chance your CPU or RAM could be defective. But, again going back to it saying you have a password set that was never set. It just yells faulty motherboard unless someone has set a password without you knowing.
Posted on Jul 28, 2009
  • 280 Answers
SOURCE: My HP Mini won't reboot.
The hard disk cable seems to have got loose. Get into BIOS setup and check if the hard disk is detected. To do this, look for a hint in the first screen that appears with the HP logo. Mostly it will be F2. Hit it before the screen goes off. The main screen will show the devices attached to your laptop. Check if the hard disk is detected(see against the text named Primary Master). If yes, go to Boot tab. Under it see for Boot device priority and select that. Under it make sure your Hard disk is set as the first option.
Reply back with your observations
Posted on Sep 06, 2009
Testimonial: "Awesome! Great advice and figured out what was wrong in a heart beat. Definitely calmed me down by letting me know that my problem is an easy fix. :D"
  • 97 Answers
SOURCE: I recover the operating system
Go into the BIOS by pressing f10 when powering on the laptop.
Go to System Configuration and choose Device Configuration
Scroll down to SATA Native Mode and disable.
Press f10 to save configuration. The computer should reboot and press f9 to select boot device.
See if the 160GB hdd is now showing as an option. If it is then you are in luck.
p.s: You may need to update the BIOS to the latest if it still does not show up for you.
Posted on Mar 01, 2011
Testimonial: "thanks for your solution. but, how I can update the bios?"
Forgot password to dv7 hp laptop
Guide on how to crack Windows 7 administrator password with Windows Password Recovery Professional. Step1: Download Windows Password Recovery Professional from SmartKey website.
Step2: Install and launch it to any accessible computer.
Step3: Use a blank and writable CD/DVD/USB to burn Windows 7 password reset disk with the tool.
Step4: Boot the locked computer from CD/DVD/USB.
Step5: Start to remove Windows 7 password with the burned disk.
Step6: Reboot computer and login to the locked PC without password.
Source: http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
Aug 29, 2012 | Computers & Internet
Reset administrator password hp 6735s
Which system do you use?
On Windows XP, try this:
Boot computer and press Ctrl+Alt+Delete twice when you See Windows welcome screen / login screen. It'll show classic login box. Now type "Administrator" (without quotes) in username field and leave password field blank, press Enter and you should be able to login Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
If that doesn't or you use Windows 7 or Vista, try this:
1. Enter a computer that can link to Internet. Download "Windows Password Reset " from http://www.windowspasswordreset.net and install the software on that computer.
2. Run the software and create windows password reset disk by follow the instructions.
3. Eject the created CD/DVD and insert it into the locked computer.
4. Reboot the locked computer (it's necessary for you to change your locked computer's BIOS setting to make it boot from CD drive) and then follow the instructions to reset Windows password.
5. Now login Windows and set a new password.
Jul 23, 2012 | HP Compaq 6735s Notebook
Computer is lock and forgot password
Since you did not tell us what the Os do you use, you can reference the tutorial below about different systems.
Break Windows 7password
CrackWindows XpPassword
HackWindowsVista Administrator Password
Jun 30, 2012 | HP Computers & Internet
How to reset hp probook 4310s embeded security password
If your hp computer is installed with Windows 7, following the video to learn how to reset hp computer security password with Windows 7 Password Genius
https://www.youtube.com/watch?v=I5HzG7fb-Wg
If your hp computer is installed with Windows 8, and the password is your only admin password, refer to hp computer Windows 8 admin password reset.
Jun 20, 2012 | HP ProBook 4310s Notebook
How can I remove the administrator password of Windows 7?
When you are under account settings, go to administration settings.You have the opportunity to change administration password. If you leave it blank, you won't need a password.
Jun 07, 2012 | Computers & Internet
How to get into password protected HP 110-1144NR netbook
The easiest way is contact the Previous Owner since you say you purchased it from them.
OK, if you are running Windows 7, Microsoft tightenedsecurity on it so you've got to have a password reset disk which 99% of thepeople who own laptops with windows 7 fail to do. It should be one of thefirst things you do when you buy the laptop. Otherwise, you're faced withreinstalling the Operating System or possibly doing a System Recovery.
If you're on Windows 7 or Vista try this:
Turn off the computer, then hit the power button to turn it back on andimmediately start hitting the F8 key repeatedly until you see the Safe Modeoption. Select SAFE MODE and let the computer boot up. When it getsto the User Login screen it will show the Administrator userid and the useridfor which you forgot the password. Sign in as the Administrator (hopefullyyou didn't put a password on it and forgot it too). Once the desktopappears it will look different, the screen will be darker and the icons bigger,but this is normal for safe mode.
Click Start/Control Panel/User Accounts
When the User Accounts screen opens, click on the userid for which you forgotthe password. Select the option to REMOVE PASSWORD.
Reboot your machine.
Mar 31, 2012 | Computers & Internet
Hp 110-3030NR just bought used, wants a password , will not boot without it, don't know where the f keys are, so can't get to safe mode
Here I collect some popular solutions to help reset HP laptop password if your laptop installed Windows system such as Windows 7/Vista/XP.
Solution 1 Reset HP laptop password by another user account with administrator privilege.
Solution 2 Reset HP laptop password with Offline Windows Password & Registry Editor.
Solution 3 Reset HP password with professional password recovery tool.
If you do not have another administrator account on HP laptop or you have little experience in Windows or LUNIX operations, you can use Windows Password Rescuer to help reset HP password without lose date. This software was provided by DAOSSOFT corperation, it supports HP laptop password recovery in Windows 7/Vista/XP and HP computer installed Windows 7/Vista/XP/2008/2003/2000.
http://www.daossoft.com/knowledge/how-to-reset-hp-password-hp-laptop-password-recovery.html
Sep 18, 2011 | HEWLETT-PACKARD HP Mini 1103030NR Netbook
My netbook n150 plus is displaying "no operating system detected" HELP!
Hello!!
1. To repair it put your Windows 7 DVD to dvd tray (any windows 7 DVD will work oem/retail)
2. boot from it
3. when you reached to the Installation Screen, At bottom You'll find Repair Windows Option.
4. Hit that option and let it do start up repair automatically and let it reboot..
5. on reboot after repair please remove your DVD to let the Netbook boot from HDD rather than DVD.
If the above mentioned solution fails then, you should reinstall the OS.
Jun 05, 2011 | Samsung N150 (36725723009) Netbook
I forgot my password on my computer
I know a windows password recovery tool called windows password buster. This software could help you recover the password.
Nov 28, 2009 | HP Computers & Internet
Forgot password to hp laptop how do i reset it.
I don't know what OS your HP laptop is installed with.
If it is Windows 8, Windows Password Hint, PIN code, Microsoft account can be used to login HP laptop. After logon successfully, change, recover or reset Windows 8 password is available.
If it is Windows 7, Password hint or another administrator account may help you. But if you don't have all of these, try password reset disk. Create it before Windows 8 locked or with Windows 8 Password Recovery tool is OK.
Besides these, Chntpw USB disk also works for Windows 7/Vista etc.
Mar 09, 2009 | HP Compaq nx5000 Notebook
HP Mini 1000 Netbook Logo
23 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
