Question about Dell Dimension 9150 (DIM915MIN) PC Desktop
A few problems with my dell 9150. 1 Windows boots up but screen shows garbled then turns black and monitor into power save mode. I tried a complete system recovery, still the same.
  • david_mcd24 May 20, 2011
    I have bought a replacement video card and installed it, It now boots up as it used to. thanks
    Sergeant:
  • 228 Answers
Try to update your video card driver if you haven't tried it yet. But if this will not work, try to use good known video card. If you don't have dedicated video card, might be a motherboard problem already.
Hope this helps.
Posted on May 20, 2011
    Sergeant:
  • 212 Answers
I would try starting up in VGA mode (tap F8 at the splash screen and choose VGA mode from the menu)
VGA mode will load very few drivers and a generic video driver into Windows. From there you may be able to go to a website and download the latest (or even rolled back) drivers. Or you can uninstall and reinstall the drivers from the Device Manager (in the control panel)
This article from microsoft provides a little more detailed information:
http://support.microsoft.com/kb/268852
Testimonial: "yes i bought i replacement video card and every thing is working OK again"
Dell monitor e177fpc
I sounds like you have the video card set to a resolution that is higher that the E177 can handle. It can only go to 1280 x 1024 resolution. You will need to boot into safe mode in windows and set the resolution lower than that so the monitor can show it correctly.
Jun 10, 2013 | Computers & Internet
Before Windows can boot-up the screen turns solid blue & a Dialog Box state "Entering Power Saving Mode". The screen then appears that the sleeping mode has occurred.
just switch off and switch on the monitor or press any button on keyboard to bring monitor from power saving mode thats all
Sep 23, 2010 | Dell E207WFP LCD Monitor
Screen goes black. the power light is on, but the picture goes out. if i turn the power off, then on again it comes back for about 5 seconds, then goes black again.
Check to see if this problem follows in safe mode. Reboot and when the Dell splash screen comes up tap F8 until you see the multiboot options. Scroll to "safe Mode with Networking" let the machine boot up and see if you have a screen. If you do, right click on the desktop and set the resolution to 800 X600 and reboot normally. Usually when a screen goes blank in normal mode but shows up in safe mode means you have an incompatible resolution for the monitor or graphics adapter. This may be a driver issue or hardware. If the screen boots up in normal mode at the lower resolution, then try and go to properties again and bump the resolution up a bit, if it blanks again, try to go online and update the driver for the graphics chip.
Sep 08, 2009 | Dell Dimension E510 PC Desktop
I have a dell inspiron 1501 and it will not boot up. Problem occured last night when black/grey vertical line showed up on the monitor and I had to manually power it down by hold down the power butten for...
Try booting the pc into safe mode with networking. If it will boot to safe mode then all is not lost. If it won't boot to safe mode, try to boot with the windows disc and go to the restore screen or go to the repair option and try to repair the windows startup.
Aug 30, 2009 | Dell Inspiron 1501 Notebook
Monitor keep going into "sleep" mode
Check the power setting in control panel of windows. If you have a monitor from another computer swap them and see if the problem stays with the computer or monitor.
May 12, 2009 | Dell Dimension 3100 PC Desktop
Gibberish + won't finish loading Windows
remove the new memory first. if that does not help you may have some a virus, indicated by safe mode workng fine. One other thing i found would do that is a damaged Hard drive, not to likely here because safe mode works.
Apr 28, 2009 | Dell Dimension E521 PC Desktop
E153fp goes dark into power save mode after Windows start up
may be your power saving option have small time .
check in control panel power option check power shemes.set it to 20 minutes.
Nov 27, 2008 | Dell E153FP 15" LCD Monitor
Black screen and numbers 2 and 4 lit
The 2 and 4 LED error code indicatesVideo subsystem configuration or failure”. You either have a bad video circuit or your video drivers have a problem. Try booting into “safe mode” by tapping the F8 key when powering on the computer. If the computer comes up in safe mode then your video drivers may have to be reloaded.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 15, 2008 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Laptop won't boot (display problems)
If the diagnostics displays on the LCD screen but you get no display when Windows starts to load, it sounds like you have a video software driver problem. Try tapping the F8 key when you power on your laptop and boot in Safe mode. If it works in safe mode then you need to check you driver. You can also try connecting the laptop to an eternal monitor and see what happens.
Thank You.
Nov 08, 2008 | Dell Latitude D800 Notebook
Dell Monitor Power save mode activate using pc
yes right click on desktop select properties then click on screen saver then increase wait time problem will solved
Oct 29, 2008 | ViewSonic VE155b 15" LCD Monitor
Dell Dimension 9150 (DIM915MIN) PC Desktop Logo
119 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
