Question about Mitsubishi WS-55511 55" Rear Projection Television
When tv is turned on the green light comes on and shuts off in 3seconds.
    Genius:
  • 1,156 Answers
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hope this will help to rectify the fault....
Posted on May 20, 2011
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors, probably in the power section.
Any caps in this section (or any other section) that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same/similar issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
I have a whirlpool gold dishwasher. The controls locked light is on and I can not get it to shut off. I can not run the dishwasher
In reading the manual, it shows the following:
To turn on Lock, press and hold Control Lock for at least
3seconds.
To turn off Lock, press and hold Control Lock for at least
3seconds.
Jun 07, 2015 | Whirlpool Dishwashers
Tv cycles on and off
Sounds like bad capacitors in nthe power supply, or maybe a regulator in the power supply. Have a tech take a look at this TV set for you, as there are no user replacable parts available in the TV set. Good Luck
Jun 09, 2007 | Panasonic PT-52DL52 52" Rear Projection...
Getting a message that hdmi is blocked?????and have several blinking amber/green light turns red and tv shuts off....help please WD-65737
Hello!
Please, read my previous solution for WD-65.....
you'll find the answer to your questions.
good luck,
thanks,
Alex.
Mar 06, 2012 | Mitsubishi WD Televison & Video
My ps3 shuts down after 3seconds from booting up the light stays green and does not change color. i tried removing the hard drive and putting back in but still doesn't work. please help
Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep).
and follow the onscreen instructions for resetting the ps3
Feb 21, 2011 | Sony Playstation 3 (PS3) Console
Monitor goes dead after after switch on after 3seconds
CCFL backlight may be busted.. also ccfl inverter may need repair or replacement too..
Mar 09, 2009 | GNR 19M1 19" LCD Monitor
Shuts down after power up 50ux53k bought new 1998
Refer to owners manual will tell you what blinking light means. But at the front not at the back.
Dec 16, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Re:problems
Your TV is probably shutting down due to excessive current draw. Replace the filter capacitor in the power supply and cross your fingers. This will be a large, tall, and round shaped object near the location where your power cord goes into the TV. It has two pins and one is positive and other is negative. Do not get them crosses when installing new part. keever
Oct 22, 2007 | Mitsubishi WS-65908 TV
Mitsubishi WS-55511 55" Rear Projection Television Logo
95 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
