Question about Refrigerators
Mitsubishi elegance MR 51E GY, the freezer is functioning and we just replace the fan. Now the bottom compartment is not cold and water keep flowing out of the fridge. Any clue what when wrong?
2 Suggested Answers
  • 83 Answers
SOURCE: The mitsubishi fridge thermo damper
Hi
These units are called frost free, however in my experience they are some of the time but not all. It is likely that the freezer has built up some ice around the coil and the fan which migrates to the fridge, try the following.
1. Empty the fridge and freezer and store the food elsewhere.
2. Switch off and unplug the unit and leave for 24 to 36 hours with the doors held slightly open. You may get quite a lot of water on the floor, you just need to mop it up, this is normal.
3. Wipe out the inside of both sides to leave them clean and dry.
4. Plug in and switch on, wait around 4 hours.The vent will be clear.
5. Re stock the unit it should be OK.
6. If the problem re-occurs within a few days then there is another possibility that is causing this problem and that is there may be a fault with the defrost system. Possibly the timer, the termination switch or the heater.
7. If the problem goes away for several months then the ongoing solution is to repeat the above steps.
Regards
Gordon
Posted on May 05, 2011
Refrigerator not cold enough and freezer is too cold making food very hard? water seems to leaking on bottom of freezer and refrigerator.
Refrigerators with attached freezers typically keep the two compartments at predetermined temperatures, but failure of some components can lead the refrigerator to seem warm while the freezer portion completely freezes.
Fan Issues
According to the appliance website Appliance Aid, many freezers contain a fan that blows cold air throughout the freezer and into the attached refrigerator. If this fan fails, the site explains that the freezer may become too cold; the refrigerator will not receive air circulation from the freezer, though, and will remain warmer than normal.
Air Damper
Appliance Aid also notes that most refrigerator and freezer combinations contain a damper that regulates the flow of air between the two compartments. If the damper sticks or fails to function properly, it may restrict the flow of air from the freezer to the refrigerator. The result of a failed damper would be a completely frozen freezer and a warmer than normal refrigerator.
Hope this would help.
Good day!
Sep 06, 2011 | Kenmore Refrigerators
The mitsubishi fridge thermo damper clog with ice and the fridge is not cold . The ice freezer compartment side is ok. Please advise what is the problem. The model of the fridge is MR -51E -GY. Thanks
Hi
Regards
Gordon
May 05, 2011 | Refrigerators
My freezer is working but the fridge isnt
Check 24volts fan (DC) is working, which flows the cool air in refrigerator compartments. If not working, replace the fan.Or any materiel you keep by blocking the air flow.
Jan 22, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
TT14ckxaw01 Freezer is working, refrigerator is not.
Your refrigerator gets its cold air from the freezer by way of a fan that transfers air past the freezer coils to the refrigerator. If the fan isn't working the refrigerator will not get cold. I your coils in the freezer are freezing up this will also stop the flow of air to the refrigerator. The first thing to check is the fan.Most refrigerator/ freezers are only controlled by one compressor (unless its a very expensive model). So if one is cold and the other isn't it's normally a simple problem.
Check whether the defrost drain is blocked..This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. Seems like it is blocked with water or ice.
Unplug the refrigerator, empty out the freezer compartment.
pull off the back panel or the bottom panel (in the freezer compartment) Look for that defrost drain hole.Pour small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. Repeat this until I get the water to go down the drain tube
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Oct 01, 2010 | Estate Refrigerators
The freezer is working just fine but the refrigerator is not cold at all
CHECK THE FREEZER FAN MAKE SURE ITS RUNNING AND IF THE BACK WALL OF THE FREEZER IS FROSTED UP YOU HAVE A DEFROST PROBLEM. I ONCE FOUND SOMETHING FELL BEHIND THE BASKET SO THE DOOR DIDNT SHUT ALL THE WAY, CHECK THIS AS WELL
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 13, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My bottom refrigerator is not cold. The freezer is okay.
Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
Jul 22, 2009 | Refrigerators
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
Refridgerater
It could be the defrost thermostat located on the condenser coil on the left side of the fan in the freezer compartment... or else it could be the defrost timer located in the refrigerator behind the dome cover... defrost the freezer and make sure the drain tube is not blocked nor the air passage which blow cold air from freezer to refrigerator compartment below. Water should drip from freezer down hole into tube to an evaporator pan on the top of the compressor near the floor in the back. Make sure the tube is free flowing by pouring some hot water down it before restarting refrigerator. Rarely the defrost heating element shorts, but a simple continuity test will determine if that is o.k. Make sure the refrigerator is uplugged before checking any of these areas... there's 120 volts all about and with water and ice it can cause quite a jolt!
Oct 05, 2008 | Roper RT14DKX Top Freezer Refrigerator
Cold freezer/warm refrigerator
Same problem with Frigidaire Gallery model#GLRT182SAW5 (dated 2002 on back of case)
Vents were blocked with ice. Vents (from top compartment to lower) located behind light. You can check by poking a chopstick up the (2) holes; be careful not to hit fan blades.
Solution:
- took freezer coil cover off in back; checked that defrost heater element was working (marked and rotated the timer in the hole next to light); checked that fan working. Found ice in the vents and defrost drip area. Got it out with hair dryer.
- cleaned compressor coils in back (check fan is rotating; also tweaked some of the compressor tubing bends to make them more smooth - read somewhere about a manufacturing defect ...); blew out drip tube from defroster while down there.
- Set the freezer control to WARM and the refrig control to COLD (THIS SHOULD IMPROVE AIR FLOW FROM TOP TO BOTTOM).
- Put thermometers in top and bottom. Checked that refrigerator cycles (not running continuously). Checked that cold air is coming down from (2) vents behind light.
OK: so far, so good. Lower compartment is 40 or under. Top is under 18.
CONCLUSION: Suspect marginal design. Had problems with another similar model where defroster ice doesn't drain correctly, pools and refreezes. Leading to blocked vents as well as blocked defroster drain and similar problem including dripping water from top to bottom and warm bottom.
MAYBE KEEPING THE FREEZER CONTROL AT WARM GETS AROUND THE PROBLEM?? ANYWAY, ITS WORKING FOR ME FOR NOW !!
Nov 12, 2007 | Frigidaire Refrigerators
Refrigerators Logo
281 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
