Question about Gaggia Syncrony Logic 74884 Espresso Machine & Coffee Maker
I have a gaggia syncrony logic that has just come back from the repairers.! The coffee dregs are almost liquid whereas before they were solid patties & liquid is found in the drip tray after every brew. Can you advise as to why this might be
    President:
  • 1,618 Answers
The coffee grind could be too fine and or not enough coffee is being added to the brew chamber after the machine grinds it. You can try to adjust the amount of coffee being used for an espresso and or adjust the grind.
Posted on May 20, 2011
Gaggia Syncrony Logic has no power
Check the 2 thermal cutouts located on the side of the boiler
Press to reset
Jan 02, 2013 | Gaggia Syncrony Logic 74884 Espresso...
Hi there...have the light continually flashing red...have cleaned it all out and everything is puched in etc...any ideas what it could be?
Had the same problem, switch off, take out the coffee dispensing unit. close everything else up, drip tray, dregs box and front door etc then re apply power. It'll clunk and whir a bit then stop. Switch off and refit the coffee dispensing unit making sure it fits flush with the rear of the housing (you can check this by looking through the hole where the dregs drawer fits. power up again and it'll clunk and whir again as it resets the dispensing unit. I hope you'll find that it's ok now.
Aug 05, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Where can I purchase a replacement dispenser shute for Gaggia Synchrony Logic Type SUP 020 Ser.#9005GA40015808? Many thanks.
Check the site at importika.com they have a list of repair areas any one of them will have a spout in stock.
Mar 10, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Emtied the dreg drawer when the SAECO machine was off.
Chenk the back of the area for the drawer, there might be some grounds preventing the draw from going all the way in to tell the microswitch that it is in place.
Jan 24, 2010 | Gaggia Syncrony Espresso Machine
Need new gasket for boiler for syncrony logic
You can check with wholelattelove or servicesunlimited.
Oct 20, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Hi, Our Gaggia machine will not disburse water through coffee dispenser. Sounds like its operating normally till water flow should happen. Then the motor slows down to nothing. Have descaled to no effect....
Try this press the button for ground coffee then when it lights up press the coffee brew button, if water flows normally then the grind on the grinder needs to be adjusted coarser, if no water then the screen on the brew unit is blocked.
Sep 07, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Red Light 28 is flashing even when dregs are emptied
Check the edge of the container that goes in to the machine there is a small part that sticks out, it is possible that that piece is not touching the microswitch in the machine. Remove the drain tray and the dregs tray, check the corners of the machine for loose coffee grounds.
May 31, 2009 | Gaggia Syncrony Compact Coffee...
Where to find a dispenser holder for Gaggia Syncrony logic
Need also to find height adjustable coffee dispenser, also need measuring scoop,brush and coffee dispenser with wrench.
Apr 25, 2008 | Gaggia Syncrony Logic 74884 Espresso...
Unable to replace dreg box
If you look to the left side of where the dump box slides in you will see a opening in the case. This is the dump box switch. use a knife to hold the switch and turn the machine back on.
This will reset the machine to it proper position. I would recommend cleaking your machine so this doesnt happen.
http://cerinicoffee.com/clean_descale_coffee_equipment_instructions.asp
Oct 12, 2007 | Gaggia Syncrony Espresso Machine
Gaggia Syncrony Logic 74884 Espresso Machine & Coffee Maker Logo
188 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
