Question about SE Electronics SE2200A Professional Microphone
Mic signal just drops out for no reason, can work for hours OK then it will drop every few mins. Using a Pantom Power box and recording through tascam interface into lobic on my Mac.
3 Suggested Answers
  • 3 Answers
SOURCE: SE2200a rapid signal drop off
Troubleshooting steps to isolate the problem:
1) The Saffire has two mic inputs - try the other one
2) Find another condensor mic to try in order to verify that the Saffire's phantom power/mic pre is not at fault.
2b) find ANY mic to verify that the pre amp on Saffire works
Got a small mixer perhaps? A friend with a mixer or pre amp?
3) Plug the SE2200a into another mic pre to see if it is the culprit.
4) Find another mic cable - no matter yours is new. I've seen this before with new cables.
5) Make sure the Saffire's built-in compressor isn't set really hard and is squishing your audio.
6) Look at the LED's on the Saffire as indication of the signal, not Logic. If it's not showing on the Saffire, Logic isn't going to see it, either.
HTH,
Steven
Posted on May 04, 2008
I had the same problem with my Saffire: the phantom power voltage quickly drops when switched on, causing the mic to cut out. This problem is common in older Saffires, and is well known to Focusrite support (a modification in newer-production units solves the problem).
The problem is that a tiny 100 ohm surface-mount "chip" resistor in the phantom power circuit fails due to insufficient power-handling capability. (This is "R196" in the phantom circuit.)
The fix is to replace the "chip" resistor with a "normal" 1/2 watt metal-film resistor (with wire leads), mounted upright on the circuit board.
I replaced the resistor myself, following directions (and photos) sent to me by Focusrite Tech Support.
The procedure is somewhat fiddly (a Swiss watchmaker could probably do OK). If you've never soldered before, DON'T EVEN TRY THIS, and if you've never worked with surface-mount components, I would ask your electronics-hobbyist buddy to do it for you.
Here is the procedure sent to me by Focusrite:
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} SAFFIRE PHANTOM POWER MODIFICATIONS
Dismantling the Unit
Remove the 7 screws on the rear panel.
Remove the 4 screws on the underside of the unit.
Lift away the metal cover.
Remove the 4 small black screws securing the MIDI In/Out sockets.
Remove the single screw securing the S/PDIF In/Out sockets.
Remove the two screws securing this PCB to the chassis.
Gently pull the PCB away from the rear panel and move it through 90 degrees towards the front panel.
Place the unit on its front and support the PCB with some suitable non-conductive item.
Modification Procedure
All the components mentioned are located in the same area on the same PCB (see photo).
It is best to remove the coil and capacitor (as shown in the second photo), as this gives easier access to the components.
Remove R196 and measure its resistance. If it does not measure 100 ohms, replace it.
Use a conventional type (100 ohms metal film, .5 or .6 watt) mounted upright as shown in the photo. Before fitting this resistor, check that the three zener diodes DZ11, DZ12 (22v) and DZ9 (3.3v) are OK and have not shorted out. (Diodes are 500mW, 5% tolerance)
Testing units for Phantom Power problems
Connect a condenser Mic or suitable dummy load* to Channel 1.
Engage +48 switch.
Measure the DC voltage between XLR pins 2 & 1 on Channel 2 Mic Input XLR.
Faulty units usually read around +28Vdc and the voltage gradually drops.
Good unts will measure +48Vdc +/- 0.7Vdc.
* Dummy Load for testing: Solder a 20,000 ohm resistor between pin 2 and pin 1 of a male XLR plug and another 20,000 ohm resistor between pin 3 and pin 1 of the same XLR plug.
Here are the photos:
My Saffire has worked perfectly since I replaced the bad resistor.
Good Luck!
Ken
Posted on Apr 17, 2009
Why nobody hear me on skype
turn your speaker on .,works for me every time I keep my speaker turned off all the time .
Sep 07, 2014 | SKYPE Computers & Internet
I have set-up M-Audio microphone recently but I can't seem to figure out HOW to begin using it. I've tried every drop down and clicked every recording button while I was using the software. . . is there...
Without knowing your setup or the mic model, my guess is that you need to run a phantom power supply to the mic to get it to function. This is done either by using an outboard analog mixing console or mic preamp with a phantom power switch, or using an inline phantom power supply. The microphone plugs into the mixer or mic pre with the phantom turned on, and then into your DAW system.
The phantom power works with condensor microphones like the one you have. It sends a 48v signal to the microphone element, which in turn energizes the element and makes it function. Dynamic mics, like a Shure SM 58 for example, do not need the phantom power and will even ignore it if run on a phantom powered channel. condensor mics however must have it to function, otherwise there will not be any sound. Hope this helps. Good Luck.
Mar 19, 2011 | M-Audio Producer USB Microphone with...
How do i unmute microphone i can hear them but they cannot hear me
open skype go to tools from the drop down list select options scroll to audio settings
you can make a free test call before you try to make a call
make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment also
click start control panel sounds and audio devices audio and also voice it
Jan 22, 2011 | Skype IM
My m-audio fast track usb interface has been working but all of a sudden lately my computer recognizes it when I plug it in but the interface will not pick up a signal from a direct line or from a mic so I...
Hello, try going into Sound & Audio Settings through control panel. From there, click on the Audio Button. Toward the bottom on the left, UNCHECK the box that says 'USE ONLY DEFAULT DEVICES'. Then Under RECORDING section, pull down the drop menu and select M-Audio. And Click APPLY & OK to close. I would reboot and it should be working after that.. ok? Good Luck & PLEASE DON'T FORGET TO RATE MY SUGGESTION, OK? THANK YOU :)
Oct 19, 2010 | M-Audio Fast Track USB (FASTTRACK) Audio...
I have a new Compaq 610 laptop with XP professional. For some reason we can't get the internal microphone to pick up any signal. What can we do to fix it?
wel first of all did you installed the sound card? And after that go to the control panel and sound and audio devices = > click on advanced a new window will pop up click in the left corner on OPTIONS and be sure in properties the mic box is checked and after that go again to OPTIONS and click Advanced options, under de mic level bar you wil have a buton called advanced click`it and Check the box 1 mic boost
Mar 11, 2010 | Computers & Internet
HI my zyxel keeps dropping the line.In general its ok then for no reason it wil run 10 mins drop out then start again sometimes it will run a few days, logging into statistics the time counter has started...
MAKE SURE EVERYTHING THAT IS PLUGED INTO THE
PHONE JACKS HAS A DSL FILTER PLUGED INLINE. DO NOT FILTER THE ROUTER...IF THAT DOES NOT HELP THEN CALL YOUR LOCAL PHONE COMPANY TO INSTALL A WHOLE HOUSE FILTER IN THE BOX ON THE SIDE OF THE HOUSE....
Mar 07, 2010 | Computers & Internet
Suddenly MIC port is not working...
go to volume control option and select mic advace option and choose microphone boost option and try.
Jan 20, 2010 | Gigabyte GA-K8VM800M Motherboard
VX-3000 microphone still enabled with headset. Is
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required mic as default - click on mic font to highlight and click "Properties"
In lower drop-box display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Dec 31, 2009 | Microsoft LifeCam VX-3000 Web Camera
Dropped the mic.
I would imagine the mic element broke. To test, remove from the case and without touching anything else, touch (using a small screwdriver if need be) the solder connections on the wires for the mic element (while system is up). Hum? Yes? bad mic element. No? Problem with electronics. Look for broken wires also.
The receiver shows signal so RF is ok. You have a problem with the audio section.
Apr 28, 2009 | Audio Players & Recorders
SE Electronics SE2200A Professional Microphone Logo
64 people viewed this question
Top SE Electronics Audio Players & Recorders Experts
Michial Gueffroy
Willem.
Willem.
Are you a SE Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
