Question about OEM Systems Car Audio & Video
Have a 95 oldsmobile aurora with factory bose system 12 disc cd changer.the amp and speakers in the trunk don't seem to be working...no sound..but front radio and speakers play.it won't eject cd magazine.keeps giving me a error message. E32...can hear motor in cd player trying to eject the magazine when door opened...
Eagleeyes
  • 199 Answers
SOURCE: Inoperable CD changer
Hi the alpine/merc/bmw cd changer all seam to suffer with the same problem, they say no disc, or no mag try firmly hitting the mag with the handle of a screw driver. the loadinga arm, tends to get stuck. you could try using some grease on the arms, and levers, white spray gease works best. but dont forget to cover the laser beforehand, you dont want grease on it :) Mark www.carradiospares.co.uk
Posted on May 03, 2007
SOURCE: Can't eject cd magazine - E-99 error message
I put a small pin in the reset button a few times and that then got the catridge to eject.
Posted on Apr 15, 2009
welcomejee
  • 10594 Answers
SOURCE: how do you eject the magazine
Press and Slide Front half cover as shown in below image and you will see eject button there to eject magazine.
Posted on May 04, 2009
SOURCE: my 12 disk cd changer in my car is giving me error
check to make sure the cds are label side down, and that the cd door is closed all the way. yes the CD's go in mirror side up
Posted on Dec 11, 2009
dj_relly999
  • 4070 Answers
SOURCE: cd changer magazine does not eject
good day, you may want to do it manually if its jammed, you may find a pinhole on it and u can use a paperclip, insert it in the hole and it will open. hopefully it wont jam again. hope this helps, have a nice day
Posted on Feb 10, 2010
The speakers for my Bose 123 suddenly don't work for any source. It had worked well for years. Mute is off. What can I do?
It sounds to me like the Bose 123 is to blame not the speakers. I think you can test the speakers by connecting a 1.5 volt battery for a short while (few seconds) accross any of the speakers terminals. Disconected from the amp. If they are working it will go POP
If it's the Bose itself then the main amp inside has failed.
Jan 25, 2013 | Audio Players & Recorders
I jusst received an Emerson MS3111. Everything seems to be working well, except I have a lot of "noise" when playing the CD...everything from "static" to a popping. Is that the...
Well, if it's only the CD doing it...
If other sources make the sounds, look at something common like the receiver.
Speakers that aren't physically damaged or overdriven don't 'create' sounds that are not present in the amplified signal.
May 26, 2011 | Emerson MS3100 3-Disc CD Changer
Installing a new stereo. I am trying to install a ''JVC KD-R210'' in my wifes 1985 BMW 535i, replacing a Sony CDX-R79 and in the trunk is a Pioneer 12 disc cd changer that was hooked up to the system. This...
There is a line level converter that would need to be purchased to that you can get the front speakers to work with the amplifier. The stereo already has rca jacks for the rear speakers. You can connect these straight to the amplifier for it to work. Bes sure that you use the blue wire to connect to the remote turn on for the amplifiers. Once you get the line level converter you will connect the wires and connect the converter using the RCA jacks. The question would be how was the 12 disc changer connected to the system. Would need more information on the changer in order to help with that component.
Mar 13, 2010 | JVC KD-S550 CD Player
My 12 disk cd changer in my car is giving me error messages it is a Bose system in my oldsmobile aurora E30 and E31
Aug 16, 2009 | JVC CH-X1100 12-Disc CD Changer
Anyway to bypass my Bose Amplifier
not too sure what you are trying to do but just buy a aftermarket deck..for example for 100 bucks jvc has a nice deck with remote that plays mp3 and even has a jack right on the faceplate for a mp3 player.then throw your subs in the trunk hook up the amp and bingo banging beat.if u have the aruroa with the battery under the back seat its even easier
Dec 24, 2008 | 1997 Oldsmobile Aurora
Bose multi cd changer wont work, reads "Disc error"
I think there may be a problem with the system (defective parts) - I, too, am having this issue. I am going to contact the BBB - maybe if enough of us complain we will get a recall. To file a complaint:
http://www.bbb.org/boston/business-reviews/department-stores/the-tjx-companies-inc-in-framingham-ma-97/
Bose
PO Box 9168
The Mountains
Framingham, MA 01701
Dec 01, 2008 | Bose & Wave& Music System
Can't eject cd from cd changer
hi check and see if there is 12 volt to the cd changer or blown fuse.
Oct 26, 2008 | Bose Lifestyle 20 System
Bose audio system error codes 31,33,30?
The trunk mounted 12 disc magazine changer with the Bose audio system is made by Pioneer. Mine is a bit flaky too so I try to avoid unnecessarily swapping out the CD's. Those error codes can mean anything from a defective/wrong disc type (it does not support MP3 discs), a disc being upside down, or forgetting to close the magazine loading door. It can also indicate condensation on the laser lens or a system malfunction. There may be a list of error codes in the owner's manual if you have one, I currently don't.
Assuming you have checked all of the possible human errors above, there are aftermarket sellers that claim you can adapt an aftermarket changer to the Bose system albeit with with inferior sound quality to the original system. Bose is typically well-known for it's audio quality. That being said, the other option would be to seek a repair facility that can repair these changers. There are some places on-line that repair car audio that also might be able to help.
A cheaper workaround might be to hook up a portable CD/MP3 player using a cassette adapter. Assuming the cassette player, amp and speakers are good, you would possibly still get fairly high quality sound from the Bose system.
Best of Luck!
SC442299
1996 Oldsmobile Aurora
4.0L DOHC 32V V8
Bose Audio w/ 12 Disc Changer
Autobahn Option
Jun 23, 2008 | 1996 Oldsmobile Aurora
Audi gamma bose CC unit
I just took a 6 CD changer out of my 1993 Audi with a Gamma Bose CC as well as the adapter box. I am interested in selling it (I traded the car). If you are interested in the changer, let me know and we can exchange contact information.
Apr 08, 2008 | Blaupunkt Car Audio & Video
Car Audio & Video Logo
99 people viewed this question
Top OEM Systems Car Audio & Video Experts
xxxxxx xxx
miles
miles
SuperN0va
SuperN0va
Are you an OEM Systems Car Audio and Video Expert? Answer questions, earn points and help others
