Question about Compaq Presario Cooling Fan CPU Heatsink & Fan
Laptop shut down due to over heating within half an hour.
    Genius:
  • 1,127 Answers
Hi
Please check your processor fan is working or not, if no then go the Hp service center for repair the FAN.
Posted on May 20, 2011
My thinkpad t43 26684du screen goes very dim after use (half hour). when i reboot it won't shut down until i remove battery. restarts fine for a while. irun win 7 ultimate all updated.
There is two problem possible for these symptoms:
1st one is due to inverter
2nd one is due to screen backlight lamp (CCFL)
You need technical support. We may need some components to be changed. If you think you can do it on your own, see http://www.laptoprepair101.com/laptop/2007/09/05/troubleshooting-laptop-with-backlight-failure/
Nov 05, 2012 | Computers & Internet
The amp shuts off all the time. Had to reset it, after half an hour it shuts off again. Is there any solution for that? Thanks
The amp is probably in protection mode due to excess heat, a short circuit out at the speakers or an internal problem. My guess is it's heat from being driven hard. Make sure the unit has sufficient ventilation or try turning the volume down a bit.
Dec 27, 2010 | Harman Kardon AVR 235 Receiver
My acer aspire 5735Z wiil not stay charged for more than 1 hour when not one the charger and just shuts off even if battery indicator shows atleast 50% charge, is just a bad battery?
Batteries wear out with use and can be replaced easily with a new one.
If you laptop is more than one year old then most probably the battery is weak and cannot hold the charge. When a battery becomes weak its capacity to hold charge reduces considerably until you have to remove it to start the laptop (with charger only).
You can continue using it until the battery time drops to about 10 minutes. After that, simply replace it with a new one.
If the laptop is new and under warranty, you should contact warranty support asap.
To increase battery life place the laptop on a solid table where there is ample air flow beneath. Heat will destroy a battery faster such as when used on bed or your lap often.
Regarding you question about shutting down even when battery is 50% it could be due to following reasons:
  1. Power Settings within the control panel.
  2. The battery charge drops quickly so that it discharges very quickly when it is showing half. Remember that the indicator is an estimate and does not account for battery degradation over time.
  3. Other issues like over heating etc but please check first two points first.
Feb 20, 2010 | Acer Aspire 5735 Notebook
It overheats within a half an hour of using it. The trackpad is not very sensitive I have to be really forceful to move the cursor to where I need it to be.
If its overheating, suggest it may be due to fouled heatsink, clogged fan or obstructed vents. How do you know its overheating? Does it shut down or have you a thermal monitor alarm enabled in the bios? Laptops tend to get hotter than PC's. Mine reaches 70 degrees without problems.
As to the touchpad, this may be worn contacts, try a usb mouse and see if this resolves the issue.
Feb 09, 2010 | Dell Inspiron 1525 Notebook
My vaio laptop will not turn on. no lights, no nothing.
Its may be due to over heating that your laptop shut down automatically in order to prevent further damage of hardware;clean you laptop by opening it from the back side and blow it with a regular small air compressor blower.
it will solve your Problem
Dec 10, 2009 | Sony Computers & Internet
Nvidia gedorce 8500 gt and the cpu gets overheated and shuts down
well it might be over clocked, but i have a computer with 4 fans and cpu fan and other fans to. though this still doesnt make a difference casue my cpu still heats up. so get a liquid cooling system, expensive i knw but it will keep your computer running, but you coudl also try cleaning you computer out. Like all of the dust and everything
Apr 26, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
LAPTOP NOT TURNS ON
This is probably due to a bad battery or damaged powerjack. Does the laptop work when connected to a plug point?
Sep 28, 2008 | Computers & Internet
Aspire 3610 fails to run for more than a few minutes
does the laptop get very hot ? Aspire know to over heat.
You also might want to reinstall OS.
May 08, 2008 | Acer Aspire 3610 Notebook
Shutting off
i have the same problem...laptop randomly shuts down, but its even done it within a minute of turning it on so i don't think its a heat issue. Sometimes it'll run for over an hour with no problem and never shut down, but other times it randomly shuts down sometimes within a minute, sometimes maybe 10 mins, sometimes 30 mins or more ...its maddening! i'd love to find a solution if anyone's found one. Thanks.
Apr 22, 2008 | HP Pavilion dv1000 Notebook
Compaq Presario Cooling Fan CPU Heatsink & Fan Logo
141 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
