Boot device not found please install an operating system on your hard disk Hard Disk - (3FO) F2 System Diagnostics For more information, please viit: www.hp.com\go\techcenter\startup
    Genius:
  • 1,127 Answers
Hi
I think your by mistake you format Primary Driver, that way the problem will happen, please install the windows installation CD and make the primary drive with NTFS, and install the windows,
Good Luck
Posted on May 20, 2011
Upgraded to windows 10. Getting error messages: boot device not found. Please install an operating system on your hard disk. Hard disk 3FO. Please help.
There have been lots of issues with W10 which is why I am not upgrading any of my computers. If they run fine with the original software there is absolutely no reason to change.
If I were you I would get rid of W10 and run the computer so it restores all software back to original factory settings but when you do this you will lose any saved files or software you have loaded such as security software.
Alternatively you can soldier on pulling your hair out trying to solve all the issues you will run into because of the W10 upgrade.
Jan 03, 2016 | HEWLETT-PACKARD G71340US Laptop
When I turn on my hp mini 110-3100 I get this message: Boot device not found.. Please install an OK on your hard disk. Hard disk (3FO) It will run the start up test(f2) It will run the Run-in test...
Look on the back of the unit. You;ll need a small philips head screw driver. Often the drive is removble with one or two screws. Check YouTube for video.
Nov 15, 2014 | Computers & Internet
Compaq desktop persario xp non-system disk or disk error
This means that the system identifies the hard drive on your computer as one that is not bootable, in other words, it does not contain any operating system, or it does contain one, but the disk format is not recognized by the system. For example, Windows operating systems only identify two types of disks and that is DYNAMIC or BASIC. If a Hard disk has an operating system and has been converted to DYNAMIC, you can not start any operating system on it. Only BASIC disks can be used to start an operating system. Here is a solution for you... Get a copy of the operating system you are using and boot the computer from it. Press F2 when booting and go to the system BIOS where you are going to configure the boot order or the boot sequence and make the CD drive the first booting device, so that the system can boot from the CD. If you receive a message stating that the SETUP can not find any hard disk installed.... then there must be a problem with the Hard disk format. Remove the hard disk and connect it to a desktop computer as a slave. This will enable you to see the Hard disk as a removable device on the 'My computer" menu.Go to start, right-click on "My computer" and select "Manage". This will take you into computer management console, then select "Disk management" and this will bring all the disks and drives connected to that computer and all their respective information. Click of the drive that you just connected and check on the bottom middle column, the type of the disk whether it is DYNAMIC or BASIC. If it is Dynamic, then you have to covert it back to basic. Make sure you make a data backup before you do this. This is because the system will delete anything on the hard drive. When you are done, take the hard drive back to your computer and boot from the CD again and install a new operating system. You should be good after this...
Mar 23, 2012 | HP Presario Computers & Internet
Starting my laptop i get this message internal hard disk not found To resolve this issude . try to reseat the drive "which i did" no bootable devices stike f1 to retry boot , f2 for setup utility...
Hi ajmedina89,
If your system wont boot up and has a no "bootable devices" message, is often caused by a defective harddrive. I recommend to try a different HDD before replacing your system HDD to isolate the issue.
Hope it helps.
Thank you for using FixYa.
Apr 25, 2011 | Dell Inspiron 1545 Notebook
HP Pavilion dv7-2277cl Notebook PC When I turn on the power I see The hp invent screen then: I get BOOT DEVICE NOT FOUND Please install operating system on your hard disk. Hard disk - (3FO) in system...
ever heard of HP.com
ever heard of HP.com media install discs. or usb install sticks
ask HP, on HP can fix a bad OS,
its there system
there , OS, HP makes up there own matching windows 8 system disks that only run on your DV7-2277cl
do no use other disk.or it will fail,yes take it to town if this is not clear.
start hear,
get your disks from HP only or you will be sorry.
I promise. (there are exceptions but is GEEK level ,im not teaching ever)
BINGO HP.com (hard to remember no?>)
http://support.hp.com/us-en/products/
Mar 26, 2017 | HP Pavilion dv7-1132nr Notebook PC
Boot device not found Please instal l an operating sistem on your hard disk. Hard Disk - (3FO) F2 Sistem Diagnostics Foe more information, please visit: www.hp.com/go/techcenter/startup
please go to the bios setup by pressing F2. then check your sata hardisk if detected. if not, remove the sata hardisk and use it as external by using external sata case adapter. then plug to the other pc and check if spinning or detected by another pc. once not detected or spinning change your sata hardisk. but if detected, there is a problem on your dv6000Z notebook.
Feb 01, 2011 | HP Pavilion dv6000z Notebook
Dell inspiron 1525 cannot find hard disk
hi there !
-remove the hard drive of the computer and remove the cdrom drive
-after removing the hard drive and cdrom drive; return them again
-turn the computer on then press F2 and look at the device info
take note of the information
Hard drive =
Fixed Bay Device =
-run diagnostics on the computer
-turn off the computer; while the computer is off, press and hold the Fn key then press the power button at the same time, once the computer is on, let go of the keys
*if you get an error 0141; and the status on BIOS is Hard drive = none then it is a faulty hard drive
cheers !
Oct 28, 2009 | Dell Inspiron 1525 Notebook
No operating system found
If the error message says "No operating system found" it is most likely a faulty disk controller or a faulty hard disk.
Reseat the hard disk, if this doesn't work you need to test the hard disk another way. Remove the hard disk and connect it to an USB hard disk adapter and connect it to a working computer's USB port. If this computer sees this as an external hard drive and you can open the folders and files then the hard disk is OK and the fault is the disk controller on the the 4115c laptop.
If the hard disk is not detected then the hard disk is faulty. You need to install a new hard disk, install Windows and the laptop's device drivers and programs to get a working laptop again.
Sep 11, 2009 | Computers & Internet
Got a laptop (ei systems) that i cannot properly start up, and access vital information which i just cant lose (court stuff etc). When computer turns on it say Boot device Hard Disk C / ...
try to boot your laptop from hard disk
reset your laptop & press f2 or del to go in cmos setup by press f2 or del key then afer go in boot manu select there is hard disk in a frist boot divice then save the settings by press f10
try this
may your problem will solves
Mar 23, 2008 | Computers & Internet
Computers & Internet Logo
672 people viewed this question
David Payne
David Payne
