Question about Technics SL-1210 Turntable
Turntables voltage been changed now wont turn on
What will i need to get? just replace all the fuses?
internal fuse and plug fuse?
[email protected] is my email thanks!
  • hendrix802 Feb 22, 2009
    New Friend:
One of my turntables target light was pulsing, so STUPID me did what I read on someones comment that the voltage should be switched to 110 V instead of 220V. DON'T EVER TRY THIS !!! after that switch all i heard when powered was a BOOM. I thought that the whole tt was dead. Fortunately only one fuse was burned so I had it replaced and the turntable is fine now.
I was so close to ruin the transformer.
IF YOU ARE NOT SURE WHAT YOU'RE UP TO PLEASE ASK FOR A PROFESSIONAL OPINION !
Cheers !
Posted on Jan 04, 2013
    Problem Solver:
Have you switched the voltage switch over underneath the turntable plate
Posted on Aug 16, 2008
SOURCE:
Lg grill wavedom model no MG-6644B
It all depends which fuse is it the plug fuse as used in the UK or the internal fuse? If it the internal fuse either the magnatron has gone S/C or the high voltage rectifiers have gone S/C and will need replacing the the indentical components
Aug 31, 2014 | Microwave Ovens
Power problem, CDJ wont turn on propperly as it is from the US and i live in Birmingham UK
The step down adapter should work fine as long it supplies the voltage and any other ratings shown on the turntable power supply indication pannel. However the problem might already have happened. If the fuses were before the power entered the mains transformer of the unit, then if they were set to blow above the USA voltage then things could be OK. However if the the fuses were in the secondary output from the transformer then the mains will have caused possible damage to the transformer. Maybe even elsewhere.
Jan 15, 2013 | Pioneer CDJ-800 Turntable
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    Hello i need some help,i have pioneer 800 mk2 cdj i buy from usa but im live in london so difirent pawer supply here i bought the converter but try connect and its not showing nothing maybe the problem...
    You can have a fuse problem only in you plug it diectly to 240V, the UK voltage. Check that the converter is a step down transformer, 240 to 110 volts. The system should work with 110Volts. If everything is ok, then you blew the system´s powersupply with the 240Volts. that is difficult to solve.
    Dec 08, 2010 | Pioneer CDJ-800MK2 Turntable
    I have two technics 1210s. I was away on holiday for 3 months and when I came back neither would switch on. I have changed the fuses and still neither turn on. Any ideas on what could be the problem?
    i got my turntables repaired by these guys www.technmics1210repair.co.uk
    i did they made my setup work like new so im going to spread the word.
    give them a shot
    Apr 08, 2010 | Technics SL-1210 Turntable
    No power when i turn on my mk3 turntable
    Check the internal fuses. There are two. You have to strip the unit down to get to them.
    This video will show you what's involved:
    http://www.youtube.com/watch?v=CDYgjwdQ55s&feature=channel_page
    Aug 17, 2009 | Technics SL-1210 Turntable
    Hi i bought my technics 1210mk5's in america and when i gor back to ireland i had them converted to 220v as this particular model is not dual voltage. The 1210's worked fine then when i used a plug pin...
    i had my decks fixed by these guys they are in london.
    thier websites is www.technics1210repair.co.uk
    they do technics turntable servicing
    check them out.
    im only spreading the word due it i had my decks fixed their and i am so pleased im telling everyone so they can get the same service i did, rather than paying over the odds at some **** toster repair shop.
    alan
    Jul 10, 2009 | Technics SL-1210MK5 Turntable
    No power
    With a voltage meter, open the table back up to where the fuse is under the on off switch. With the table plugged check the voltage meter check the incoming ac prongs for 20V. Also, the 1210 has a voltage switch under the platter to the left
     a little hole for which a flat head screwdriver is needed to switch the voltage. If you live in the UK or outside od the USA it should be on 220V, IF YOU LIVE IN THE USA, IT SHOULD BE ON 110V. If your electricity is 110/120 and its on 220, the transformer is most likely fried. If your electricity is 220V and its set to 110V , then its not getting enough current. Its possible the transformer could have gone bad, with no smell of burn or sign of damage. Also, check board with all the capacitors on it around the motor, check fopr any leakage...
    If service Technics for 15 years and sometimes i'll se voltage issues I've never seen before.....
    Oct 27, 2007 | Technics SL-1210 Turntable
    Turntables
    Your power transformer blew. The fuses in these models don't offer much protection, when it comes to more serious power surges. And the only other thing that would be blown is the transformer - a common issue. You can purchase parts for this model HERE, however, I do not suggest replacing this part yourself, as it is a little tricky, and you may damage your unit ever more, if not done properly.
    - DJ PRO AUDIO
    www.DJPROLAB.com
    Jul 14, 2007 | Technics SL-1200MK5 Turntable
    Technics SL-1210 Turntable Logo
    392 people viewed this question
    Top Technics Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Ben Armstrong
    Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
