Question about Panasonic Televison & Video
How to connect bose wave radio to a digital tv
SOURCE: BOSE WAVE RADIO/CD
I've repaired about 10 type Bose AWRC3x (the radio/cd model with lift up lid and top controls). If the cd won't play or skips, try cleaning the lens VERY carefully with a cotton bud with some isopropyl alcohol. Let it dry then try again. This will help in about 1/3 of cases.
After that, a new laser unit is needed. They cost around 15 pounds,30 dollars, (Type SFP100s with 13 pin connector made by Sanyo). You need to have some electronics experience to take the case to bits to get the laser deck out, change the cd laser and reassemble. Basically, DISCONNECT THE POWER! Remove the 3 screws on top, turn over and carefully prise the front of the base away from the top cover with a table knife or similar. Lift off the top cover - be careful with the lid ribbon! The deck can be disconnected from its ribbon cable and wired connector very carefully. Take the deck to bits and fit the new laser head (take photos if you think it will help). Remember to unsolder the shorting 'blob' of solder which protects the new laser from static till its fitted.
On the bright side, there is no tracking etc to set up, that's all automatic so usually they work like new with a new laser fitted. I have to say this is the weakest feature on the Bose CD radio, the actual electronics rarely gives trouble.
Hope this helps Steve O'Donnell
Posted on Mar 20, 2008
  • 20 Answers
SOURCE: Non-working CD in Bose wave radio
Try replacing the battery on the bottom of the system - alot of people miss it because you have it constantly plugged into the mains, but replacing this (somehow) re-sets the system, and 9 times out of 10 solves the issue.
Posted on Dec 31, 2008
BillB-SA
  • 2761 Answers
SOURCE: My 10 year old Bose wave radio quit working.
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Posted on May 19, 2009
DigidocTN
  • 22 Answers
SOURCE: Bose wave radio will not power on. used to work
I repaired mine recently. Check transistor Q4 for an e-b short. The replacement costs less than $1.
Posted on Jun 27, 2009
  • 21 Answers
SOURCE: where is the fuse for bose wave radio
Upon opening the Bose Wave radio.. 4 screws only from the bottom. The fuse is located at the top side of the PCB. It is a small fuse. Kindly inform me if you need a picture. I am repairing one now
Posted on Aug 13, 2009
Can I set my Bose Wave up to utilize as a speaker system for my TV?
Yes...it should be able to talk to the tv via optical cable and switch itself off and on via the tv remote.sometimes they only used RCA connecting cables I.e. Red and white audio instead of lazer or hdmi pass through.
Feb 01, 2016 | Bose Wave Radio
Need to replace plastic lens over digital clock display on bose wave radio II
Sorry, that's a job for the Bose service department. I doubt anyone else has that part.
Jul 09, 2014 | Bose Wave Radio II
What does the BoseLink input do? Can I use it to connect my Bose Radio to my HD TV? It has a USB port for audio sound output. (I can't seem to find the manual that came with my Bose Radio)
yes, buy a 3.5mm to 3.5mm cable. It looks like a headphone jack on both ends. Plug one end into headphone jack of HDTV and plug the other end into the 3.5mm Audio In jack on the Bose Wave. Boselink input is for other Bose components.
Mar 02, 2011 | Bose Wave Radio
Can we connect the bose radio to a panasonictc-p42c2tvso music programs on the tv will play through the bose speakers
I connected mine to our tv through the audio jacks and not only did the sound not come through the bose speakers, I think I fried the curcuits---The radio no longer works--nothing happens when I plug it in. So don't do it . This bose radio is over 12 yrs old---the tv is new---that could be it
Jan 13, 2011 | Bose Wave Radio
Would like to connect Bose Acoustic Wave II sustem
If your TV have audio output ( RCA or any kind ) then you can hook that up ( you can buy the cable from radio shack ) then to BOSE audio input w/c is the AUX input.
Apr 26, 2010 | Bose Wave Radio
Want audio from tv to wave radio
I have the same problem. did you ever get this issue asnwered.
Dec 28, 2009 | Bose Wave Radio
I want to have TV sound come thru myBose Radio what connections do I need and where to connect
Assuming there's stereo rca outputs on the back of your tv, you just need an rca audio cable to run from the output of your tv to the input on your Bose.
Aug 02, 2009 | Bose Wave Radio
I have a Bose Wave, Multi CD changer and wish to output my TV audio to it. Bose reps say all I have to do is connect Red & white audio cables to the AUX input on the CD changer and to the TV's Red...
The only other solution for this would be to connect the red and white RCAs directly to the source that you're trying to hear. (i.e. cable box, dvd player etc.) I have seen a convertor that will go from digital coax to RCA, but I'm not sure how reliable it would be. Plus a good one would be very expensive for what you're trying to do. You could also get an RCA switcher. Connect all or your components (cable box, dvd etc) to the switcher, and an RCA output to the Wave system.
Jun 18, 2009 | Bose Wave Radio
Bose Wave Radio with non-Bose speakers.
bose cd will not work but radio is fine
Jul 28, 2008 | Bose & Wave& Music System
Televison & Video Logo
100 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
