Question about Compaq Presario 1400XL340 Cooling Fan Laptop Cooler
My compaq presario become very hot within few miniute and then it is automatically shut down.what is its harm and how this problem can be solve.
    Problem Solver:
  • 12 Answers
It is overheating. It may be a few things, check the vents and make sure they are not blocked by anything (sometimes dust can block them as well). Also listen and feel at the vents to make sure you fell air blowing out (if not the fans may have died out).
The fact that it shut down means it is trying to save the components before they burn out. You should be able to turn it back on once it cools down enough. You can also use a fan to blow air through the vents to speed the process. If it continues to shut down, it will burn out eventually if not repaired. You can get by for a while by using a fan base (you sit the laptop on it and it has fans blowing air on it to keep it cool). You can purchase this at any bestbuy or staples.
Posted on May 20, 2011
How do I set a Compaq Presario SR1403WM back to Factory settings
Step 1:
While many problems with Compaq Presario computers can be solved by less drastic means, there are times when the best course of action is to set the computer back to its original factory default state. Issues with persistent viruses or spyware often require this drastic step, as do problems with a corrupt operating system. Learning how to restore your computer to its original state is an important troubleshooting tool.
Shut down your computer and restart it. Watch for the Compaq logo, then press the "F1" key to enter setup. Press the right arrow within setup to go to the Boot menu. Press the down arrow to access the "Boot Device Priority" option. Change the first boot device to CD-ROM by pressing the down arrow until "CD-ROM" is displayed. Eject the CD tray and place the recovery CD that came with your computer into the tray. If you do not have a recovery CD, you can order one directly from Hewlett Packard. Shut down and restart the computer. The Presario will automatically boot from the CD and begin the recovery process. Select the operating system your computer shipped with. Many Compaq recovery CDs support multiple operating systems, so be sure to choose the operating system your computer shipped with. Insert the operating system CD when prompted. Enter the license key for the operating system when prompted. The license key is typically found on a small tag located on the top or side of the computer.
Mar 10, 2013 | Computers & Internet
Compaq presario CQ40 is overheating within 30 minutes. Although cooling fan is working (fan sound is coming)
Laptop needs cleaning! Only experienced technician should open laptop, clean cooler and change thermal paste. This will solve the problem and save laptop from serious damage.
Jan 13, 2012 | Compaq Presario Notebook
Startup gives the following warning: a cooling fan problem is detected..
Replace the cooling fan
If you do not the computer gets hot within minutes and will shut down automaticly
Feb 26, 2011 | HEWLETT-PACKARD Compaq Presario CQ56-110US...
No power on will shutdown
Hello
First of all press ALT+CTRL+DEL and start Task Manager, there is probably some application (or other process) that is not reponding. You can kill them to let the shutdown continue, and know what is causing the problem and maybe find an update for it.
Also this means that your computer has not been rebooted properly since the installation of important system updates. If you have "Automatic Updates" scheduled on your machine, these updates could have downloaded and installed without your knowledge. To fix this issue, let the updates finish installing, reboot and then shut down your computer as normal.
Click "Start."
Click "Windows Update." Click "Install Updates" to begin the installation of any updates that have been downloaded to your Compaq Presario. When the "Restart Now" button becomes available, click it once. Your Compaq Presario will shut down Windows, finish installing the updates and then reboot your computer.
Click "Shut Down." Because the updates have finished installing and have been installed properly, your Compaq Presario will now shut down normally and will not immediately boot back up.
Feb 17, 2011 | Compaq Presario 700 470024-192 Notebook
My Compaq Presario CQ50-103NR Notebook PC keeps shutting down. Sometimes right away sometimes after a few minutes. The left side of laptop seems to get hot while the right side stays cool. Can You please...
Hi:
You most likely have a heat problem, as you have realized. To fix the problem, your heatsink/fan assembly needs cleaned, and then reinstalled with new heat sink compound. Some disassembly is required, so this isn't an easy job. If you go to a reputable shop, and tell them what you want them to do, rather than just tell them your laptop is shutting down, you should get it done for a fair price!
Apr 23, 2010 | HP Compaq Presario CQ50-103NR Notebook PC
My laptop becomes too hot & it shut downs suddenly when I use any big applications like turbo c or playing any game or when I try to write any cd through it. After few minutes its fan starts spinning very...
Sounds like you have a hardware fan & vent, the CPU shuts down when it gets too hot.
Check the fan, it should spin freely, clean the dust off the fan and heatsink assembly. Replace the fan if necessary.
When you use the laptop, make sure none of the vents are covered.
May 01, 2009 | Compaq Computers & Internet
Its automatically shutting down, the left side is so hot! how can i solve this?
Your heatsink is clogged with fluff and thus overheating - the only easy fix is take it to a servo station get the tire inflater and back blow thru the heatsink exhaust port to get the fluff out of your heatsink. If this can't be done your unit needs a strip down for heatsink service and clean
Mar 07, 2009 | Compaq Presario 700 470024-192 Notebook
COMPAQ CQ60-104Tu goes blank... improper shutdown
It might be a problem with the computer. I would advise going back to where you bought it and returning it to either get a new one or a different one. Glad I Helped!
Jan 28, 2009 | Compaq Presario Notebook
Compaq Presario 1400XL340 Cooling Fan Laptop Cooler Logo
196 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
