Question about Simplex Kaba Ilco Unican 1000 keyless lock
I changed the batteries then initialized it and it won't work. I can access it with the emergency card. I tried to reprogram it and it always says can't establish connection with the lock. It has worked in the past.
  • 963 Answers
The Unican 1000 locksets are pushbutton locks and do not use a card for access. I think you may not have referenced the proper model that you are having problems with.
I'm including a link to Kaba Ilco products page where you can research your model of lock:
http://www.kaba-ilco.com/access_control/products/eplex.aspx?id=6
You may find that your lock is under the E-Plex series, which use card access.
Also to be found on that page is a link to "Literature and Support" which you can expand to take you to the proper information grid for your model of lock.
The Literature Grid contains links to PDF files which have headings for the Manual, Parts List, Instructions Charts, etc. The Instructions Charts may be of most interest to you because they contain troubleshooting information.
In order to view these PDF files,, you will need Adobe Reader installed on your computer. There is a link on the Grid page to Adobe Reader if you don't already have it installed.
Near the top of the Literature Grid page you will find a link called "Contact Us", and under that link you will find links to Customer Service and Support and Technical Support which will allow you further assistance by Kaba Ilco support, either by email or by calling them toll-free.
I hope this information helps. Good luck!
Posted on May 21, 2011
My phone has the dial pad superimposed over the home screen and will not let me make calls except emergency calls. I can't access anything. How can I get this off.
This one is a call for your provider as to how to turn it off. It is locked in a feature that allows you to dial emergency but nothing else. Usually bill related.
Jan 05, 2015 | Samsung Cell Phones
My remote car starter from autostart on a grand am 03 won't start or locks won't work after it died for about a week then changed the batteries
Check to be sure the new battery is a good new one, they set on the shelves for some time ya know. Then make sure it goes in the correct direction.Then refer to your owners manual if it needs reprogrammed.
Feb 18, 2013 | Cars & Trucks
Locked in emergency call screen
Sounds like dust on the sim card or phone needs to reboot. Switch phone off, then remove battery and sim card. Wait half an hour - have a cup of coffee :) Make sure sim is clean and refit. Refit battery and power up. Hopefully that will fix it.
Feb 17, 2013 | Samsung Galaxy I9300 SIII Factory Unlocked...
Server won't start
I would first try reseating (removing and putting back) the SCSI card. If it is not able to reseat (built into the motherboard) you can always try to get into the BIOS diagnostic and run a system diag on the machine.
regards,
Mike
Oct 23, 2012 | HP Compaq ProLiant ML350 G5 Server
My 2006 Dodge Dakota remote Key got wet now it won't work Ive changed the Battery But still Wont work ??
tou can try letting it dry out/replace but it will need reprogramed either way
Jun 16, 2012 | Cars & Trucks
I have sony h55 model camera. i insert the battery in inside of camera. but not working. Inside lame is lit. what's Problem?
Yes, if during initialization or other major function the power is interrupted, it can wipe out the internal logic for the camera. If that has happened, and the camera won't even power up, there is no known repair that can be performed other than through a licensed repair facility.
However, if your camera does power up and you damaged the flash card only, then it may be able to be low-level formatted, then re-formatted by your H55.
Feb 14, 2012 | Sony DSC-H55 Digital Camera
2008 Mazda 5 key fob battery changed and it still won't work. how do i fix it?
I have taken a GM key FOB apart before and found a bad soldered connection. If that doesn't work, people sell them on Ebay all the time, look up how to program on the web and reprogram it to match your vehicle.
Jan 05, 2012 | Mazda Cars & Trucks
Our KX-T7633 phone at work will not display the date or time. I have tried to match the settings with the other phones in the office, but I still cannot get the date or time to display! Please help!!
I'm guessing one of two things. Press the TRANSFER button or the INFO button and look at the display. The ugly thing is it may be you don't have a top line at all :-(.
We have one port that won't display top line and one that won't PROGRAM! I have yet to find out why and the strange part is it's in software, not hardware, because a station card swap didn't fix the problem. I guess Pana tech support would say "initialize and reprogram". I've not been that desperate yet.
Carl
Aug 22, 2011 | Panasonic KX-T7633 Corded Phone
Simplex Kaba Ilco Unican  1000 keyless lock  Logo
165 people viewed this question
Top Simplex Locks & Locksmithing Experts
Frank Mangiapane
Level 1 Expert
Michelle Balcom
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
