Question about Legacy Audio LEQ4 7-Band Car Equalizer
I have a problem hooking up a eq because all the wire does not match the wire harneess on my 2003 ford escape i try to hook it up but it made buzz sound.
I have a 2008 ford escape 2wd 3.0 and i put a new starter on it and when i reconnect the battery the starter starts to wind and i don't have the key in the ignition. What did i do wrong?
there are two large bolt electrical terminals on most starters one has nothing on it ,thats where the battery wire hooks up + and the other (looks just like other one) has a small bent piece of metal that connects to starter under it's bolt that's Not where you hook battery , if you did hook it there the starter would run as soon as you hook up battery
ooh and the two bolts and anything connected to them can not touch each other or anything else
try looking at that
Oct 30, 2013 | 2008 Ford Escape
Battery is DEAD on 2003 Ford Escape! Door key (using an actual key) unlock is also motorized, which needs battery juice. I can't get into this car! I thought about putting jumper cables on the sta
Open the door manually with the key!
Many Ford Escapes have power door locks as standard equipment. This system consists of a lock switch, lock actuator and wiring harness. When you depress the lock switch, it sends an electronic signal through the harness to the actuator. The actuator moves an internal piston that either pulls the actuator hook down or pushes it up. The actuator hook connects to the lock rod, which either locks or unlocks the door, depending on which way you push the lock button. While this system won't work with a dead battery, the mechanical lock system remains unaffected by electrical power loss.
Insert the door lock key into the driver's door lock.
Turn the key counterclockwise one quarter turn.
Pull the door handle up until the Escape's door opens. Once the driver door is open, simply open the remaining doors by pulling the interior door handles until the doors open.
Aug 13, 2017 | 2003 Ford Escape
My horn will not work i was told it was the ground wire for the horn, where is in located? I have a 2003 ford escape
Most horns do NOT have a ground wire but are grounded by the fact they are bolted to the car chassis. Remove the mounting bolt and clean the surface area with a wirebrush. Reattach and see if that does the trick. Also, a simple circuit tester light will tell you if you have power to the horn. Hook it up to the lead wire, connect the end with the clip to a GOOD ground and have someone press the horn button. If the light, lights You've got power and the horn itself is the problem. Replacements are plentiful at your local salvage yard.
Nov 18, 2010 | 2003 Ford Escape
O5 Ford Escape I have to change the Wiper motor plug and the wires on the new plug are all black. I need to know which wires hook where. I need a wire diagram
The plug on the new harness is numbered.(look at the body of the white plug ) The Wires from old one are colored. they go together like this.
1 is blue and orange
2 is black and pink
3 is black (ground)
4 is Black and white
5 is Dark green
Aug 13, 2010 | 2005 Ford Escape
I have a 2003 ford escape with the airbag light on, the code that came up when hooked up to a diagnostic was code 44, what does that mean??
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Common fault on FORD
Usually due to a poor connection in the YELLOW PLASTIC CONNECTOR underneath the passenger seat.
Just push it together properly and it should clear the AirBag Light
Jun 04, 2010 | 2003 Ford Escape
Where can I find the colour code for the wiring of a radio in a 2001 ford transit
the power feeds go to 1 block
get a test lamp and find the
switched live = goes to red
constent live = goes to yellow
ground earth = goes to black
speakers and dash display to 2nd block
speaker leads are matched in coloured pairs , use 9v battery to each pair to track speaker location, will buzz when hooked up to matched pair
Dec 04, 2009 | Car Audio & Video
How to wire an eq to car stereo without an outboard amp?
no those wire is not for speakers out put that for signal in put only if there is rca jack follow the instruction and run your cable if your dont know dont guess you will burn unit audio out put if install wrong
Jun 28, 2009 | Power Acoustik PEQ-70 7-Band Car Equalizer
Abs light troubles
Possibly have a bad speed sensor or something else. You will need to have it hooked to a computer to find out what is going on with it.
Jun 14, 2009 | 2003 Ford Escape
Equalizer doesn't turn on
hookup the remote wire of your EQ to that of the HU or just simply connect it to the positive line but it would make your EQ powered ON all the time. That remote wire of your EQ is to get a trigger signal from the HU so that it will turn the EQ "on".
Apr 20, 2009 | Power Acoustik PWM-19 4-Band Car Equalizer
Legacy Audio LEQ4 7-Band Car Equalizer Logo
Top Legacy Audio Car Audio & Video Experts
Mark Skinner
Richard Lukszys
Richard Lukszys
Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
