Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Hi when i on the t.v after 10mins the tv would switch of f so i would turn main power off and switch it on again then it will go about 15 -20 mins then it would go off again
  • 998 Answers
That problem is commonly cause by a weak power supply.If you open the back of your tv try to follow the ac cord it is connected in the power supply, then try to look for a swollen capacitor it is easily seen because of the oil that spilled on the pcb then replace the capacitor, but you should check the polarity before replacing it.
Posted on May 20, 2011
Onida 14" slim 150. When I on the tv it
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 17, 2014 | Televison & Video
Interior lights stay on wile i'm driving my 2005 lincoln navigator
Only one bad door switch should do that
The 20 min time out is the GEM or Body Module,
which is normal only because you have a bad switch,
otherwise it goes to sleep when either front door opens
Put radio on & open a door,the radio should go off
& kill the time delay if no issues exist
Feb 05, 2013 | 2005 Lincoln Navigator Luxury
Hi I have an LG 37LC55 which works fine with scart no problem but when I am using hdmi after about 5-10mins the screen scrambles and goes green, purple, yellow but sound still works when I switch it off...
my freind i think it is not a problem.maybe it is from the device connected with tv hdmi try another device or go to system setting of the device to change the video format(try 1080i)
Jan 14, 2013 | Televison & Video
My weslo cadence 850 run's for about 10mins. and then cut's off, the 15amp pin sticks out and then I have to push it back in, then wait about 5 mins. so I could restart it again. Can you help
HI,
Asu mentioned there is some problem with the motor. The 15amp barker breaks the circuit because the motor consuming more power that the desired level.
There will be two carbon brush on the motor on its rear sides. Fist of all replace these carbon brushes. Some time problem will be solved. If then also the problem remains you have to replace the Motor. Hve add the picture of carbon brush to know How its look like.
Ajin
Jan 19, 2012 | Cadence Exercise & Fitness
It green screens after 10 mins
Are you using hdmi cable. If so your hdtv needs to have it's hdmi port reset .First unplug everything even the TV and xbox. Then disconnect everything and unplug every thing from the wall outlets. Then plug the TV back in and hook everything back up. The HDTV even with the power off can have it's hdmi port bumped so you need to unplug it to reset the ports.
Thank you
May 09, 2010 | Microsoft Xbox 360 Console
My converter box will not turn on. The light stays red. i plug it in and it lights red but it wont turn on it stays off and i use remote and i manually push the power button but it wont turn on!!
TRY
Unplug receiver.
Leave for 10mins.
Plug in again.
Wait another 10 mins.
Press the hand control stand by button.
In a few minutes the light should turn green and start options should appear.
Good luck. This works when my HD box freezes.
Feb 02, 2010 | Televison & Video
Will not power up. Stays in standby mode.
these particular tvs are very sensitive to voltage changes spikes etc.first turn off main power switch wait at least 30 sec if standby come on wait another 30 then turn off main power again and unplug tv for 1 min then plug in turn on main switch wait 30 sec then turn on tv with remote resets system.then buy a ups and always wait at least 30 min after turning tv off to turn back on if not causes power failure and after each press of power button wait 30 seconds before trying again lmk good luck
Jan 08, 2010 | Hitachi 42HDS69 42 in. Plasma Television
Machine is locked
turn it all off at the mains leav 10mins and start up again
Sep 29, 2009 | StarTech.com StarView SV211K 2-port KVM...
Telly turns itself off
Hi there!
Have you checked for loose connection on the mains plug wires or perhaps a faulty mains adaptor. Otherwise it can be dry joints in the power supply or perhaps capacitors which have failed. If not sure refer to a repairer. Good Luck,JUS004
Feb 24, 2008 | Televison & Video
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
359 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
