Question about Fujitsu Siemens AMILO Pro V2000 Notebook
I installed windows 7 to my laptop and now the fn f1 button to get my wireless turned on doesnt work i need the drivers for it ??
  • Fujitsu Siemens Master
  • 4,924 Answers
Yes you need to download the drivers for wireless card from the manufacturer's site and after that will work ...The function itself its still working ..but it has no driver to work with ..In case it will not work try the button for enabling wireless or try to enable the wireless from the task-bar tray or from network folder ..or from control panel ..
If you did not find the card in any of these places take a look in device manager (click right on computer and select properties and device manager ) and in there look under network devices and see if it is proper installed or not ..If it has issues will appear in yellow with an ask sign on it ..
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/lifebook/
this is the link for FAQ for this model ..
http://support.ts.fujitsu.com/Download/ShowFiles.asp
this is teh link for drivers.
The issue is that there are no drivers for windows 7 ..but download teh driver for windows xp ..and before installing open the folder and click on the executable right ..(click)
select properties and open the compatibility ..and in there select to run in compatibility with windows xp sp2 or sp3 and apply ..After that run the driver and if it says it can load it ...look and select to run it in compatibility ..
Posted on Dec 17, 2011
Fn f1 not working
What was the old OS? Maybe it is to do with the old OS or have you loaded the mother board drivers?
Feb 19, 2014 | Sony VAIO Computers & Internet
Hi, i have a fujitsu siemens v6535 with windows 7 ultimate & my wirless switch doese'nt work, it may be broken, i tryed every way to turn it on from windows(fn+f1 & other ways) ???? how ca
Have you tried turning it on manually? Look on both sides and in front of the laptop for the switch.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
May 10, 2012 | Computers & Internet
Hi! All i have Amilo li2727 and using windows 7. my wireless net device doesnot want to turn on what must i do.
Normally there is a switch on the side or front that turns the wireless on. The FN function key located at the lower left portion of the keyboard toggles the wireless on and off if the switch is on. Normally you would Press and Hold the Fn function key then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it will have the icon of a tower with the wireless signal )))).
May 06, 2012 | Computers & Internet
Wifi not working
Make sure that driver is installed properly. If it is, check for wifi switch. Make sure it is turned on. In some laptops do not have switches, they use the functions keys to turn them on. Use Fn+F2 or Fn+F3. Also, make sure that you just have one wireless utility activated in the computer. It is more advised that you use the Windows Wireless utility which is more compatible with most types of routers.
Lastly, check your wireless card and the wireless router if they are wireless a,b,g or n. If the router is wireless n, your card should also be wireless n. If your card is just b or g, it would not work.
Jun 29, 2011 | Computers & Internet
I cant get wlan connection.. I have run windows 7 now many times.. Even if i press buttons Fn+F1 it doesnt work.. What can i do?
Did you upgrade your laptop or pc to Windows 7? If you did you may need a driver for your WLAN that is compatible with windows 7. Check you windows 7 if it is a 64 bit or a 32 bit because you have to download the appropriate drivers. If you are using the default windows version, check device manager to check if your WLAN is working or installed.
Apr 18, 2011 | Computers & Internet
I have got a problem,when i wanna run the wireless on laptop,it doesnt allow me to connect,it keeps saying "turn on your wireless compability" and it says that you can do this by switching on a...
Here the list of FUJTISU SIEMENS-AMILO models and where the wireless switch is located. Hope this will helps. Check what family your laptop belongs to then turn on the wireless swith using the list below:
Fujitsu Siemens Amilo A Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo D Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo K Series ---- Not Wireless
Fujitsu Siemens Amilo L/EL Series ---- Fn / F1 to turn on/off
Fujitsu Siemens Amilo La Series ---- Fn / F2 to turn on / off
Fujitsu Siemens Amilo Li Series ---- Easy launch button (one of 3) on top of keyboard
Thanks for using Fixya.
Jan 27, 2011 | Computers & Internet
My wireless wont turn on on medion akoya E5211 ... i need to turn on my wireless connection switch and dont know how or where it is
I had the same problem so I rang Medion & they told me go to the Medion website and download "Launch Manager" from your driver page. It's a program that turns on all of the Fn keys. Thus making the wireless (Fn+F1) work as well as the brightness (Fn+F8 or F9).
This is the only way to get it to work
Oct 24, 2010 | Medion md40298 Notebook
Hai my y410's wireless is not turning on when i installed the new windows 7 on my y410 which originally came with vista
install drivers that you had for your windows vista for your wireless network adapter.
Hope it works..
Feb 14, 2010 | Lenovo 3000 Y410 Laptop
WIRELESS BUTTON
Somewhere on the laptop should be a button to switch wifi on and off. Most time near the volume controls...
Have you put that one on?
Mar 27, 2008 | Computers & Internet
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
350 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
