Question about Hitachi HTS541612J9SA00 120 GB SATA Hard Drive
When starting the laptop, it says "operating system not found", the hard drive (hitachi hts541612j9sa00) makes a sound like trying to run but not being able to do so. I tried to take it out an externally conenct it to another computer but it is not being recognized. Is this the end?
  • 6,831 Answers
Hi
Thank you for using FIXYA!!!
Before we start thinking about trashing the drive, we can ask some questions, and if the results are negative, it is most likely a spindle failure in the drive itself. Basically this means that the repair cost will be much more than just to replace the drive.
I have written a tip which will be able to diagnose the problem. To navigate to the tip, you will need to click on the link below.
Click HERE.
Just to clarify: The clicking noise i am referring to in the tip does not necaserilly need to be loud, if the drive makes a different sound that it use to make, it is most probably done.
Please do not hesitate to let me know if you have any further questions.
Kind regards
Lock123
Posted on May 20, 2011
    Sergeant:
  • 180 Answers
Hi
Bad news, with sorrow,
When the hard disk make sounds, it says: bye bye..
Good Luck
Error
If you have an external hard drive, you can use software such as Acronis, to make a copy of that drive to save everything in an image. Get a new drive to install in place of the old one. Next you can use Acronis to copy the image on the external hard drive, back to the computer, onto the new hard disk in your computer.
Jul 19, 2013 | Microsoft Windows Vista Ultimate Edition
Whenever i open my laptop it says failure predicated on hard drive hitachi 541612j9sa00(s1).what should i do now?
You should take the computer to a computer repair shop and they might be able to backup any important data from it if you have not backed up. If you have backed up then you may want to purchase a new hard drive, again your local computer repair shop can help you with this and replace your old drive and reinstall your operating system and then your backup data(if applicable).
Good Luck.
May 09, 2011 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
Hi, my laptop stopped recognizing my HITACHI HTS541612J9SA00. on device manager i get two general storage devices, and their properties say that they're both working properly plus they're both located on...
This sounds like a single drive with multiple partitions that's working properly. Just because it doesn't identify the device by name doesn't mean its stopped working. Have you lost drive letters? Also, if it stopped working then you wouldn't be able to boot Windows unless you have multiple drives with some type of redundancy like a RAID array that's mirrored. : ) You can right click My Computer or just Computer IIRC in the later OSs and Manage to bring up your management console. Go to Hard Disk management and check what's active and if you have any drives/partitions that haven't been assigned a letter. This is the place to tell you more about your drives than you probably knew was possible. Good luck!
Feb 14, 2011 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
My disk drive does not work in my Advent 1115C Laptop running Windows 7. I went into the Device Manager and listed under Disk Drive is 'Hitachi HTS541612J9SA00 ATA Device' and I tried to update it but it...
Install it another computer which is running well.If your Hdd run well in that computer ,change the USB cable .If the HDD can not run in another pc you think, you have lost data.Because that Hdd cant run any more.
If the problem is same.
follow the step
R_click on my computer>Properties>Hardware>Device manager>uninstall all the usb hub ,one after one .
After UN install all the usb, restart your PC .
If the problem , is same as before ,
Insert your OS in the cd tray > press Win key + R>type sfc /scannow (please take a space between sfc and front slash)>hit enter .Again you will restart the PC.
If the problem is same please change the Hard disk.
Hope it will help you
Jan 10, 2011 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
I want a converter for Hitachi HTS541612J9SA00 120 GB SATA Hard Drive to usb do you know wich one I need..?
You need a 2.5" inch SATA to USB external harddrive enclosure.
since its a laptop hard drive you need a small case.
for example this one http://www.amazon.com/2-5-SATA-HDD-Enclosure-Black/dp/B0018TCB0O
Aug 07, 2010 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
No hard drive
the hard drive heads have failed you will need to replace the hard drive,, ebays the cheapest to be honest but only search compatable with you dell,, any make hasnt got to be Hitachi
Apr 27, 2009 | Dell Inspiron 1501 Notebook
Hitachi HTS541612J9SA00 120 GB SATA Hard Drive Logo
318 people viewed this question
Top Hitachi Computers & Internet Experts
Fotis Papastamatiou
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
