Question about GE JKP15 Electric Single Oven
My GE P7 oven clock has stopped running, Any suggestions? where can I get an electrical wiring schematic?
4 Suggested Answers
SOURCE: GE P7 Oven
I, too, have lost my manual and none of the timers work. I can never remember how long to run the clean cycle for, but will turn it off as it has been a little over 2hours and your post mentions 1.5hours.
I initiate the cleaning cycle by completing steps mentioned above and then turning the top dial (which has a clean range on it) clockwise until the clean light comes on. I then just time it by my watch to turn it all off. Then I wait a couple of hours before attempting to open the door. Don't forget to take the racks out, they are not suppose to go through the Clean cycle.
Good Luck,
Linda
Posted on Dec 20, 2007
cactus bob
  • 267 Answers
SOURCE: 1960's GE P7 self-cleaning oven
wait untill oven has colled down to room temp and press latch release button and hold in while slideing latch to unlock
Posted on Jan 15, 2009
  • 65 Answers
SOURCE: GE P7 Wall oven had bad thermostat????
IF YOUR HEATING ELEMENT IS GETTING ORANGE HOT, AND CYCLING, I WOULD SUSPECT THE THERMOSTAT TO BE THE SOURCE OF THE PROBLEM. YOU MAY FIND IT HARD TO FIND ONE THOUGH DUE TO ITS AGE.
Posted on Jan 28, 2009
Manual ge p7
You should be able to access the clock from the back panel. Make sure the power is off and you can disconnect the power to the clock motor. Tape off the wire to prevent it shorting out against the case. generally the white wire is the neutral and can be safely disconnected without affecting the clock operation of the oven. Some clocks also control the oven operation. Make sure that you are not disconnecting this feature.
Nov 04, 2013 | Ovens
GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
Feb 12, 2011 | GE 24" Built-in Single Electric Wall Oven...
I have just installed a new electronic control in my JTP45 Electric double oven. (part WB27K5273). I have a schematic, but so far have not figured out why that when I open the door the unit turns off and...
It does sound like a wiring mistake. Check all the connections and the wire colors against the colors on the Tech Sheet wiring diagram (which is normally taped on inside the control panel). Particularly look closely at how the door switch and lock connector is plugged in. You may have reversed the plug.
Best Regards,
Bruce
www.fixyourboard.com
Jun 18, 2010 | GE JTP45 Electric Double Oven
Can't get the GE P7 door lock engaged in order to
have to have a repairman come out and reset the code on the inbord computer not a simple fix i know i sell appliances
May 17, 2010 | GE 30" Built-In Single Electric Wall Oven...
GE P7 Wall oven model JK1905AV only gets warm....
I have a pair I'm trying to get rid of if you're interested.
Jul 15, 2009 | GE JKP50SH Electric Double Oven
Jan 28, 2009 | GE JKP50SH Electric Double Oven
Whirlpool Range GY396LXPB00
shanco, is your clock working at all, does it display. If not, you have a thermal cut out on the back of that oven. This runs through the neutral side of that clock. If that TCO is open, the clock and display will not function. Part number 4451442. Very inexpensive. You can look it up at repairclinic.com for a price. They will have a picture of it. Now I'm going by model number gy396lxb00. You have to remove the back panelto get at it. According to the schematic Im looking at it looks to have 2 red wires going to it. Catriver
Jan 04, 2008 | Whirlpool RBS305PDS Electric Single Oven
GE JKP15 Electric Single Oven Logo
427 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
