Question about Cameras
I was cleaning my psp with a glass cleaning liquid,but vry much liquid came out of it,i have dried my psp with drier then it turned on but it's buttons don't work.....what to do???Help me
  • 917 Answers
You will probably need to open up the PSP and carefully clean all the rubber buttons and button PCB inside. Do not attempt this unless you heve done this type of thing before. Liguid that gets into or underneath the rubber membrane will not dry easily with a drier.
Posted on May 20, 2011
While cleaning with glass cleaner the front of the console is not working
Moisture got in ---- using a hair drier you can get it fully dry. I don't think you burned the system. Maybe a fuse blew cause of moisture . You must of had it on / plugged etc. Water and electronics don't like each other
disconnect power. After dry turn back on hopefully the relay will keep back on
Mar 25, 2015 | Video Game Consoles & Games
Scanner glass
I use warm water with a tiny bit of washing up liquid. I use a micro fibre cloth dip it in the water, wring out until vertually dry and clean the glass. Use a dry micro fibre cloth to dry. Do not use glass cleaner.
Jul 10, 2012 | Epson Stylus Photo RX700 All-In-One InkJet...
My sons psp has a black screen
Without a functional screen, the PSP doesn't have much of a purpose. If the power light next to your screen is off as well, all your PSP needs is a good long battery charge. But if the power light is on and the screen is still dark, a few quick troubleshooting steps can help you get to the root of the problem. If troubleshooting doesn't work, you will need to contact Sony eService through its support site, particularly if your PSP has recently been dropped or had liquid spilled on it.
Step 1Turn off your PSP. Remove the battery pack. Replace the battery pack, making sure that it is securely inserted. Turn the PSP back on. If the screen is still black, continue to Step 2.
Step 2Press any system button. If the backlight is turned off, pressing a system button should reactivate it. If the screen has turned back on, go to the PSP settings menu. Select "Power Save Settings." Select "Backlight Auto-Off." This option automatically turns off the screen if the PSP has been idle. If you do not wish to have this feature active, select "Off." If this step did not solve the problem, continue to Step 3.
Step 3Press the screen brightness button below the screen. This button is marked with a small donut-like icon. Pressing the button will incrementally increase the brightness of the screen. Holding down the button will turn off the backlight. It is possible that this button was accidentally pressed down after placing the PSP in a pocket or a backpack. If the screen remains black after the brightness has been increased to full, continue to Step 4 if your model of PSP is any but the PSP Go.
Step 4Open the top hatch on the PSP. This will eject the UMD disc. Only touch the UMD at the edges, as fingerprints can interfere with the disc's functionality. Clean the surface of the UMD with a clean, dry cloth. Do not clean the UMD with water or any other chemicals. If the disc looks scratched or damaged, this is likely the cause of the screen issue. Additionally, moisture can condense on the UMD if the PSP has undergone a recent temperature change, such as being brought into a warm house from a cold car. If the UMD looks wet, turn off the PSP and allow the UMD to air dry. Wait several hours before trying to restart your PSP.
Dec 27, 2011 | Sony PSP (Piano Black)
Copies leaves lines when put through the feeder,but not on the glass .......have cleaned and sprayed air can everywhere I can think of The Hp Printer is HP 3055 All in One printer
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Mar 16, 2010 | HP LaserJet 3055 All-In-One Printer
Getting a black strip in copy mode on X6575 lexmark printer. No line in print or test mode
Most likely a page was scanned with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
Mar 16, 2010 | Lexmark X6100 Flatbed Scanner
Unwanted verticle line on fax copies
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 560 Plain Paper Fax
I get lines and can't read the right side of copies that I make with the 1270e. How do I fix this?
You have not specified why you can't read the right side of copies and I am assuming that the reason is because the 'lines' are covering the text. I can offer a solution to the lines issue.
Feb 22, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
I have a black line showing up on my faxed documents. I have opened it up, changed the film and re- set it, but the problem persists. The machine is about 5 years old.
Feb 07, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
Printer problem
Does the line appear while copying or printing ?
To isolate the issue try to print a self test page :
1. Press and hold the Cancel button and then press the Start Copy Color button.
2. Release both buttons. The self-test page prints.
If you see lines on the test page then the issue is with the cartridge or cartridge contacts. Clean the cartridge and cartridge contacts inside the printer.
rRemove both the cartridges. Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridge contacts, from the top to the bottom. The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts.
The contacts inside the printer may also require cleaning. Using a clean, dry, lint-free cloth. Gently wipe the contacts, from the top to the bottom.
Reinsert the cartridge and print. If the issue issue persists replace cartridge(s).
If you do not see lines on the test page. Place the same test page on the scanner glass and make a color copy. If the lines are on the copied Image the issue is with the scanner glass.
clean the scanner glass :
Clean the glass and scanner backing
  1. Turn off the all-in-one.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the all-in-one.
  4. Raise the lid.
  5. Clean the glass with a soft dry cloth, or a sponge slightly moistened with non-abrasive glass cleaner or water. CAUTION: Do not use abrasives, acetone, benzene, or carbon tetrachloride on the glass; they can damage it. Do not place or spray liquid directly on the glass; the liquid might seep under the glass and damage the device.
  6. Dry the glass with a chamois, cellulose sponge or soft cotton cloth to prevent spotting.
  7. Clean the white scanner backing with a soft dry cloth or sponge slightly moistened with water, and allow it to dry.
Try a blank copy
  1. Plug the power cord back into the wall outlet.
  2. Plug the power cord into the all-in-one.
  3. Turn the power on.
  4. Close the lid; do not place any paper on the glass.
  5. Load paper in the paper tray.
  6. Do either of the following:
    • Press Start Copy Black to start a black-and-white copy job.
    • Press Start Copy Color to start a color copy job.
  7. If the output is a full/half-black page, or has vertical black lines, the product needs service or contact HP for in warranty replacement.
Thank you .
Silan
Dec 20, 2007 | HP Photosmart C3180 All-In-One InkJet...
Psp will turn on but will not read any discs old or new
Hi BubbasMom,
Bubbas PSP has a problem with either the UMD laser, or the mechanism that moves it back and forth. Open the UMD door and Clean the lens with a Q-tip lightly dampened with Glass Cleaner. Swab it with the dry end after you use the glass cleaner.
If that doesnt fix it. You probably have something jamming the Laser from moving. Sometimes you can clear this by forcing the laser to move some. You will hear it click a few times. Once you click it a few times on way or another. Try a UMD to see if that fixed it.
Nov 21, 2007 | Sony PlayStation Portable (PSP) Console
Cameras Logo
65 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
