Question about Garden
How the h... do i cabnge the blade on the bosch 1582 cutter ??
  • 436 Answers
I am assuming you are asking because you have a CLIC system.
Bosch uses a tool-less blade changing system for its jigsaws that it calls "Clic." The system makes changing blades fast and simple. With the simple blade changing you get with the Bosch jigsaws, it is no problem to change out a dull blade.
REMEMBER: SAFETY FIRST LAST AND ALWAYS!!!
Make sure the saw is unplugged or the battery is removed.
If you have a blade in there:
Hold the saw over a work bench and push the ejector lever to the center of the front of the saw. There is a center stop; you will feel it. The blade will eject and fall out
Insert the new saw blade into the plunger until it latches into place. The teeth should face toward the front of the saw. The back of the blade should rest in the groove of the guide roller. The plunger and the guide roller are between the body of the saw and the plate
If the blade will not go into the plunger, check the positioning of the slots in the blade. They should be at the top. Push the ejector lever and try again.
Give the blade a yank to check that it is firmly seated. Plug the saw back in or replace the battery and proceed with the cut
Use protective gloves when handling blades. They can be sharp and can be HOT.
I hope this helps
Please rate FIXYA
Thanks
Charly
Posted on May 20, 2011
My Bosch AHS 48-16 Electric Hedge Cutter hit a bit of wire, now there's s clickingn noise when trying to start it. Any help appreciated
It could have possibly damaged the cutting edge of the blades and put a burr on them, meaning that as the blades reciprocate, the 'burr' is catching on the other blade.. Check the blades for damage and use a flat file to smooth off any burrs that could be catching. (Make sure it's unplugged before doing any work on the machine)
May 10, 2016 | Electric Garden
How to replace blade for central machinery Model t-1582
This saw has been discontinued by Harbor Freight. However, you may able to ask from them a manual by sending them an email. Try to check this manual. Hope that helps.
Nov 24, 2013 | Saws
I have Bosch hedge trimmer AH15 63-16C which has stopped cutting. It still seems to be working as it should and the cutters moving as normal but suddenly stopped cutting? Just wondering if this is fixable...
This sounds similar to a problem I have with my Bosch AHS 60 24s. The blades are moving but not independantly and therefore not in a cutting action. I took it apart and the bottom blade has slipped off the drive wheel. I put it all back as it should be but as soon as I used it again, the same thing happened. I'm not sure why this is happening, it may be that the motor end of the bottom blade has become slightly bent, so I will be trying to straighten at the weekend. The cost of replacement blades is prohibitive and time for a new hedge trimmer. Has anyone else had this problem and a different solution.
Oct 07, 2013 | Bosch AHS 45-16 Electric Hedge Trimmer
Can I replace just the blade on my pizza cutter? It seems a shame to buy a new one as it really is in good condition, just the blade is blunt.
The Web Restaurant Store sells pizza cutter blades for a good price, although as the pizza cutters themselves are not expensive, you might find it just easier to buy a new one.
http://www.webstaurantstore.com/american-metalcraft-pcw-4-4-pizza-cutter-replacement-blade/69332864.html
Feb 28, 2013 | Home
What is the difference between the angle cut blades and the shear cut blades on my bolt cutter?
angle cut blades have the cutter head angled at 25-35 degrees for easier insertion into tight spots. Shear cut blades are light normal scissor blades
Jan 16, 2013 | Cutter Tools
How do I change the blade on a Bosch 1582 vs?
There is a round hole in the center of the front handle that allows you to use a long narrow flat head screwdriver to loosen the slotted screw that locks the blade in place. Then you can turn the blade 90 degrees and remove it, replace it, and reverse the process. You need the right kind of screwdriver, one with a blade about 3/16" wide and a quite long stem before the handle, so you can reach the screw.
See also this article.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 22, 2011 | Saws
My chainsaw won't cut through timber, it will only scorch it. Is it possible that I have the blades the wrong way round? If so, I don't know how to turn them inside out. I've had this problem for ages...
From your description of what is occurring, you are probably correct that the chain is installed in reverse. To verify take a look at the individual cutters on the chain - are the sharpened edges pointing in the direction of the chain rotation? When looking down on the chain bar (the "cutting arm"), are the cutters facing toward the tip of the bar? If not, the chain is backwards. If the chain is installed correctly, but you are still not cutting, the chain is most likely extremely dull and needs to be resharpened.
I'm not familiar with the specifics of the Bosch chainsaw. I live in the US and the Bosch saw is generally not available here. I recommend you consult your manual for instructions on removing and installing the chain. If you do not have a manual, you can call Bosch UK and they will send you a replacement.
Hope this helps.
Regards,
DIYpro
Apr 28, 2011 | Bosch Garden
Blade won't stay in jigsaw
It sounds like you need to replace the shaft.
Feb 22, 2009 | Bosch Saws
Onkyo sr606 unable to select speaker setup in the menu screens?
sometimes, the memory of the receiver will act abnormally.. what you need to do is return the unit back to factory settings. To do that, press and hold vcr/dvr button and while holding it, press the standby/on button. You will see the word clear. It would reactivate your settings. ^_^
Dec 06, 2008 | Onkyo TX-SR606 Receiver
Garden Logo
175 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
