Please help me to use the function for solving bearing angles for surveying for solving Latitude and departure Im using now fx-991MS
SOURCE: doubts
how to calculate antilog in fx-82MS
Posted on Nov 20, 2008
  • 8073 Answers
SOURCE: how to calculate inverse of a 3x3 matrix in casio
Here is the solution for th FX-991ES.
The error may be due to the key you used to signifie inverse. It says in the manual that you should use the key x^-1 not the one used to input general powers.
Here is screen capture from the Appendix to the manual. The picture shows the sequence of keys to press to obtain the inverse of a 2x2 matrix. It is taken from page 41 of Appendix
The matrix used in the exemple is
a_11=2 a_12=1 a_21=1 a_22=2
Here is the link to download the manual and the appendix
http://support.casio.com/manualfile.php?rgn=1&cid=004001004
The link is for FX991ES. Look there foe you manual.
Hope it helps
Posted on Sep 07, 2009
  • 8073 Answers
SOURCE: Hi, I have a Casio calculator fx-991MS giving me wrong answers!
I am only looking for a plausible cause of the error, because I do not believe your calculator can make such a mistake. I think you accidentally activated the Exponential display format and did not pay attention to the small, raised -03 that came at the end of the number displayed. It is a common mistake for those not very familiar with Scientific or exponential notation.
Let us try to reset your calculator to the normal (floating point) format.
Press the [MODE] key a number of times until you reach a screen that has FIX, SCI, NORM and under each one a number (FIX 1, SCI 2), Norm 3). To have the number of decimal place you gave in your result (4 decimal digits), you press 1 to select Fix then 4.
Be aware that scientific calculators usually stop displaying results in floating point format ( 0.0000045 ) if the number is smaller then 0.001. So basically, 0.00099 will be displayed as 9.90-04, -04 being raised above the level, and in smaller size.
Hope it helps.
Posted on Oct 02, 2009
Testimonial: "Thanks so much, its working now:) I thought I was going to have to buy a new calculator!"
adnanbhatti
  • 1188 Answers
SOURCE: can i calculate calculus using fx-991ms
If you want to get an answer like 1/2X for d/dx(X^2), you will have to purchase a CAS calculator like Casio's Algebra FX-2 or Classpad. TI series calculators also have CAS.
However, you can calculate the numerical values of derivatives and integrals only.
To calculate the value of a proper integral:
  1. Press the 'ON' key;
  2. Press the Integral key b8325f5.jpg;
  3. Enter your expression (example X^2+X-3 etc);
  4. Press the 'comma' key after your expression;
  5. Input the first limit after comma, input comma again after first limit;
  6. Close brackets;
  7. Press the equals key, display may return after a while with the answer.
for eg to calculate xdx from 0 to 2, input as follows:
dx(X,0,2)
To calculate derivative at a point:
  1. Press Shift and then the integration key.
  2. Enter your function;
  3. Input comma;
  4. input the point at which you want to evaluate the derivative;
  5. Close bracket and press enter.
Example, to calculate d/dx X^2 at 3 input:
SHIFT+dx key X^2,3)
Display looks like this: d/dx(X^2,3).
Posted on Oct 23, 2009
  • 8073 Answers
SOURCE: how to calculate 0.3log(base 2)0.3 using fx-991ms
Your calculator knows only the decimal logarithms log or log_10 and the natural logarithms (ln or log in base e).
So you cannot compute directly the logarithms in any bases other than 10 and e.
A workaround consists in using the relation
log in base b of a number a (log_b (a))
log_b(a)= (log_10(a) ) / (log_10 (b))
or the relation
log_b(a)= ln(a)/ln(b)
log_2(0.3)=log(0.3)/log(2) where log is log in base 10
Similarly
log_2(0.3)=ln(0.3)/ln(2)
As to the multiplicative factor you had at the beginning of your expression, just multiply the value obtained by one on the formulas above (both formulas will give the same result) by 0.3
Posted on Jul 24, 2010
I've got a casio fx 991plus calculator and I want to know how to use feet and inches in the calculation displays, like how is used meters and centimetres in the display
PDF]fx-570MS/991MS Additional Functions - Support - Casio
support.casio.com/pdf/004/fx570MS_991MS_E.pdf
Casiodisplay format (Disp) settings while the calculator is in the BASE ... Be sure to checkthe current calculation mode (SD, REG,. COMP ... Use [ and ] to display the expression 4 + 4. Press A ... want to perform scientific function calculations. COMP .
The Casio fx-991es, fx-570es and - Numericana
www.numericana.com/answer/casio.htm
The Casio fx-991ex succeeds the fx-991es (functionally identical to the ... Both are nonprogrammable nongraphing scientific calculators, with natural ... Side-by-side comparison of the fx-991EX and fx-991ES PLUS. ... Displays QR codes for smartphone use .... Work out a formula for many values of the input variables.
CASIO fx-991MS Calculator Tutorial: Lesson 5- Dealing with ...
Dec 03, 2015 | Casio Office Equipment & Supplies
I am using fx-991ms calculator.The numbers are not visible.How can i increase the brightness of the screen.
when the battery gets low the display digits will dim, but not always the case, you can try sticking something under the calculator to to change the angle of the screen.
Feb 18, 2015 | Office Equipment & Supplies
Casio fx 991ms
On a fx-991MS? With many other models, including the fx-991ES, I'd say you have the calculator in binary mode but the 991MS doesn't have such a mode.
Aug 03, 2013 | Office Equipment & Supplies
How to find antilog on casio fx-991MS?
For common antilog, use 10^x, the shifted function of the log key. For natural antilog, use e^x, the shifted function of the ln key. In either case, press the appropriate function and then enter the expression whose antilog you're seeking.
Oct 26, 2010 | Casio FX-300MS Calculator
Sir,as i know about fx-991ms calculator,it contains above 400 functions.but my calculator fx-991ms calculator contains only 240 functions.sir pls inform me why this?
How did you arrive at this lowly number of 240?. Did you actually count them? Did you use them all? Some may be accessible through a specific sequence of key presses and for that you will have to read the whole manual.
Your calculator contains physical constants (and there is bunch of them). It can do conversions between units and back. Each physical unit and each conversion in one way is a function.
If your calculator is defective you will have better luck detecting the defect by thinking about a function that you want and verify if your calculator has it.
To distinguish themselves from competitors manufacturers make many claims and the claimed number of functions is one such point they try to emphasize with the consumers. No one can easily verify the claim unless one knows what the manufacturer calls a function. (remember these are not mathematical functions but functionalities (capabilities). Having two line display may be one of them and so is the replay.
Sep 05, 2010 | Computers & Internet
How to calculate 0.3log(base 2)0.3 using fx-991ms calc
or the relation
Similarly
Jul 18, 2010 | Casio FX-115ES Scientific Calculator
How to calculate calculus problem by a scientific calculator fx-991ms
If by calculus problem you mean derivatives of functions, integrals, extrema and such things, I am sorry to inform you that neither the Casio FX-300MS, nor the FX-991MS can handle them. The newer Casio calculator FX-991ES is capable of performing numerical differentiations and integrations. There also graphing calculators by Casio FX-9750G, FX-9860G as well as by Texas Instruments (TI 83 PLUS/TI84PLUS) that are reasonably performant in that area.
Hope it helps.
Oct 19, 2009 | Casio FX-300MS Calculator
M mod n in Casio fx991MS
there is one button ab/c beneath CALC... if u want to calculate 7 mod 4 then... u should press 7 then ab/c 4 and equal to
1, 3 ,4 which is 4*1=4 and 7-4=3 remainder...
Jun 29, 2009 | Casio FX-115MS Plus Calculator
74 people viewed this question
k24674
jasbo
jasbo
