Question about Garmin GPSMAP 541s
All brand new GPS541S & transducer. I can not get the depth reading to appear on the screen however, I do get the speed & temperature. Also, no fish-finder or view of the bottom either. Any ideas?
    Guru:
  • 1,833 Answers
You have said that your GPS device is brand new so I suggest that to return it to dealer for replace or repair within warranty. You can check first the battery is not low or bad. May there is any problem with settings. Reset it with help of manual. Reset the time zone etc. Your GPS device may have software problem and need to reload the software.
Posted on May 20, 2011
Lowrance hook 5. Brand new but the temperature and depth readings are blinking and are not accurate. Whats going o
Hey Raymond,, Are you reading this when you are at home or in/on the water? Is your transducer in the hull or outside? Do you have the correct transducer?
Please check these and reply back to me..Thanks!!
Jun 18, 2017 | Lowrance Boating
My Mark 4 sometimes shows incorrect depths. The transducer has not moved and no problem with electrical. One point it is working fine, the screen then runs multiple vertical lines and the depth chan
Take note if when the vertical lines appear on the screen if the depth numbers begin to flash. If this is the case then the transducer has lost bottom contact and the unit is trying to reacquire bottom contact. If the transducer is parallel to the bottom of the lake while your boat is not moving then, the next time you have it on the trailer, turn your unit on and go listen and or feel the transducer to see if you can hear and or feel the tick or sonar ping. If you can't your transducer may be faulty. If the loss of bottom contact occurs when you are moving it will happen at a certain speed. This is the result of air bubbles passing under the transducer and disrupting the sonar signal causing loss of bottom contact.
Sep 19, 2014 | Lowrance Mark 4 Chartplotter/fishfinder...
What is causing the depth to keep blinking when my boat is on plane.sometimes the screen just shows a horizontal line where the depth should read. garmin541s brand new
First, make sure that the connection is good, clean, and tight on both ends of your transducer. Sometimes turbulance or temperature stratifications in the subsurface water will cause this. Also, check the specifications of your transducer. Some do not perform well while moving at high speed. One test, when on plane, when the problem occurs, slow the boat and see what happens to the readout. Repeat this several times. This should help narrow down what is causing the problem.
Sep 19, 2013 | Garmin GPSMAP 541s
The unit worked fine for 3-4 months.Now,it just gives a reading of 0 ft. with the water temperature. Once in a while while i'm drifting it will give me a depth for a few seconds and go back to a 0...
It sounds like your transducer has gone bad. You may be able to find a replacement on Craigslist or eBay, since this is an older model. Transducers are pretty sensitive to bumps and drops because of the crystal inside.
Aug 23, 2011 | Humminbird Piranhamax 170
My fish finder isn't showing depth or temperature anymore. I was fishing one day and my temp started blinking and went away, then my depth began blinking and went away. Soon after this my screen wasn't...
Yes... or it is unplugged... or the wire is broken...
Typically you hear a clicking sound at the transducer when it is powered and running but in your case all function is missing from the display and temp and depth is off of the transducer..
Sep 04, 2017 | Humminbird Fishfinder 550
When at speed i tend to lose sight of the bottom it becomes very broken. Also the depth reading takes a while to record depth.
What you are experiencing sounds like air bubbles crossing the face of the transducer. If you have a transom mount transducer check the face of the transducer. Make sure that it is clean. Also make sure the front of the transducer is a tiny bit lower than the back. The digital readout on the screen will only happen when you have a strong signal of the bottom.
Jun 28, 2010 | Lowrance Dual Frequency Transducer
My depth finder loses its depth reading at about
You need to set the transducer lower. When at speed, the hull of the ship raises up out of the water and hence your transducer is probably not deep enough at these times to give a proper reading.
Jan 21, 2010 | Humminbird Boating
No depth reading while on plane.
Depending on your transducer type, you may have a liquid filled type that simply needs refilling. If this is the case check for leaks and get it redone. If not it could be transducer placement or cavitation under the hull.
Jun 18, 2008 | Raymarine A65 Combo GPS...
Log and trip function not registering
It is unlikely the problem is in the A65 screen.....most likely it is an issue with the paddlewheel itself, its circuit in the depth/speed transducer, or least likely, in the DSM25 sounder module.
Both the log and the trip functiions are read from the paddle-wheel sensor of the connected DSM25 sounder module and transducer.
1. Make sure you have a DSM25 sounder module and transducer with a paddle wheel (the A65 is available without the DSM25 option.)
Double check the connections between the DSM25 and the A65, as well as the transducer connection to the A65. There is an indicator light on the DSM25 to confirm it is on.
2. Make sure the paddle wheel turns freely. They tend to get fouled easily with debris and growth.
3. Make sure the A65 is giving to a reading for SPEED when underway or when having a buddy spin the paddlewheel by hand. Do not confuse SPEED with SOG. SPEED is from the paddlewheel.....SOG (Speed over ground) comes from your GPS sensor and is not used by A65 for log or trip purposes.
If you get npo speed reading at all the paddle wheel may be defective or the depth/speed transducer may be defective. See your dealer about a replacement.
Nov 06, 2007 | Raymarine A65 Combo GPS...
Garmin GPSMAP 541s Logo
90 people viewed this question
Top Garmin Boating Experts
TO Lady
charles
Are you a Garmin Boating Expert? Answer questions, earn points and help others
