Question about Lexmark C533DN InkJet Printer
Cannot get past initial set up ie two problems cannot power of printer with button on front panel also cannot get any language up on small screen
  • Official Brand Answer
  • 3,344 Answers
Try to unplug the power adapter from the printer.
Then unplug the power cord from the power outlet in the wall. Wait for at least 10 seconds before you replug the cord. Then replug the power adapter to the printer.
Posted on Jun 01, 2011
Eror code E000020-02a9
Incorrect language appears on the display
If the "Before you troubleshoot" checklist does not solve the problem, then try one or more of the following:
CHANGE THE LANGUAGE USING THE PRINTER MENUS
1 From the printer control panel, press .
2 Press the arrow buttons to scroll to Defaults, and then press .
3 Press the arrow buttons to scroll to Set Defaults, and then press .
4 Press the arrow buttons to scroll to Use Factory, and then press .
5 Complete the initial printer setup.
CHANGE THE LANGUAGE USING A BUTTON COMBINATION (IF YOU CANNOT READ THE CURRENT LANGUAGE)
1 Turn the printer off.
2 Press and hold down and , and then press to turn the printer on.
The printer resets and starts the initial printer setup.
3 Complete the initial printer setup.
Aug 02, 2013 | Office Equipment & Supplies
How do I change language settings on my Dell V313 printer
Printhead error
Apr 22, 2013 | Dell V313w AllInOne InkJet Printer
How do I reset my Dell all-in-one printer to the English language mode?
If you cannot read the language of the menus and you want to reset the printer to default settings try this:
Using a button combination (if you cannot read the current language) 1 Turn off the printer. Note: If you have set the Power Saver timeout in the Setup menu, then press and hold mad_nas_5.jpgthe for three seconds to turn off the printer. 2 From the printer control panel, press and hold mad_nas_6.jpg and mad_nas_7.jpg, and then press mad_nas_8.jpg to turn the printer on. 3 Release all three buttons. 4 When prompted to set the initial settings of your printer, make your selections using the printer control panel buttons. Initial Setup Complete appears on the display.
If this is not helping you try to find the user manual for your model at the manufacturer site.
Mar 05, 2011 | Office Equipment & Supplies
Change the language on hp laserjet 4000 to english
For the LJ4000 to change the control panel language:
On the front panel, hold down the SELECT key.
Turn the printer on, while continuing to hold the SELECT key.
When the Select Language message is displayed release the SELECT key.
Initializing will display on the control panel. After 5-7 seconds Language=English will display.
Press the VALUE key until the desired language is displayed.
Press the SELECT key and an asterisk will appear. The asterisk indicates that the printer has saved the new setting.
Press the GO key to display Ready in the language that was selected.
NOTE: If Select Language does not appear in the display, hold down the SELECT button until you hear the motors rotate, then release. Following printer initialization, the Language= menu will appear in the display.
hope it helps, if so do rate the solution
Nov 30, 2010 | HP LaserJet 4000 Printer
Printer is showing "error: 0xf0af0001 Reset Power". I have unplugged and then plugged in printer multiple times and printer comes ok for about 30 seconds and then the same error message appears will all...
last month i had same problem and i contacted customer care and i got this solution. And this works.
Step 1:
Perform a partial reset.
A partial reset returns the user settings to the factory defaults. The language and country/region settings may also be deleted.
Please perform the partial reset using the following steps:
a. Unplug the power cord from the all-in-one.
b. Press and hold the "#" and 3 button on the front panel keypad.
c. While still holding the buttons down, plug the power cord back in. Release the buttons after the all-in-one begins to initialize.
If the issue persists, follow Step 2.
Step 2:
Perform a semi-full reset.
b. Press and hold the "#" and 6 button on the front panel keypad.
Jun 24, 2010 | HP Officejet 5610 All-In-One InkJet...
How do you change the language
To set the language on your printer initially:
1. When you first power on your printer, press the Arrow buttons to find your. language. 2 .Press the Menu button to select your language.
Resetting the Language on Your Printer:
If you need to change the default language used on the operator panel, complete the following steps:
1 Press the Power button to turn off the printer.
2 Press the Power button and the up arrow button simultaneously.
3 When the language settings appear, press the Arrow buttons to scroll to your language.
4 Press the Menu button to select your language.
Sep 28, 2009 | Dell 924 All-in-One InkJet Printer
Printer Canon MP600 turned Japanese!
There are language settings. Go to the main menu and rotate through to the pliers/screwdriver icon. (settings) Click the right button to select the icon with two sliding tabs. (device settings) Scroll down 4 selections to language selection. Select English.
Dec 17, 2008 | Canon PIXMA MP600 all-In-One InkJet...
I accidently changed the language now its in dutch i think
Troubleshooting steps to be Followed
Setting the front panel language on the HP PSC 2200 series To set the language and region, follow the steps below:
  1. On the all-in-one front panel, press the Setup button five times, and then press Enter to access the Maintenance settings.
  2. Press the number 5 on the front panel numeric keypad, and then press Enter to access the Language and Region settings.
  3. The available languages will appear in the display. Press the Right Arrow (>) button to scroll through the available languages. Enter the two-digit code for the desired language based on what is listed in the display (example - 11 for English, 12 for Spanish, and etc.).
  4. Confirm the selection by pressing the number 1 on the numeric keypad of the all-in-one. Press 2 to cancel the language and try again.
  5. The available regions will appear in the display. Press the Right Arrow (>) button to scroll through the available regions. Enter the two-digit code for the desired region based on what is listed in the display.
  6. Confirm the selection by pressing the number 1 on the numeric keypad of the all-in-one. Press 2 to cancel the region and try again.
The front panel language does not set correctly There can be a problem if the front panel cover (bezel) is not installed correctly. If the language cannot be set or is still wrong, do the following:
  1. If the software has not been installed, install it.
  2. Remove the control panel bezel. This may require the use of a coin or small screwdriver to carefully pry up the cover from the back (near the display).
  3. Reinstall the front panel bezel as shown in Figure 1. Be sure the bezel is firmly seated and that all of the buttons can move freely. Figure 1: Installing the front panel bezel c00224430.jpg
  4. Set the front panel language following the steps above.
Sep 18, 2008 | HP PSC 2210 All-In-One InkJet Printer
Panel shows different language
Follow the following steps:
  1. Turn off the printer.
  2. Press and hold down the right VALUE button.
  3. While holding down the right VALUE button, press and release the POWER button.
  4. When INITIALIZING appears in the LCD, release the right VALUE button.
  5. The message VALUE AND SELECT KEYS TO CHOOSE LANGUAGE is displayed in the LCD and the currently selected language is displayed as =ENGLISH .
  6. Press the VALUE button until the desired language is displayed.
  7. Press the SELECT button and the desired language is now selected and displayed in the LCD and the printer returns to the READY state.
Feb 06, 2008 | HP Color LaserJet 2600n Printer
Memory faulty
Perform a semi-full reset on the all-in-one by following the steps below >
  1. Unplug the power cord from the wall outlet.
  2. Unplug the power cord from the all-in-one.
  3. Wait 30 seconds and plug the power cord back into the wall outlet.
  4. Press the Cancel and Right Arrow buttons.
  5. While still holding the buttons, plug the power cord back into the all-in-one. Continue to hold the buttons for two seconds, and then release them
  6. Allow the all-in-one to re-initialize. This may take a minute or two.
  7. If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information.
The problem should be corrected. If the problem still exists, replace your product.
Thanks
Jan 18, 2008 | HP PSC 2175 All-In-One InkJet Printer
Lexmark C533DN InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
